AEG U3100-4-M Oven - RCD trips after heating up
  • spleenharvester
    • Mar 2010
    • 913
    Odd problem here with this oven. Once it's been heating for about 10 minutes the RCD trips. If you try and flip the RCD back on it will trip instantly until the oven has cooled down again.
    It's previously eaten an element so I replaced the element again - fault remains. My next thought was possibly the cooling fan, as the mainboard's cooling fan kicks in after about 10 minutes usually, but the resistance is testing OK.
    There's some quite badly melted plastic around the earth connection at the back of the oven, but I'm not sure if this damage was caused by the fault or if it occurred at a previous time. Despite the melted plastic the connections seem to be electrically sound.
    Any ideas?
    E: Also worth noting it smells like burning plastic whenever used, but the melted terminal block doesn't seem to be heating up.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 913
    Re: AEG U3100-4-M Oven - RCD trips after heating up
    Think I've figured it out, it was the terminal block after all - opened the rear cover and it's a complete mess of melted wires and plastic. I think there was some arcing going on between the live terminal and the chassis. Going to replace the terminal block, should hopefully fix it.
      • 31150
      maybe use a ceramic terminal block
      • R_J
        • Jun 2012
        • 9579
        If that doesn't fix it, it is likely the internal heat element wire shorting to the elements ground when it heats up
        • Curious808
          LG LST5651SW stove: oven not heating properly
          by Curious808
          LG LST5651SW stove: The oven has a hidden bottom (bake) element that seems not to be heating up, but tests OK.
          PROBLEM DESCRIPTION: Set oven to 400. The display shows it heating up normally to about 365, and stops there. The top (broil) element is visible and heated. Can't see the bottom element, but the bottom of the oven isn't extremely hot. A wet cloth on the bottom doesn't sizzle and doesn't really heat up. The stovetop burners seem to be working fine.
          TESTING SO FAR:
          1) Removed the back panel and leads to the bottom element. Using multimeter, continuity...
          01-07-2023, 02:37 PM
        • Fsufan1391
          LG Oven model LREL6325F
          by Fsufan1391
          Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
          04-23-2025, 05:42 AM
        • EasyGoing1
          The best way to drive a heating element?
          by EasyGoing1
          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
          This is the general setup that I have now.
          This is what the...
          01-25-2023, 11:29 AM
        • Cemal Odabasioglu
          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
          by Cemal Odabasioglu
          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
          Observations...
          01-14-2025, 03:54 PM
        • bpjl
          SEF 551.10 - Error starting the reflow oven.
          by bpjl
          When starting the SEF 551.10 reflow oven, the following problem occurs:
          It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
          PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
          10-17-2024, 06:30 AM
