Rubycon Capacitors
  • davmax
    • Dec 2005
    • 899
    Rubycon Capacitors
    I have now read and compared many data sheets on replacement caps. My conclusion is that Rubicon make the best. The ZL series have low impedance and high ripple current values that are superior to others I have checked. Now the new range ZLG is significantly better still.
    Why would anybody use another brand if Rubicon is available? If anybody can point me to a better product (Rubicon is more than sufficient) I would be very interested to compare.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Rubicon Capacitors
    really it depends on what is actually available. Panasonic FC, FM and Rubycon ZL are reasonably easy to find. MCZ is the ultimate Rubycon al-e cap for our purposes but difficult to find. check sanyo oscon specs as well another difficult to find cap.
    Rubycon
    Sanyo OS-CON
    • Rainbow
      • Aug 2005
      • 1375
      It's also question of price. If new caps cost more than new board, it's not good. Most people will buy new board instead, even if it's crap.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        yes of course. If we look at http://www.pcbulb.com/ website in HK/China we see the following :
        Oscon SA series 2200uf 6.3v = $4.08 (1 piece)
        Oscon SEPC series 1500uf 6.3 = $1.36 (1 piece)
        Rubycon MCZ 2200uf 6.3 = $0.68 (1 piece)
        Those are realistic prices because pcbulb has good availibility. It is difficult to compare them anyway because you could get away with probably 1/2 the UF in oscon to get similar performance than general non polymer caps.
        Then if we look at Farnell
        Panasonic FC 1000 6.3 = 0.25 British Pounds
        Rubycon ZL 1000 6.3 = 0.28 British Pounds
        Rubycon ZA 1000 6.3 = 2.87 British Pounds
        Oscon SP 1000 4 = 2.04 British Pounds
        Oscon SA 1000 16 = 7.00 British Pounds
        The Rubycon ZA, Oscon SP and SA are too expensive and not realistic price because they are not maintaining good stock of them.
        what i am saying is that you can get better caps than FC and ZL but availability and pricing makes it not realistic unless you are intending your board to have the ultimate overclocking performance and price is not so much a consideration.
        in that case you couldnt go wrong with having Rubycon MCZ everywhere except vcore where you would use oscon SEPC. That i believe would be the best price/performance ratio in the premium category.
        • MrCreosote
          • Dec 2005
          • 31
          Re: Rubycon Capacitors
          wow,
          I looked around pcbulb.com and those purple Sanyo OSCONS.... well I was stripping some old mobos and I removed a bunch of caps that looked just like them. I didn't have good light so I couldn't read them. I'm going back there (friend's computer shop) today and am going to see just what those were!
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
            Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
            by sam_sam_sam
            I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
            This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
            After all of...
            07-13-2024, 08:14 PM
          • Cama
            Solar Inverter - SMH-II - 2 missing capacitors
            by Cama
            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
            My model is : EASUN SMH-II 7 KW
            Mother Board : P/N 18947-002401250250
            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
            Thank you...
            09-12-2025, 02:50 AM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
