A1706 MacBook Pro mid 2017 no internal SSD 820-00923
  • slimmy182
    • Apr 2021
    • 119
    • italy
    Hello people.
    I've purchased this mid 2017 13" MacBook Pro touchbar, logic board number 820-00923 who don't recognize internal SSD anymore. When powered on it display the question mark. Seller says that it simply stop working one day, no liquid spill, failed update or so. It can operate perfectly installing MacOs on external drive, but internal SSD storage does not show up in online recovery nor when external hard drive is plugged it to launch MacOs.
    I decided to open it and try to resolve the problem. Never been opened or worked before for sure.
    Inspecting the board under the microscope show this two little spot of corrosion:
    probe point TP[1]TP_Q3100_DRAIN , picture show before and after cleaning
    and LB300 (It's a filter?)
    I can't find any other spot or phisical damage on this board. J9600 (lifeboat port) also look good. Could you please help me fix this Mac? Any advice or suggestion what to check it's really well accepted. Thank you in advice!
  • mon2
    • Dec 2019
    • 14503
    Re: A1706 MacBook Pro mid 2017 no internal SSD 820-00923
    Remove all power & battery. Wait for the capacitors to discharge - a few minutes should be ok to drain out the power off the board.
    Then pour IPA (alcohol) and clean each of the referenced spots on the logic board to remove the glowing green swamp juice residue. Use a cotton swab / Q-tip to clean up the areas.
    Then review the locations again to be sure there are no broken traces.
    One of the sites is near the CD3215 ACE controller = Power delivery controller which will negotiate the 20V power contract to boot the logic board. Locate the USB connector near this ACE controller and where you see the green puss. Attempt to power the board using that USB Type C connector -> does it work ?
    If it does, the liquid corrosion is not a fault for this ACE controller.
    The DRAIN pin you mentioned is linked to the PPBUS_G3H power rail which is a major power feed to the PCB. That is, it must be working ok since your board boots.
    After the cleaning, the next logic step will be to review the SSD voltage rails on the logic board to be sure that each is present.
    and watch this video...
    https://youtu.be/yt0f3sGSZas
    • slimmy182
      • Apr 2021
      • 119
      • italy
      Thank you for the reply mon2!
      After cleaning as you suggested I can confirm CD3215 ACE controller works fine, it does negotiate the 20V and I can boot up and charge the battery.
      I guess you are right for the DRAIN pin as board boot correctly.
      I'll try to understand as much as possible watching this video, and try to identify SSD voltage rails as i'm not so good on looking at schematics. Thank you very much!
      • mon2
        • Dec 2019
        • 14503
        The SSD is considered to be an active component. So it requires power rails to function.
        The SSD is soldered onboard. In the schematic, search for the keyword 'SSD' and the pdf search engine will locate the hits and some should be power rails. That will be the first step. Then locate the part they show in the boardview file which will show the location on the logic board.
        It can take just a single broken trace or contact to be missing and the ssd detection can fail. The linked video if I recall correctly is about a common fault of a resistor that corrodes with liquid spills.
        Your board had some liquid exposure which is evident with the green film. You may also see a red dot on the pcb which is a liquid detector sticker applied by Foxconn who builds these circuit boards.
        Once you find a power rail, you can check if the voltage is present with your multimeter. Meter in dc voltage mode. Red probe to the test point. Black to ground like a metal shield. You can start with testing the voltage at the fuse you show in the posted pic - it is the white body part near the CD3215. Just to get some practice.
        Parts like resistors and capacitors are passive parts.
        • slimmy182
          • Apr 2021
          • 119
          • italy
          OK here I'm.
          Upon cheking fuse near CD3215 F3000 I've got 20V when plugged in and continuity is present. But if plug in the other side the other fuse FB200 show me 0 Volts, continuity present.
          About the Louis video, R9350 related to PPVIN_2V7NAND_LB measures 13.8V in both test point and pin1 and 1.58V on pin 2. Measuring the R9350 in 2000k scale I got 550homs
          I was looking for any other liquid spill but i cannot find any other at all, it's clean just little bit dusty nearby the usb-c connectors area. Any detector sticker is just white anywhere.
          C9126 - PP1V8_SSD_COLD - 1.8V diode mode 294 (2K scale)
          C9304 - PP0V9_SSD_FIXED - 0.9V diode mode 294 (2K scale)
          C8724 - PP1V2_SSD_HOT - 1.22V diode mode 328 (2K scale)
          C8714 - PP1V8_SSD_HOT - 1.8V diode mode 408 (2K scale)
          C8732 - PP1V2_SSD_COLD - 1.22V diode mode 282 (2K scale)
          C9323 - PP0V9_SSD_REG - 0.9 diode mode 208 (2K scale)
          I measured also PP3V3_S5_SSD and it's 3.34V. Seems SSD is powered
          I hope that this measures can help.
          • slimmy182
            • Apr 2021
            • 119
            • italy
            I got 0 voltage at L9300/20/30/40 and L9400
            C9422- PIN1 PP2V7_NAND_VCC 4.8V
            SSD_BOOT_LB_L 1.62V
            SSD_PWR_EN_LB_L 0V
            STORAGE_LB_EN 3.05V
            SSD_RESET_LB_L 3.05V
            SSD_PCIE_CLKREQ_LB_L 3.18V
            LPSR_EN_LB_L 3.05
            at R9420 P2V7NAND_EN and PICCOLO_VEN1 are 0V
            • slimmy182
              • Apr 2021
              • 119
              • italy
              There is anything I can check to isolate the problem?
              • dellxps15
                • Feb 2014
                • 1596
                • italy
                post picture of ssd socket and ofcourse use macbook ssd, or ssd adapter with a good nvme drive as non nvme doesnt work.
                check if all capacitor near ssd socket are ok and looks good.
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  A1706 does not have removable SSD.
                  • mon2
                    • Dec 2019
                    • 14503
                    From your post #6 and following the same thread on the Rossmann forum, the voltage readings look a bit low.
                    This is a show stopper.
                    https://boards.rossmanngroup.com/thr...15/#post-86929
                    • slimmy182
                      • Apr 2021
                      • 119
                      • italy
                      Thank you. As my U9400 is burnt I’m waiting to get an other one. But I guess something as changed as my first measures are different. The ones takes in post#6 are correct
                      What can be the cause? There is anything to check untill new U9400 is arrived? Tanks
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        I have the same problem on the same motherboard. Did you manage to repair it?
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • sofles
                          Macbook a1707 2017 model 820-00928 GPU issue
                          by sofles
                          Hello there
                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                          11-21-2024, 05:25 AM
                        • Tennen
                          MacBook Pro 2017 A1706 820-00923 no power, low voltage PPBUS_G3H
                          by Tennen
                          Heya, so recently a MacBook Pro 2017 A1706 820-00923 reached my table, showing no signs of life at all. I am trying to use it as an opportunity to get more into the details of fixing Apple products. What I did so far might not have been ideal, but I am trying to improve.
                          The story I got told:
                          The MacBook received a new battery at some point and later at a random point in time just stopped working. Some specialist shop tried to diagnose the issue but only tried another battery - concluded mainboard damage and returned it to the customer.
                          What I did and learned...
                          10-20-2022, 07:26 PM
                        • kurtspirit
                          Macbook A1706 EMC3071 (2017 Touchbar)
                          by kurtspirit
                          I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
                          So I took it apart and started measuring.
                          The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
                          Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
                          I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
                          What do you think ?...
                          08-23-2022, 05:57 AM
                        • afarr
                          Apple MacBook Pro Mid-2017 A1706 - C7490 Capacitor Help
                          by afarr
                          Hi all, this is my first post, I offered to check out a friends MacBook Pro, A1706 which doesn't power on, before this happened they smelt something burning inside, and Apple refused to help with out being out of warranty.
                          Among investigating a capacitor on the logic board spilt and scorched surrounding area please refer to images; https://imgur.com/a/AmSwFr3
                          I found a schematic (x362 MLB Schematic) for the logic board on a thread from this site, I'm unsure about the right terminology when describing so please forgive me.
                          On the location I assume...
                          02-13-2023, 01:11 PM
