Sencor SVC7020BK robot vacuum cleaner problem
  • Awesomerp
    • Sep 2022
    • 29
    • Lithuania
    Hello I have been trying to identify and fix a problem with a robot vacuum cleaner, which when switched on cleans for like 3-4 seconds and stops, all the driving, sweeping and vaccum motors stop.
    On the pcb from a battery connector up to a main microcontroller everything seems to be fine (vcc pin input is 5v constant when a switch is switched on).
    And the switch itself is fine looking at the quality of my soldering
    Red LED keeps blinking during those 3-4 working seconds, and when the robot stops LED just remains lit.
    The green one for some reason does not even blind/shine i think the volage does not even reach it or not enough to say at least.
    What I figured so far:
    Battery charges( but as previously said green LED should blink when it charges but doesn't and i tested led is good, when i put my Multimeter probes across it, I can see clearly that it blinks but when i remove it ,it stops, so it means not enough voltage is supplied from the main controller?)
    5V linear regulator is working
    All the motor drivers look in shape, but stop working after 3-4s period
    Step down regulator does bring down voltage to 8.3V which is good.
    The D16 diode when checked with a multimeter on diode mode shows 3.2V in reverse biased but when i remove it and test it, its 0 don't really know why.
    If someone has any ideas or tips of what could be the case of this problem, would really appreciate your insights
    It is interesting what makes him switch off and I assume that the main microcontroller does the switching right?
    I am pretty new and trying to understand the whole working principle so shared knowledge would be awesome.
    I am also attaching images of pcb layout and schematics.
    Only the photos are mine so credits to the person who made the reverse engineering of pcb and schematic.
    • 30979
    Re: Sencor SVC7020BK robot vacuum cleaner problem
    you should find a manual to see what the leds mean.
    looking at the schematic, 2 things i noticed.
    1: the "charge circuit" is bullshit, charging a 14v battery from 19v with a 6ohm resistor is sooo cheap!
    2: the psu for the motors has a sense circuit - maybe it's detecting an overload?
    did you check the 8.3v??
    • Awesomerp
      • Sep 2022
      • 29
      • Lithuania
      Yeah the vacuum cleaner it self was pretty cheap, I guess they could not be bothered to make a better charging circuit
      1.And about the power monitoring circuit yeah 8.3v across the R7-R6 resistors is present, if you were talking about this circuit.
      2.They claim that red lit led means: the battery is flat or the cleaner is lifted of the floor. The battery seems charged to me. 14.4V on the meter. The green one seems not to get a proper voltage.
      3.Maybe you know why the D16 diodes "Reverse" voltage is displayed 3.2V while in circuit. (while in diode checker mode on multimeter)?
        • 30979
        change the LM393, it's the only thing that could show a low battery if r6,7,8 & 9 are o.k.
        d16 if you look, has a bypass - r8,9,10,5 and j28
        all in series allows the diode to be bypassed via ground.
        • Awesomerp
          • Sep 2022
          • 29
          • Lithuania
          R6- Measure- 6.8kΩ, Schematic - 18kΩ
          R7- 3.9kΩ, Schematic - 4.7kΩ
          R8- Measure 50kΩ, Schematic - 68kΩ
          R9- Measure 16.7kΩ other polarity 30-45kΩ(increases over time), Schematic 56kΩ.
          I can't tell if i can't get a good reading of how small they are or their resistance is actually lower than has to be. (strange that all of them act up)
          I tried with 2 multimeters and the results were similar.
          Voltage across (R6,R7) to ground is 8.3V and across (R8,R9) to ground is 13.8V.
          I think i will try ordering and replacing resistors first, if the problem will still occur ill replace the comparator.
          Thank you for your help I will update when the parts arrive and how it goes.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            resistors might be fine if as i suspect you measured in circuit ?
            i would look more towards the motor itself . it could be running at the wrong speed .. maybe jammed slightly from hair balls or something .
              • 30979
              lift one end of each resistor before testing, your metering the internals of the lm393 at the moment!
              • Awesomerp
                • Sep 2022
                • 29
                • Lithuania
                Yeah i did it in circuit
                • Awesomerp
                  • Sep 2022
                  • 29
                  • Lithuania
                  Sweeper motors draw 7.4V
                  Drive motors draw 8.2V
                  Vacuum motor draw 12.2V
                  Tested while it operates those 3-4 seconds until it stops.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    this is where the figures lose me . need to know what is expected .
                    • Awesomerp
                      • Sep 2022
                      • 29
                      • Lithuania
                      About the motors:
                      1. Drive motors are 8V 8000rpm
                      2. Sweeper motors are smaller rated at 8V 6000rpm
                      3.Vacuum motor is rated 8V 6000 rpm but bigger than sweeper ones.
                      1.Drive motors seem fine since they do get 8.3 while running
                      2.Sweeper motors get about 7.4 while running but when the robot stops it goes up to 8V.
                      3.Vacuum motor while running draws about 12.5V, when the robot stops voltage rises to 13.5.
                      I have shown the the voltages in the circuit diagram (in vacuum and sweeper motor parts).
                      1. Red values indicate voltage after robot stops.
                      2. Blue values when it is running those 3-4 seconds.
                      I suppose that initially the diode drops 0.6V from 14.4 which we can say is 13.8V approximately 13.5.
                      The question would be is the Voltage suppose to drop to from 13.5 to 12.5 while its running?
                      Also looking at the JP1 of vacuum motor connector on:
                      Pin1 voltage is present but I think Q22 transistors is being turned off (not getting proper voltage at base I assume) after 3-4 seconds that's why pin 2 does not get a voltage and the vacuum motor stops operating? ("well all of the motors stop operating").
                        • 30979
                        if you turn the motors by hand, is there any friction or are they spinning o.k.?
                        • Awesomerp
                          • Sep 2022
                          • 29
                          • Lithuania
                          Yeah they are okay, spinning freely.
                          There are ceramic caps on each of the motors is there any chance they could cause the problem?
                          Do not have an ESR meter to test them.
                            • 30979
                            ceramics either work or go shorted - and then they would burn.
                            • Awesomerp
                              • Sep 2022
                              • 29
                              • Lithuania
                              I see, thank you for the info, what about coils or electrolytic caps? Can they impact this behaviour? Now talking about the main circuit.
                                • 30979
                                get back to that lm393 - maybe check it's output signal under load
                                • Awesomerp
                                  • Sep 2022
                                  • 29
                                  • Lithuania
                                  Black probe on the ground and went through all the pins with the red one here's what i got. (picture)
                                  Voltage was constant with load and when it stopped.
                                  Only 8 pin changed a little:
                                  Load - 13,05V
                                  Stopped - 12,85V
                                    • 30979
                                    that makes no sense, how can the battery voltage rise under load?
                                    • Awesomerp
                                      • Sep 2022
                                      • 29
                                      • Lithuania
                                      My bad:
                                      Stopped - 13,05V
                                      Load - 12,85V
                                      • Awesomerp
                                        • Sep 2022
                                        • 29
                                        • Lithuania
                                        Well something with the charging circuit seems to be wrong too.
                                        Left a battery to charge for an hour and now it is 16.3V instead of 14.4.
                                        R72 got real hot.
                                        The values of the resistors are good.
                                        I suspect Q11 and Q12 surface mount transistors to be the culprits, will test them tomorrow.
                                        What do you think?
                                        • AlexVG
                                          Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                          by AlexVG
                                          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                          (This board does not respond, only the LEDs light up in a circle.
                                          The liquid damage is catastrophic and restoration is impractical).
                                          (I bought this board to get the WiFi module and camera).
                                          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                          If...
                                          10-22-2024, 07:20 AM
                                        • ex250
                                          SDJ01RM vacuum robot not powers on, all dead
                                          by ex250
                                          Hi friends, I have this vacuum robot at home that is not starting any more, no leds working, power button doing nothing, battery reading seems ok arround 14.4v, I suspect that mainboard is faulty, seems that there is not any clear brand model on it, and of course could not find any schematic. The trand of the vacuum is the Roidmi SDJ01RM, on some sites appears as vacuum mop Eve plus 60 or similar
                                          If any one could point for where to start... would appreciate, new board is quite expensive arround 100 USD or more
                                          Many thanks and Merry Christmas to all...
                                          12-24-2022, 05:12 AM
                                        • rtstorm
                                          Xiaomi Vacuum Cleaner Charger PSU
                                          by rtstorm
                                          Hello my vacuum cleaner dock died, 0V on output. I replace the caps but still no voltage. I found out that this resistor is broken (showing 0 Ohm) do know the value of this? Is this really 0 Ohm resistor?...
                                          05-24-2024, 10:07 AM
                                        • Henke
                                          Electrolux EUO9GREEN Vacuum Cleaner doesn't start
                                          by Henke
                                          I have a vacuum cleaner that won't start. I have desoldered 2 capacitors with low value. But i don't know if they can cause that kind of problem. Someone here with any thoughts and inputs?
                                          I marked the capacitors on the pcb picture with red and blue dots. The big one marked with 334 K measures 216 nF and the other one marked 224 K measures 109 nF.
                                          01-08-2024, 11:37 AM
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
