LCR T7 tester problem
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    Several months ago, whilst testing a box of old used caps which I had 'assumed' were discharged, the T7 LCR tester I was using was damaged.
    When the button was pressed, the display would briefly light up and then go dead.
    So, I stuck the T7 in the freezer for ten minutes and 'Bingo!' it came back to life.
    Only thing was that after it 'defrosted' at room temperature, the problem returned.
    After freeze spraying components one at a time, I managed to pin the problem down to a SOT-8 chip. An STC 15L104W. Which until now, I had just been spraying each time I used the device.
    Anyway, I decided to buy a new chip, to fix the problem, however this only makes the problem worse. The device screen merely flashes briefly and that is that!
    Replacing the original, bad chip, just takes me back to square one.
    My question is, "do these STC 15L104W's need to be programmed or flashed?"
    Adding some photos to help see what is inside the tester.
    Any suggestions will be greatly appreciated
    • 31214
    Re: LCR T7 tester problem
    they need to be programmed - but we dont have the code.
    i have the tools but not the code.
    the fix is to replace it with a small 2 transistor circuit and then re-flash the atmel.
    it will have much better battery life afterwards.
    as a bonus, if your going to do this then swap the atmel for an atmega644 or 1284 and a 20MHz crystal
      • 31214
      hmm - looking at your pictures they changed the board.
      you cant upgrade to a 644 or 1284
      you can still do the crystal upgrade though.
      is it still a colour display or did they fuck that too?
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Easy fella. Still has a colour display.
        What difference will the crystal upgrade make?
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          That would make sense.
          Does both the Atmel and the STC get programmed at the same time?
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            And this circuit is then squeezed into the casing?
              • 31214
              the atmel and stc talk to each other to control the power.
              the circuit can be built onto the pcb pads - i'v done it, or on stripboard.
              look here:
              https://github.com/madires/Transistortester-Warehouse
              • Crystaleyes
                • Sep 2021
                • 493
                • Brazil
                So do you think the STC 15L is damaged and should be replaced?
                Or just that it only works when cold due to the firmware being damaged?
                As mentioned, if it is freeze sprayed then it keeps taking readings one after the other, until Ileave it without testing for half a minute or so.
                Therefore it seems that it only needs to be chilled when 'beginning' the test readings
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  Hang on...
                  I might have been talking shit...
                  ..Right next to the STC 15L is a small diode, D2. With 'S4' written on it. TBH I hadn't paid that any attention seeing as when I freeze sprayed the chip the device worked.
                  That said, I just did a few runs spraying 'only' the diode...
                  ... And that made it work!
                  (where is the Face-Palm smiley?)
                  Let me rewind and focus on the diode before I think about flashing firmware and inserting circuitry
                    • 31214
                    that link should have the T1 schematics - it's very similar
                      • 31214
                      here
                      • lotas
                        • Jan 2016
                        • 4759
                        • Russia
                        Schematic diagram
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          Excellent.
                          Very similar indeed.
                          My concern is that the schematic is for the design which has the transformer whereas my tester is the cheapo version with no trafo.
                          In the schematic, D2 is an SS18 whereas my suspect D2 is an S4 (which I believe equates to an SD103 amongst others, inc. the SS54? and 1N5819 in through hole form).
                          I'll grab a diode tomorrow from the shops and confirm one way or the other
                            • 31214
                            the diodes are just 1amp schottky,
                            the circuits are similar but yours uses inductors to boost the voltages instead of the transformer - a better way of doing it i think.
                            • Crystaleyes
                              • Sep 2021
                              • 493
                              • Brazil
                              Right..
                              Even though the D2 diode tested fine after pulling it, I installed a 1N5819 1A Schottky to see if that made any difference, but it didn't.
                              I also pulled the Atmega238 and froze that separately, but that too made no difference.
                              Then I carefully froze the STC15L, being sure to avoid all other components, and the tester worked again.
                              So, the issue 100% lies with the STC15L104W.
                              Any suggestions as to how to resolve this?
                              Or just keep it for spares?
                                • 31214
                                replace the stc with the circuit i posted and re-flash the atmel with the software from madires at that link
                                if you cant build the atmel software then i can create it for you.
                                do you have tools to program AVR chips?
                                btw, some people say to re-flash the stc chip,
                                i tried that for a friend but the stc chips are shit and dont always go into standby - result is it drains the battery overnight!
                                these testers (T1 / T7) have a couple of known problems.
                                one is the stc chip fucking up, another is a couple of ceramic caps shorting in the boost circuit for the zener testing.
                                • lotas
                                  • Jan 2016
                                  • 4759
                                  • Russia
                                  1. Getting ready to flash the U4 power controller. We solder the USB-UART converter with a stabilizer to the board.
                                  (3.3V to 3.3V, Gnd to Gnd, Tx to P1, Rx to P2).
                                  2. We connect the converter, wait for it to be detected by the system, launch the software, select the com-port, select the firmware from the archive (p. 1), set the frequency to 12 MHz, apply power, the processor starts, does not go into boot mode, is not detected by the programmer .
                                  3. Experimenting with the sequence of power supply to the processor and pressing the "Check MCU" & "Download/Program" buttons.
                                  4. We study the datasheet on U4, we find that the Test button of the tester is connected to the Reset output. Click "Check MCU", click the Test button, the microcontroller resets and is detected. In the same way, we launch the firmware, and finally, we flash U4.
                                    • 31214
                                    yes, but we are flashing firmware for the new atmel code,
                                    i dont think it works with the original chinese code - not on T1 anyway.
                                    • Crystaleyes
                                      • Sep 2021
                                      • 493
                                      • Brazil
                                      Can that be done with an Arduino Uno?
                                        • 31214
                                        yes, atleast i'v seen people doing it.
                                        personally i just use a USBasp programmer - why not when they cost about $2!!
                                        saves a lot of messing around with patch wires and INO files.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • seifaldenn
                                          LCR T7 tester problem short
                                          by seifaldenn
                                          LCR T7 tester problem short( dz2---v05 )
                                          you changed v05 working now Not a fixed measurement
                                          Any measurement out 2.95v
                                          Kim can solve the problem out 2.95v ...
                                          03-29-2023, 06:57 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
