Newark doesn't seem to have anything
  • MrCreosote
    • Dec 2005
    • 31
    People say Newark carries the UCC KZE.
    I just spent a lot of time on their website and they do carry a few KZE's but the selection is non-existant. No 1000, 1200, 1500, 2200uF. In fact the largest uF was 470.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Newark doesn't seem to have anything
    range seems to differ according to location. where are you located anyway?
    • Chris1992
      • Apr 2005
      • 561
      Newark also carries the Chemicon LXZ series. Try those as they are also good low ESR caps.
      The great capacitor showdown!
      • MrCreosote
        • Dec 2005
        • 31
        I'm in Jeannette, PA near Pittsburgh.
        Using their search engine with all the settable columns I get no 1500uF 6.3V radial lead of any kind.
        I thought it might be my browser, Firefox, w/ or w/o cookies, so I tried IE6 and still NOTHING.
        According to their own table they only stock 6 different types of caps @ 1500uF.
        That sounds totally weak. (and only 133 different 6.3v caps)
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yeah i checked also, strange selection. anyway, in the states you have many other choices for vendor
          • arneson
            • Sep 2005
            • 1267
            http://www.jameco.com/webapp/wcs/sto...21&pa=330721PS
            These are kind of noname and very inexpensive. have no idea of quality...
            Jim
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              they do not cross reference to low esr caps and anyway waste of money to recap with cheap caps.
              • Spacedye69
                • Nov 2005
                • 698
                • US
                I had to get Nichicon PW in 1500 6.3v 8mm from Mouser. They carry wide selection of Nichicon. The rest I got were HE series. Pretty cheap also. 8mm 1000uf HEs $.18 a piece(15) 2 1500 PWs were like $.40. 7 4700uf 10v 12.5mm were $1.18 a piece though!!!!!!!!! Easy web site and quick process.
                • PeteS in CA
                  • Aug 2005
                  • 3586
                  • USA, Unsure of Planet
                  Digi-Key also carries United Chemicon now.
                  PeteS in CA
                  • davmax
                    • Dec 2005
                    • 899
                    Digikey offers a very wide range of Panasonic Low ESR caps. The FC and FM series are appropriate.
                    Go through this Catalog and locate the Digikey part No. and check for stock with a components search.
                    http://dkc3.digikey.com/PDF/T053/0953-0969.pdf
                    e.g FC series 2200u 10V = Part P10230-ND at 90C ea. Single price
                    the NEW and superior FM series 2200u 10V = Part P12357-ND at 76c each.
                    This should be very helpful to many of you.
                    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                    160Gb WD SATAII Server grade
                    Nvidia 8500GT 256Mb
                    160Gb WD eSATAII Server grade for backup.
                    Samsung 18x DVD writer
                    Pioneer 16x DVD writer + 6x Dual layer
                    33 way card reader
                    Windows XP Pro SP3
                    Thermaltake Matrix case with 430W Silent Power
                    17" Benq FP737s LCD monitor
                    HP Officejet Pro K5300 with refillable tanks
                    • SevenOFF
                      Denon AVR-X4000 – Fast red blinking after 2nd relay
                      by SevenOFF
                      Hi everyone,
                      I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
                      According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
                      Here’s what I’ve done so far:
                      • Fully opened and cleaned the unit (a lot of dust inside)
                      • Removed and visually inspected the AMP board → nothing visibly damaged or burned
                      • Testing is done with
                      06-18-2025, 09:54 PM
                    • nobbnobb1
                      Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
                      by nobbnobb1
                      I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
                      https://www.digikey.ca/en/products/d...0D241K/2799098
                      The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
                      06-04-2025, 08:40 AM
                    • gregory112
                      Why put two fuses of the same rating in series? Or am I mistaken?
                      by gregory112
                      This Razer Blade 15 2022 motherboard does not have a schematic. Razer also does not give any schematics or boardviews. Around the GPU VRM circuits I found these two fuses rated for 1.5A (from the letter K).
                      From the PCB trace I can see that the two are connected. These two are not connected directly to ground. I believe therefore they are placed in series. I wonder why is this? Also judging from the size of the PCB trace, this carries 19V power.
                      Thank you in advance...
                      03-18-2025, 12:46 PM
                    • csberti03
                      Asus ROG G513QC liquid damage
                      by csberti03
                      Hi!
                      I have an Asus ROG with some liquid.
                      I already replaced most of the damaged components.
                      But there are some resistors that have OL resistance but i don't have the exact value to replace them.
                      In boardview it carries a signal called VRAM_DGPU_TON.
                      First is 2.2 Ohm 5% (R67218)
                      Second is 499K Ohm 1% (R67217)
                      also R6016 Measures 210k instead of the 130k in boardview.
                      It's part of AC_SHORT_DETECTION circuit.
                      Should I replace that?
                      I have 1 ohm, 3.3 ohm, 100k, 470K resistors.
                      Is it OK to use those...
                      12-18-2024, 12:28 PM
                    • trepachka
                      iPad Air A1475 Boot loops after replacing battery
                      by trepachka
                      This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                      The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                      I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                      11-08-2024, 03:17 PM
