ESD Safe vs Normal Soldering Irons?
  • Deft
    • Sep 2010
    • 55
    Hello all.. I was looking into buying a temp. controlled soldering station before I get started on my first recapping project. Before I started looking into buying a soldering station I didn't even know about irons being ESD-safe or not. The first one I bought was a cheap store brand 22 watt iron and I used it for many projects including soldering a touch screen controller, 4-port USB hub and a bluetooth adapter to my Asus EEE 701 without any issues whatsoever.
    I'm not looking for product recommendations or anything.. I would just like to know if I should stick with ESD safe and why I should do so? Or if I get a regular station is there any precautions I should take? From my experience using my first soldering iron it didn't seem to make any difference to me.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: ESD Safe vs Normal Soldering Irons?
    As long as you touch an earthed object before starting work, no problem using a regular iron.
    A working TV? How boring!
    • Deft
      • Sep 2010
      • 55
      Thanks.. That was the answer I was hoping to hear
      • Deft
        • Sep 2010
        • 55
        Ok, so now I've seen a soldering station that claims it has:
        "Zero Voltage" circuitry eliminates both high voltage spike and magnetic field generation at the tip to prevent unnecessary damaged to electronic components.
        Just curious if this means the same thing as ESD-safe?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          fyi most ungrounded irons are crap.
          i know of a good one if cash is low that is grouned (i use one). the xytronic 258... the only "good" non grounded one i saw was a weller and it was a POS for a weller.
          sigpic
          (Insert witty quote here)
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            It does, just in more fancy terms.
            • larrymoencurly
              • Oct 2004
              • 960
              I think "zero voltage" here refers to the temperature controller switching the AC on or off only when the DC voltage level is exactly zero, so only pure half sinewaves are produced, with no abrupt switching that generates spikes.
              I saw replacement irons for the Hakko 936 soldering station. The black ones were ESD safe; the white ones were not. Both had grounded tips.
                • 31300
                i dont like grounded tips, it assumes the circuit is discharged.
                i connect my iron tips through a 4m7 resistor.
                it limits the current so that static is killed but you can still solder live stuff.
                (not mains)
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  why in the @#%& would you solder a live circuit? i thought common sense said not to do that.
                  welcome to 2010, where common sense is an oxymoron
                  sigpic
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Because the device is a reactor safety issue and the tactical situation doesn't allow shutting down the plant to fix it.
                    Changing out switches in live 400 vdc circuits is fun too.
                    Rubber mats every where.
                    Rubber gloves.
                    Face shield.
                    And a guy holding a rope that's tied around you standing by to yank you out if you take a hit.
                    It's not just a job........
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      well that is different. specific use. but who in the $%&* would have a reactor in their basement? not exactly the kind of thing you buy at walmart...
                      sigpic
                      • Deft
                        • Sep 2010
                        • 55
                        I'm probably not going to solder directly onto a live circuit anytime soon but I did recently find a place to buy a Hakko 936 locally for a reasonable price. Hopefully the next person that Googles "buy Hakko 936 in Toronto" finds this post and realize they can get one at Active Electronic Supplies Depot for $100.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Because a pretty big percentage of the regulars on Badcaps do not do their main work soldering in their mommys basement (no offense meant)
                          -What I mean is that this info is good for many people here, and I'm sure some already do this kind of work...
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Per Hansson, your signature is incredibly appropriate.
                            - Dr Seuss
                              • 31300
                              working on car wiring usually incures soldering live lines.
                              you cant disconnect the battery first because it causes all kinds of shit from losing the electric window safety settings to losing the fuel management fine-tuning.
                              just because it's only 12v doesnt mean you want sparks on your soldering tip!
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                thats why you pull the fuse for the circuit you are working on...
                                sigpic
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Some customers at work even asked for a hard copy when they saw it posted on the LASER machine I was running then
                                    • 31300
                                    what fuse?
                                    i'm installing high current wires from the battery *to* the new fusebox!
