Tips when soldering U6960/TPS62180
  • aed040
    • Nov 2022
    • 13
    • Philippines
    I am trying to fix my macbook.
    Can you give me some tips when replacing the U6960 chip.
    What Hotair temp and fan speed do you use?
    How long do you usually wait before you can remove a chip? Ive been watching repair videos and they can easily remove a chip after a few seconds but I've been heating the part on a test board for almost a minute and it wont budge.
    Does a really good flux help in melting the solder? I am not sure if my amtech flux is fake that is why its taking a long time.
    The flux is also being blown away from the component I want to remove which then leaves it looking dry, does that mean I have a very strong air?
    Which is better smaller or bigger hotair nozzle?
    Sorry If I have a lot of questions, I just want to know what I am doing wrong.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Tips when soldering U6960/TPS62180
    hi it depends from many circumstancies. ill try to explain as much as i can by point:
    1° pcb size matter.. small macbook air absorbe less heat then a imac 27 inch board.
    2° what hot air and how much old is it ?
    3° i have 6-7yr old atten 8586 with hot air nozzle replaced once. i use 390° (screw set to get much hotter air possible) and fan speed around 6-7, but keep in mind that when it was new i was ok to set fair speed to 4 for almost all board
    3° nozzle size depend on component size, pcb size, solder type. on a small macbook air with leaded solder (maybe already reworked) u can use medium (1cm diameter)set 380° and air flow 5; on lead free big pcb i sometimes go with no nozzle, 390° and fan speed to 6-7(remember my hot air is old)
    fan speed should be no more to make resistor get blown away easy (without flux).
    4° flux must be not sticky and very good brand (kingbo or amtech 559)
    all ° are celsius.
    for small bga chip put flux. if pcb is really cold it can teke even up to 120 seconds to remove it.
    set max temperature to make chip lead melt, but not make chip burnt on top.
    ive seen also all that yt video where they are able to remove ic veryt fast, but my hotair has fan and not pump, plus i prefer to not make ic too much hot fast... prefer more time but no damage. ofcourse after 120-180 seconds u should be able to remove it, otherwise or increase air flow or temperature by 10° step increase.
    after chip is removed, for bga i clean wole pcb with solder iron flux and desolder wich first i apply some leade solder , then remove all with desolder wick by adding some more flux. clean all with ipa. apply some new flux when pcb is dry and solder back ic.
    same tecnique when i can add some leaded solder (inductor resistor and so on. it require much less heating time for removing it.
    check also hot air flow on board ... sometimes u heat straight and component starting melt are the one on top or bottom of air flow direction. check that and make some circle on ic , moving it with tweezer very gentle. when chip start move keep heating and after 10 seconds try remove it without making any power...
    hope all that help.
      • Jul 2011
      • 6069
      One thing that might help a lot is to use the correct tip to cover the ic chip and it’s pins and use enough air flow to keep the heating element from burning out the distance from the output of hot air gun also makes a difference as well
      • chth96
        Is it good to use chemistronic flux off es835b for flux remover?
        by chth96
        I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
        Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
        11-17-2023, 07:25 AM
      • estabilito
        Tips geting oxidized when using wick
        by estabilito
        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
        Temperature: 350-365celsius
        station: jbc cd-2bqe
        Wick: edsyn
        flux: warton hf rework jelly
        Do you have any tips?...
        04-12-2025, 11:55 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • Azurain
        Elitebook 840 G5 Bios Chip Soldering Question
        by Azurain
        Hi everyone,
        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
        04-14-2023, 06:58 PM
      • GGEZ
        16IAH7H minor liquid damage around GPU buck. boardiew and schematic included.
        by GGEZ
        Hi. I have a lenovo 16IAH7H (NM-E231) with a small amount of water spilled on the RT8816CGQWGPU buck converter. When powering on, keyboard lights up, fans will spin slowly. CPU and GPU are getting hot. No image. Not via HDMI either.
        Part number is PU4001. The liquid spillage looked minor so I cleaned it up with some alcohol and cleaned ups some crusty joints with solder and flux.
        BoardView and schematic is provided. The buck converter diagram is on PAGE 107.
        I'm inquiring about any troubleshooting tips like probe points to measure and such. I can...
        08-19-2024, 03:18 PM
