MacBook A2251 waterdamage
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone,
    Working on a A2251 that was left out in the rain, and afterwards plugged into power :') Motherboard is a 820-01949
    Anyway, when cleaning up the corroded areas I took off the U3100 (_R) to check for underlying damage since the whole area is trashed, I saw that pad number 111 is completely gone, but I have no idea what it's used for. I can read of the schematic that it's line NC_UPC_R_I2C_ADDR, but what is this line's purpose, and is it required to boot the macbook since we're mainly going for data?
    TL;DR: What is NC_UPC_R_I2C_ADDR, and is it needed to boot the macbook?
    Including both boardview and schematic.
    Thanx in advance!
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Re: MacBook A2251 waterdamage
    After replacing U3100_R, the other 3 ports take 5v 0.25a, and the corresponding port to the CD3217 that I replaced is taking 5V 0a.
    G3H is at 12.23v
    I have no experience with CD3217 machines, so not sure where to take it from here. Anyone have some advice?
    • MICHAEL_2013
      Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
      by MICHAEL_2013
      Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
      Model A2251 EMC 3348. Serial Number: C02G54CZML85
      Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
      I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
      C02G54CZML84 only works up to Monterey.
      C02G54CZML86 doesn't work (I...
      11-20-2025, 11:18 AM
    • MikoMiko
      MacBook Pro A2251 - 820-01949-A not charging
      by MikoMiko
      Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
      03-24-2025, 11:09 AM
    • manymonsteras
      Macbook Pro - A2251 - No power when battery is connected
      by manymonsteras
      I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
      First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
      11-20-2025, 09:42 PM
    • envym
      MacBook Pro 2018 with Activation Lock
      by envym
      Hi everyone!
      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
      06-27-2025, 08:54 AM
    • PITERPENY
      Macbook A2251 no boot
      by PITERPENY
      The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
      01-05-2025, 03:11 PM
