Dell optiplex 3000 micro bios
  • applemackintoshh
    • Nov 2022
    • 10
    • malaysia
    help! please remove absolute enabled ... as you can see on the picture, not clickable "grayout" means absolute is enabled.
    note: no bios password
    issue: absolute is enabled
  • hoaca388
    Badcaps
    • Jan 2022
    • 12333
    Re: Dell optiplex 3000 micro
    Your device still has a second bios chip, find it and post it here, remember to include the sevice tag number.
    • applemackintoshh
      • Nov 2022
      • 10
      • malaysia
      hi, yah i will sir, here is the other bios sir.
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Write your device service tag.
        all donations are welcome,
        • applemackintoshh
          • Nov 2022
          • 10
          • malaysia
          write your device service tag.
          4qksgr3
          • hoaca388
            Badcaps
            • Jan 2022
            • 12333
            4qksgr3
            OptiPlex 3000
            • smallvhin
              • Jul 2015
              • 192
              • philippines
              Master help me to remove password and absolute security lock. more thanks 🙏
              • Arrow16
                • Apr 2022
                • 229
                • Philippines
                optiplex 3000 micro absolute lock pls help to disable
                Her is my 2 bios backup
                BRKSGR3
                • smallvhin
                  • Jul 2015
                  • 192
                  • philippines
                  Master Master help
                  • elkhiyhie
                    • Jun 2020
                    • 35
                    • philippines
                    kindly also help me to remove absolute security, thank you.
                    here is the original file bin..
                    • elkhiyhie
                      • Jun 2020
                      • 35
                      • philippines
                      here is the file
                      • Arrow16
                        • Apr 2022
                        • 229
                        • Philippines
                        here is the file
                        Flash this 32mb file, just put back 16mb bios chips
                        Give feedback
                        • elkhiyhie
                          • Jun 2020
                          • 35
                          • philippines
                          Give feedback
                          yah its working sir, thank you for your help!
                          • jamshidtavana
                            • May 2023
                            • 1
                            • Deutschland
                            Hi everybody,
                            I have the same problem with admin password and I need the bios for OptiPlex 3000 with tag number : 79X1SN3
                            I don't know if you need the complete tag number that is also 79X1SN3-8FC8
                            The second Bios chip is MX77L25650F.
                            Could you please tell me with which programmer can I program the chip?
                            Best regards.
                            • drefo
                              • Mar 2021
                              • 26
                              • France
                              Hello can you help me to remove the password bios thank you
                              OPTIPLEX 3000
                              CFYLTN3-8FC8
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1355
                                • France
                                OPTIPLEX 3000
                                CFYLTN3-8FC8
                                It's good, problem solved with drefo, just clear VSS2 on big chip
                                • catch05
                                  • Jun 2023
                                  • 3
                                  For clarity, did you clear the entire VSS2 body or a specific section. I've attempted to do the same by clearing the entire body but the password lock remained. Thank you.
                                  • catch05
                                    • Jun 2023
                                    • 3
                                    I was hoping to learn and solve this bios admin password lock myself, but I believe it may be better to ask for help. Clearing VSS2 on the 32mb chip did not work. Service tag is 7S6CYS3.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12333
                                      Originally posted by catch05
                                      i was hoping to learn and solve this bios admin password lock myself, but i believe it may be better to ask for help. Clearing vss2 on the 32mb chip did not work. Service tag is 7s6cys3.
                                      1111111
                                      • catch05
                                        • Jun 2023
                                        • 3
                                        1111111
                                        Worked perfectly! Thank you so much for your skills, and with only two bytes changed!
                                        • Altemon Moura
                                          Optiplex 3000 micro
                                          by Altemon Moura
                                          Unfortunately, when removing the chip
                                          (GIGADEVICE 25R256EYIG)
                                          It broke in the hot air.
                                          Will I be able to buy this same model?
                                          (GD25R256EYIG)
                                          "Can I burn the Bios?"
                                          motherboard
                                          DELL Optplex 3000 - 202040-1 D10NK$HA
                                          Optiplex 3000 micro
                                          Service tag: C7CG7T3
                                          SERVICE CODE: 26565563271​
                                          05-20-2025, 06:35 AM
                                          DELL OptiPlex 3070 OptiPlex 3000 i5-9500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 3060 OptiPlex 3000 i5-8500 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3060 boardview and OptiPlex 3060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
