Indesit vented tumble dryer control board dead
  • notallbad
    • Oct 2012
    • 1190
    Anyone able to help diagnose the fault with this board please.
    Hopefully photos are clear enough to give me direction on what readings to take and where.
    All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
    So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
    The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors, caps, relays and transformer.
    Did find a faulty smd diode on the xformer secondary side but still no luck after replacing with a good one from an identical donor board.
  • notallbad
    • Oct 2012
    • 1190
    Re: Indesit vented tumble dryer control board dead
    Wiring connections
      • 31142
      forget the board and check the door switch and thermostatic switch(es) first.
      btw, any excuse to waste money these days, my vented dryer just has a motorised camswitch instead of that microcontroller/relay crap
      • notallbad
        • Oct 2012
        • 1190
        Yh door switch etc all checked. But in any case even with those disconnected the board should still power up when the dial is turned to select the drying duration.
        The door switch only prevents the motor from activating as a safety feature so board should power up still.
          • 31142
          yes, but the thermostatic switches are different, those are a final safety before the heater catches fire.
          those can shut down a lot - maybe even the control board.
          and they do burn up - i had to replace one of mine.
          they are mounted in the airflow to make sure the heater doesnt burn up from a blocked vent or overloaded drum.
          why not check for 5v or 3.3v on the microcontroller?
          • notallbad
            • Oct 2012
            • 1190
            Have already stripped the machine down, thoroughly cleaned it out and tested all ancillaries, as its a vented dryer theres not much to test but everything else is ok.
            On the regulator 1117m3 the voltage appears to be dropping in and out, it appears as though its in a boot loop.
            The microcontrollers on the board are:
            LNK626DG
            SENO12DG
            LM293
            • redwire
              • Dec 2010
              • 3912
              The LNK626 drives the low voltage power supply with T1, it should have a 12VDC output for relay power. This usually gets dropped down to 3.3 or 5V for the MCU by another IC like the '1117.
              Check the input to the '1117 and if unstable (and IC is not hot), it's got at least 4 different makes of electrolytic capacitors, I would check the six. C50 has mains and can bite.
              • notallbad
                • Oct 2012
                • 1190
                So just a quick update on progress.
                I felt that as the Lnk626, Sen012 and Lm293 were 'boot looping' there was another cause preventing start-up so starting looking elsewhere.
                A few components later and its got life back into it (yet to be tested back on the dryer).
                NE555 timer and smd cap
                A couple of transistors
                Couple of smd diodes
                To be honest I think a shorted smd cap took out a couple of diodes, suspect the ne555 was ok but I had some so swapped it out anyway.
                Shall update once fitted back in the machine and tested.
                • notallbad
                  Heat pump tumble dryer regas
                  by notallbad
                  Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                  The dryer currently in question runs on R134a.
                  The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                  I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                  07-16-2023, 01:27 PM
                • Petros_Z
                  candy tumble dryer (evoc 981 at-s) Component 738
                  by Petros_Z
                  Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
                  It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
                  Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
                  01-04-2025, 02:17 AM
                • spleenharvester
                  Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
                  by spleenharvester
                  This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
                  Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
                  Cheers
                  12-16-2024, 03:36 PM
                • tmcw
                  Tumble Dryer - motor start capacitor
                  by tmcw
                  I was looking for a replacement capacitor for a tumble dryer, and I found one on eBay that has the correct values, and even looked similar, but of course, when the capacitor arrived, it didn't look like the cap in the listing picture.
                  I've attached the old (left) and the replacement (right) caps in a picture. The new one has plastic housing, the old one has a metal housing and is bigger. Am I likely to have any issues with this replacement?
                  Thanks....
                  05-09-2022, 09:11 AM
                • Yanleb
                  LG 60PK550 Logic Control Board EBR63450301
                  by Yanleb
                  Hi all, I just want to share the repair of my 60PK550-UA TV set.
                  The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                  But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                  All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                  C57: 3.30V
                  C61:...
                  07-20-2023, 12:38 AM
