Kada 903d hot air machine
  • musanide
    JQUB
    • May 2020
    • 86
    • zambia
    This model has a 15v power supply , and one day i was trying to inject voltage on a laptop motherboard and the next thing I heard was a warning beeper, and the the machine was dead, later I managed to fix the soldering iron and the the power supply sections but my Smd work sections doestn work, so am asking for a schematic diagram if anyone has 1
    • 31140
    Re: Kada 903d hot air machine
    post some pictures please
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      Hi everyone,
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • unimatrix93
      How to stabilize AC voltage to CNC machine
      by unimatrix93
      Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
      I have a CNC machine wired to 3-phase 230V AC.
      It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
      The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
      I contacted the electricity company but they refuse to help me solve this problem.
      So I started to look around for some DIY...
      03-17-2025, 05:52 AM
    • xdever
      820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
      by xdever
      I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
      01-15-2025, 08:44 PM
