HP EliteBook 865 G9 - BIOS issue decrypt
  • haopcxg
    • Jan 2023
    • 21
    • zh
    My HP EliteBook 865 G9 notebook was accidentally encrypted and could not enter the BIOS. It is relatively new. I extracted the data of the front and back memory of the motherboard: 6050A3334301-MB-AX1. I hope someone can help me.
  • volinakis
    • Jan 2021
    • 2790
    • N/A
    Re: HP EliteBook 865 G9 - BIOS issue decrypt
    try. Leave EC intact and write this in Main_Bios (Memory_01).
    it will enter in MPM mode, press F10 and you have a tab under "Main" named " set machine unique data" and you'll find all data on stickers of back of the bottom cover. to exit MPM mode use BCU 4.0 under windows or restart laptop how many times counter shows.
    • haopcxg
      • Jan 2023
      • 21
      • zh
      Ok, I'll do it。
      • haopcxg
        • Jan 2023
        • 21
        • zh
        Several red flags
        • haopcxg
          • Jan 2023
          • 21
          • zh
          The HP screen is very slow after powering on, a few minutes.
          • volinakis
            • Jan 2021
            • 2790
            • N/A
            try clean ME or read again chipset with bios unlocked and post it here. i will try to clean ME for you. Did you set all data for your laptop? do you have any warnings on start up?
            • haopcxg
              • Jan 2023
              • 21
              • zh
              Turn on the black screen, the fan runs wildly, and HP icon and red letter appear after 1 minute. How to clean ME; There is only red ink and no warning when the machine is turned on. It only needs to read the IC content next to the memory, and it still needs 2 IC contents.
              • haopcxg
                • Jan 2023
                • 21
                • zh
                CPU :AMD Ryzen 9 PRO 6000
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12049
                  Several red flags
                  AMD system has no ME region, try this file and feedback
                  • haopcxg
                    • Jan 2023
                    • 21
                    • zh
                    Clear the IC and write the firmware. The computer does not respond when it is turned on. The caps lelock and numlk indicators flash 6 times, and the charging indicator flashes; When the machine is restarted after forced shutdown, the power indicator lights up once, the caps lelock and numlk indicator lights up for a long time, the power indicator lights up twice, and the charging indicator lights up; Then press the start button to cycle.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12049
                      No way, check your procedure again, did you accidentally lose any components around the bios chip?
                      • volinakis
                        • Jan 2021
                        • 2790
                        • N/A
                        since you can enter in bios setup it means you have no password. Load factory defaults (doooh! it is obvious!) and "change admin password" will disappear. Set machine data as I told you, exit MPM mode as I told you and "red ink" will disappear. I see from your photo you didn't set correctly data, Product Name is HP EliteBook 865 G9 Notebook PC, expand "show Advanced..." and don't blur it because ALL DMI are in bios content you post it here.
                        • haopcxg
                          • Jan 2023
                          • 21
                          • zh
                          After rewriting the firmware, you can start the computer. Now the problem is that the HP screen appears for too long, and all the contents are filled in. It is observed that the keyboard light needs to light up twice before the HP screen appears after pressing the power key. The first time is that the caps lock and numlk flash six times, and the second time is that the HP screen appears.
                          • haopcxg
                            • Jan 2023
                            • 21
                            • zh
                            I checked my BIOS file and found that it was the engineering BIOS (U82 Ver. 80.13.00), not the official BIOS (U82 Ver. 01.03.01), so there was a startup exception. I couldn't upgrade the BIOS (prompt: BIOS update did not occur because the system administrator has locked the BIOS version). I uploaded the latest official BIOS
                            • miansh621
                              Banned
                              • May 2022
                              • 133
                              • pakistan
                              feedback
                              • haopcxg
                                • Jan 2023
                                • 21
                                • zh
                                Originally posted by miansh621
                                feedback
                                The fan turns wildly, the screen is black, and the light flashes twice. Two rings for two consecutive times
                                Back up the files that can't be turned on. Is it different from the original file?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12049
                                  HP EliteBook 865 16 inch G9
                                  • haopcxg
                                    • Jan 2023
                                    • 21
                                    • zh
                                    If there is red ink, it may be necessary to rewrite DMI information. What should I do? Can you share your method of changing BIOS? I also want to learn.
                                    • haopcxg
                                      • Jan 2023
                                      • 21
                                      • zh
                                      Serial Number : 5CG2201PGV
                                      Product Number : 6J3E7PC
                                      Description : HP EliteBook 865 G9
                                      IMG_BuildId BID=22WWLHAZ601#SAB2#DAB2
                                      IMG_Desc1 6J6S6b7B7H7M7Q7W7m7s8uaBaEapaqatauawbUbh
                                      IMG_Desc2 d7dXfPgSgujBk8mEn7nWngpDpFpJpnpqprqjqz.B
                                      IMG_Desc3 4
                                      • haopcxg
                                        • Jan 2023
                                        • 21
                                        • zh
                                        Ct:6mbnrx3wyfp0dj
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • wizard13
                                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                          by wizard13
                                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                          • Part Number (P/N): PYU13E-00C00PFR
                                          • Serial Number (S/N): 22028896H
                                          • System Configuration (SC): A1PYU13E1127
                                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                          • Power Input: DC 19V –
                                          02-28-2025, 02:43 AM
                                        • Zonk666
                                          Wht´s the general issue (laptop won´t boot after bios update) with HP BS Series, HP Probook, HP Elitebook ?
                                          by Zonk666
                                          Hello everyone.
                                          In the last 8 months I have manually flashed about 150 HP laptops (BS series, Probook, Elitebook and Zbook). There are about 50 HP laptops, as I have already written before, they have been automatically flashed through windows updates.
                                          Approximately 15% did not start after flashing.
                                          I got the HP Pro, Elite and Zbook to work again with the exception of one using the familiar key combinations or the well known bios flash stick methode.
                                          An Elitebook 840 G6, like many HP notebooks from the BS series (exclusively those with dedicated graphics c...
                                          03-08-2024, 10:49 AM
                                        • lap-top123
                                          Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                          by lap-top123
                                          HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                          Hp Elitebook 850 G8
                                          ProdID 52W98EC#ABD
                                          SN# 5CG1458XQ7
                                          Mac-address #1: 84:14:4D:2C:4B:5B
                                          UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                          Mainboard : 6050A3216701-MB-A01(A1)
                                          08-20-2025, 07:28 AM
