What Exactly Is a Capacitor?
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Here is a very informative article, titled What Exactly Is a Capacitor? It give some history and discusses the common types. The section on ceramic types gives good info on temperature coefficients.
    Here is a technical information document from AVX, describing monolythic ceramic caps and their manufacture.
    PeteS in CA
  • arneson
    • Sep 2005
    • 1267
    Re: What Exactly Is a Capacitor?
    I love the history stuff.
    Like when the first capacitor had gold and was measured in Cubits.
    Maybe one of those Leydon jars could cool my Proc and filter the V supply at the same time.
    Jim
    • chth96
      Is it possible to test small ceramic disc capacitor with analogue meter?
      by chth96
      I read EBOOK of Testing Electronic Component and found that
      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
      Is it really possible to test small ceramic disc capacitor with analogue...
      03-09-2024, 10:03 PM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      Hi everyone,
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • rictechie
      smd ceramic capacitor use in iphones
      by rictechie
      is there a brand of smd ceramic capacitor use in iphones? or they are generics
      07-26-2024, 08:28 PM
    • Prolog
      RTX 3080 FE Identifying capacitor
      by Prolog
      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
      I hope these photos make it clear which component I am referring to:
      (yes, the soldering is a bit botched from removing the blown one, I know)
      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
      12-01-2024, 08:27 PM
    • Sparklingx
      SMD ceramic capacitor capacitance & voltage
      by Sparklingx
      what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
      09-12-2024, 01:04 AM
