Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
Tags: None
Re: Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
This is very similar to a Freon compressor start relay one general rule is if the start capacitor is open or exposed then more than likely it is bad and should be replaced the run capacitor needs to be checked also to make sure that the UF value is correct and not low in value
If everything is good and the motor still not start and runs then either the motor is faulty or the start relay is faulty and should be replaced
Also need to check with a amp clamp on meter that your starting current is only momentary and that your running current does not exceed the current rating on the data plateLast edited by sam_sam_sam; 02-22-2023, 05:40 PM. -
agreed should be able to test each component individually. The start/run caps have to have their rated capacitance and their DC leakage value needs to be low, usually an ohmmeter is sufficient for the latter.
I've heard a lot of techs in the past just use leakage as the sole metric for testing motor capacitors (and the pulse behavior of capacitors at DC). Not sure how accurate this is, but these are metrics that must be sufficient for a working capacitor, and hence motor.Comment
I would check these devices and make sure that they have a good connection and that they work properly you do have to stall the motor to check the over current one the starter one should not stay on for more than a few seconds at the mostComment
by DannyxGood day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... -
by edugimenoHi everyone!
I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
I respected the polarity, positive to cathode of protecting diode
So provided all... -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by sam_sam_samIf you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
One note this unit has been repaired already once because of switching power supply regulator ic chip failure
Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
... - Loading...
- No more items.
