Is there a 8 pin wiring standard for hot air guns?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    A while back I was given a very dead Ya Xun 878D+ rework station, the kind that has a fixed hot air gun and a removable iron with the 5 pin socket.
    It was a fairly straightforward repair and has been working well, but one thing has bugged me was that the hot air gun couldn't be disconnected, so I bought an 8 pin socket and plug set in order to resolve this.
    Yesterday, after stripping it down and cutting the wires, it dawned on me that there is probably a 'standard' as to which wires are connected to which of the 8 pins?
    Obviously, I can wire any wire I want, to any connector and it will work just fine, HOWEVER... who the fuck knows where this unit will be in the future and IF someone else (who doesn't know what I have done) buys a replacement heater gun, then it will likely cause some major damage.
    So... does anyone have any info regarding the 8 pin socket wiring?
    • 31248
    Re: Is there a 8 pin wiring standard for hot air guns?
    they arent standard, and most companies got rid of the connector for safety reasons.
    if you unplug the handpiece you can touch or short the pins with mains on them.
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Aha! Good point, and obvious now I Iook at it.
      Gonna go for it anyway, as the blower will only realistically be disconnected when the station is being moved.
      The wiring order only occurred to me as an afterthought.
      Cheers though!
        HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
        This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
        09-06-2024, 08:30 AM
      • Dannyx
        Wire twisting tool for small wires - ideas ?
        by Dannyx
        Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
        08-23-2020, 06:29 AM
      • ChaosLegionnaire
        correct way to connect bare speaker wires into spring clip terminals?
        by ChaosLegionnaire
        i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
        however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
        i googled...
        10-27-2022, 06:19 AM
        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
        by momaka
        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
        Macron Power Technology Co. LTD.
        Let’s look at the PSU itself.
        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
        06-02-2021, 10:05 PM
      • artvandalai
        Advice on rewiring this stepup transformer?
        by artvandalai
        I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
        01-14-2025, 01:00 AM
