LG OLED 55b7v No video
  • nicke74
    • Mar 2023
    • 16
    • sweden
    Hello all
    My first post here.
    I have a LG OLED 55b7v which suddenly getting problem with no video.
    I have opend the TV up and found that the 24 v is missing on the output from the Power board.
    I have seen alot of posts related to similar problems but my Tv seems to behaves a little bit different
    I can turn the TV on via the remote and the TV starts to consume about 55 W but nothing happend. I can also turn it off via the remote via the remote.
    The Tv stays on when I turn it on. I cant see any red light from the optical output.
    As far as I can can mearure all outputs to the main board seems to be correct.
    Anyone having any ides how to resume the trouble shoooting .
    Isssues with powerboard, mainboard or Tcon card?? I do hope someone having any clue how to solve the problem. Anyone knowing common issues with those boards
  • Diah
    • Feb 2013
    • 6494
    Re: LG OLED 55b7v No video
    plug out the 24V socket from T-CON driver boards side and turn on check the optical come on red or not.
    • nicke74
      • Mar 2023
      • 16
      • sweden
      No differnce when disconecting the 24 V from the Tcon card
      I acctually noticed also that Im only able to turn off the panel via the remote about 30 secound after I started the TV.
      When I wait longer nothing happend and the TV remains turned on. I also notice tat the standby LED does not light anymore
      I suppose I need to meaurse the input to the main board again to verify input
      I suppose this is a indication of problem in the main board
      • Diah
        • Feb 2013
        • 6494
        when you disconnect the 24V socket from T-CON side... you need to measure the 24V on power boards if it exist or not... if not you need first to take the power boards out and test it as stand alone to be sure it supply all needed voltage.
        • nicke74
          • Mar 2023
          • 16
          • sweden
          Hmm, I erformed som measurements on the board but do not know what the correct values should be and if it concludes anything related to the problem.
          In operating mode:
          DPC = 0V
          ACD = 3,5 V
          PWR _ON = 3,5 V
          12 VM = 12 V
          20 VS = 20 V
          DRV_on = 0,07 V
          In standby
          DPC = 0V
          ACD = 0 V
          PWR _ON = 0 V
          12 VM = 7,6 V
          20 VS = 0 V
          DRV_on = 0 V
          My feeling is that the problem is related to the DRV_on signal which does not turn on the 24 V.
          Does this indicate anything which part to replace?
          What can I do to narrow this down more to replace the correct part or fixing the board?
          • Diah
            • Feb 2013
            • 6494
            its okay... only you dont have DRV_ON which are responsible to turn on the 24V line.
            so if you want to check this 24V. you need just plug out the cable ( single wire ) from the socket 201 of DRV_ON .. and feed the pin of DRV_ON 3.5 V from PWR_ON ( 3.5V ) then turn on if the line 24V okay... it will exist.. and the screen will turn on too .... in case the screen had issue for example you can see it too.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4515
              • Italy - Milan
              You have probably a bad standby software, must check for 25Q eprom and its dump
              • Diah
                • Feb 2013
                • 6494
                what standby software.... from where you got this name..... his tv turn on and there 3.5V PWR_ON. learn please before you give wrong advice.
                his issue related to MICOM. cut off DRV_ON. this can be bad panel or bad MB. if he disconnect the LVDS both... and the 24V come back then bad panel.... but some OLED can be repaired ( self test repair) if they got the 12 / 24V.
                • nicke74
                  • Mar 2023
                  • 16
                  • sweden
                  When looping the 3,5 V from pwr_on to drv_on I got 24V from the powerboard so quite sure the powerboard is ok.
                  I noticed that I do nt have any power to the Optimal output or the USB connectors and no power to the standby led either so I suppose the issue is related to a bad main board.
                  Or could the T-con board be involved anyway in the problem?
                  • Diah
                    • Feb 2013
                    • 6494
                    you have issue at 5V line on MB which it go to front LED wifi / BT. you need to check for short first at those module or terminated them one by one from system. then check.....
                    BTW i wrote before... disconnect the both LVDS and check
                    • nicke74
                      • Mar 2023
                      • 16
                      • sweden
                      I can add that the panel was replaced by LG due to burnt in issues just two year ago so it is a quite new panel. Ofcourse it could be broken .
                      Now I also tried to disconnect all cables between the T-con board and my mainboard and still no power to usb or optical output..
                      Is t possible to reset the main board sw in some way incase it went into some bad state?
                      • Diah
                        • Feb 2013
                        • 6494
                        yes in case it response on IR signal from outside.... send IN_STOP command with IR DIY or mobile with IR and follow it with code 0413 it should go to STB plug iut from wall 1 minute then turn it on
                        • lotas
                          • Jan 2016
                          • 4802
                          • Russia
                          Service Manual
                          • nicke74
                            • Mar 2023
                            • 16
                            • sweden
                            atleast it respond to power on / off via the remote.
                            Hmm sorry Im a real rookie when it come to TV repair. Could you advise me what I need.
                            I have some old mobiles which I think support IR, Can I download an app doing the trick
                            Sorry for my beginner questions
                            • Diah
                              • Feb 2013
                              • 6494
                              try this from my old post
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4515
                                • Italy - Milan
                                Diahrrea don't break my balls i know what i wrote, i have to learn nothing by you, i confirm my diagnosis, i've seen now the mb photo, there is probably a standby mpu near switch SW300 , so no 25Q chip, that it must be rewritten, how? You need a programmer that manage it, if not mb replacement, bye
                                • nicke74
                                  • Mar 2023
                                  • 16
                                  • sweden
                                  Hmm, I have performed some measurments . It does not seem to be any shortcut to ground , atleast nothing I found but still no 5V power on the board
                                  I have verified bot 12v and 20 v incoming on the board.
                                  Anymore advise what to check or do I need a new mothercard?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4515
                                    • Italy - Milan
                                    can you program??
                                    • nicke74
                                      • Mar 2023
                                      • 16
                                      • sweden
                                      slightly but I do not think I manage on this level..
                                      Do you know anyone which have the knowledge...
                                      • Diah
                                        • Feb 2013
                                        • 6494
                                        disconnect socket P4000 on the MB.. and plug it in... you need to follow all part with FL name.. measure from both side with reference to TV chassis
                                        any strange reading marked it on photo to the part section and upload here.
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
