MBP A1502 820_3476A S0 Enable issues (total beginner)
  • rodgsilva
    • Jan 2023
    • 11
    • Brasil
    Hello, just a quick disclaimer... I'm a total beginner at logic board repair, just got my hot air station few weeks ago, so forgive if I'm missing something really obvious here.
    I have a A1502 board here (820_3476A) that show green than orange light on the charger and fan spin, but no chime or image. (tried all the key combos resets)
    No sign of liquid damage, only some minor corrosion on a couple of 201 resistors the I already replaced.
    Seems like all the main power rails are present but there're issues with the S0 1.05v enables.
    I took the following measures:
    P1V05S0_EN - 3.35V
    P3V3S0_EN - 3.3V
    P1V5S0_EN - 3.35V
    P5VSO_EN - 3.35V
    I'm don't know what could cause the higher voltages on the 1v lines.
    The other area that I believe could be related and also have some weird values is the U7600
    Here's some readings:
    IN
    Pin - Name - voltage read
    12 - V5IN - 5.16v
    2 - PP1V05_S0 - 1.04V
    17 - P1V05_S3 - 0V
    16 - P1V05_S0 - 3.35V
    6 - VREF - 1.8V
    8 - REFIN -1.05V
    19 - MODE - 0V
    18 - TRIP - 0.16V
    OUT
    15 - VBST - 6.16V
    14 - DRVH - 1.36V
    13 - SW - 1.05V
    11 - DRVL - 3.5V
    20 - PGOOD - 3.35V
    9 - VFFQSNS - 1.05V
    5 - VTTREF - 0.52V
    Well, that's all the data I gather so far, unfortunately I don't have a known good board or even donors to take as reference, also don't have a power supply yet so I can't tell how much current is taking.
    I would appreciate any input for what I could look or try to replace.
    This is just a fun learning experiment for me so no pressure if I make worse but I would be very glad if I could fix.
  • reformatt
    • Feb 2020
    • 1491
    Re: MBP A1502 820_3476A S0 Enable issues (total beginner)
    So you have fan spin? Check voltages on L7630 and L7310. Be extremely careful probing around the +1.05V converter while it's on as that's a great way to kill a PCH. Logic levels for enables are supposed to be 3.3V BTW.
    If you are getting Vcore, then it's something beyond G3 to S0 state.
    • guruji
      • Oct 2012
      • 122
      • India
      checlk load switches they are tiny 8pin ball chip like glass top they are the cause.3.3_s5 to 3.3_s0 5v_s5 to S0 and so on for other voltages.
      • rodgsilva
        • Jan 2023
        • 11
        • Brasil
        Hi thanks for the input.
        Yes I do have fan spin and Vcore voltages.
        L7630 = 1.05v
        L7310 = 1.7v
        So if the enables are correct than I'm not sure what I could check next...
        The only "glass like 8 pin ball chip" I could find was u2940
        And I have the following...
        Pins 1 2 3 4 5 and 6 = 0.9v
        Pin 8 = 3.3v
        • reformatt
          • Feb 2020
          • 1491
          He's referring to the switches on Pg60 of the schematic. Like U8030 for example (3.3V S0 switch). Often with these boards its some kind of shorted cap on switched power rail.
          I normally go through the output of each one and check resistance to ground (with power off of course). If you have fan spin, then it's easy to check the output of each one for voltage.
          A very close examination of the board under a microscope usually presents some kind of corrosion somewhere. It can be quite minor too. Had an insect die on top of a cap once on one of these boards, and the cap went short as a result.
          • rodgsilva
            • Jan 2023
            • 11
            • Brasil
            Ah got it, thanks for the clarification.
            I just checked the switches and they seem to be fine.
            I was able to get a working board of the exact same model so now It makes a lot easier since I take references. With that said I guess I found at least part of the problem...
            SPI U6100 (Bios)
            On the good board I have:
            Pin 2 - SPI_MLB_MISO = activity from 0 to 3.3v
            Pin 5 - SPI_MLB_CLK = from 0 to 20v (maybe 0.40v)
            Pin 6 - SPI_MLB_MOSI = from 0 to 20v (maybe 0.40v)
            Dead board:
            Pin 2 - SPI_MLB_MISO = Static 3.3v
            Pin 5 - SPI_MLB_CLK = 0v
            Pin 6 - SPI_MLB_MOSI = 0v
            All the other pins are fixed at 3.3v on both boards.
            No shorts and the resistors around the area seem the match values with the good board.
            I guess this narrow down to bad SPI chip or PCH right?
            There's any other thing I could do to try isolate the culprit?
            In any case reprograming the BIOS chip or BGA work for the CPU is way beyond my league at the moment.
            So after all the correct term would be "brain dead board", since I've learned that all the Enables were just fine
            • reformatt
              • Feb 2020
              • 1491
              For a bad PCH, check resistance to ground on L7630. The value will vary downwards when the CPU is hot, so check it at room temperature. About 150 ohms or so on some boards I have here. Anything under 50 ohms here would be suspect.
              First thing to try would be a donor BIOS. You can transfer U6100 from the other board to test, bear in mind the boot process will be slower due to a dirty ME. But it's useful to at least see if the board boots. I also use a USB-C power meter connected to 85W brick charger, and a USB-C to Magsafe 2 adaptor to check current. This can reveal a lot of what a board is doing once you have a bit more experience.
              Check the Repair wiki for this board for some pointers. You can also use this to troubleshoot beyond S0 state
              https://logi.wiki/index.php/Bootup_Signal_Order
              Again, look really closely at the board for corrosion. Macbook boards have plenty of unprotected copper test points, any that are discoloured can often be found to be open circuit when you scratch at them.
              • rodgsilva
                • Jan 2023
                • 11
                • Brasil
                I'll check the resistance later today and report back.
                I got confess I'm a little afraid with the idea of removing the BIOS from the good board and end up with two bricked A1502 haha So I guess I'll try to find another donor first.
                I already got the USB-C power meter to deal with newer models but I did not know i could use with an adapter to check current on the magsafe, I'll try to find thanks for the info.
                I don't have a proper microscope but my setup its pretty good for close inspection, with a Sony A7 camera combined with macro lens and a HDMI out to a 20" monitor.
                So the board its pretty good looking overall it was just "dusty", however I did find a ugly looking 201 resistor next to the Bios and I replaced already, so this could also indicate that the SPI chip got corrupted or just dead I guess.
                • rodgsilva
                  • Jan 2023
                  • 11
                  • Brasil
                  Just checked and I have 153ohms from L7630to ground, so pretty close to your reference.
                  • BC_TechForum_drb
                    Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                    by BC_TechForum_drb
                    Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                    Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                    Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                    2/ Figure 1 Gfx-D500-B Front Facing
                    3/ Figure 2 +5v supply (zoom-in)
                    Intro:
                    While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                    12-07-2023, 09:55 PM
                  • AlexVG
                    Macbook A1502 SMC replaced. Can I use SMC A1466? Do I need SPI clean ME?
                    by AlexVG
                    Good evening.
                    I replaced SMC on Macbook A1502.
                    I have had SMC from A1466 only. It's the same but obviously has different program.
                    Is it enough to clean SPI with
                    https://www.badcaps.net/forum/troubl...-bios?t=100913
                    and change SN?
                    Thank you.
                    08-16-2024, 02:12 PM
                  • Talonts
                    Dell Latitude 7290 enable touchscreen entry in BIOS?
                    by Talonts
                    For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
                    The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
                    I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
                    06-24-2025, 11:27 PM
                  • gbuniva
                    MacBook A1502 (820-3476-A) Repair case with solution
                    by gbuniva
                    Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
                    The computer arrived dead, when connected to Magsafe no lights on the connector.
                    Here some Measures at some testpoints on de LB 820-3476-A :
                    PP3V42_G3H 1.7V
                    PPBUS_G3H = 0V
                    PPVBAT_G3H_CHGR_RE = 0V
                    PP3V3_S5 = 0V
                    PP5V_S4 = 0V
                    P5V1_SW = 5.5V
                    PP3V3_S0SW_SSD =0V
                    PP3V3_S0SW_SSD_FET =0V
                    PPDCIN_G3H_INRUSH = 16.10V
                    PPDCIN_G3H_CHGR = 16.10V
                    PP5V_S5 - 0v
                    PP3V3_S5 - 0v
                    PP3V3_SUS - 0V
                    PM_RSMRST_L - 0v...
                    04-09-2025, 07:11 PM
                  • tccyo22
                    Xbox One Original missing 12v enable signal
                    by tccyo22
                    Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                    Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                    08-14-2023, 06:06 AM
