HP Envy 17M-ch0xxx (455.0MK01.0002) BIOS
  • bombob
    • Aug 2021
    • 7
    • usa
    Issues started after bios update with power button blinking with no power on.Had to unscrew battery and detach it for it to boot with bad bios checksum message.Tried several Bios recovery using USB,showed it being flashed and booted fine but it would go back to same behavior as soon as I access the bios(Wont reboot). Would work fine for several days too as long as I don't go into the bios
    shut it down yesterday and now it will only show power led but no activity,doesn't boot to Bios USB recovery anymore. BIOS Chip is MX77L12850F it was on version F.14
    I need a way to backup the corrupted bios and flash a working image. Already ordered a T48(TL866-3G) programmer but I am not sure if it can save it
    • 21971
    Re: HP Envy 17M-ch0xxx (455.0MK01.0002) BIOS
    When you get the programmer make a backup,even if its corrupt and post it here.Post the laptop serial number as well.
    • bombob
      • Aug 2021
      • 7
      • usa
      Awesome. Thanks, I will.
      • bombob
        • Aug 2021
        • 7
        • usa
        The programmer gets delivered later today. upon reading the support list, it looks like my bios chip is not supported but I read on a post here https://www.badcaps.net/forum/showth...1216206&nojs=1 that mx77l12850f is interchangeable with W25R128JVSIQ (same voltage,capacity and pinout). Should I dump it using this chip profile? do you think it will work?
        • bombob
          • Aug 2021
          • 7
          • usa
          Here is the dump for the laptop
          Serial: 8CG12640QC
          Win11 21H2
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            Serial: 8CG12640QC
            Win11 21H2
            Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
            all donations are welcome,
            • bombob
              • Aug 2021
              • 7
              • usa
              Great I will let you know thanks
              • bombob
                • Aug 2021
                • 7
                • usa
                I fear its a board issue. Flashed ,verified. Dumped, compared.Still no go. tried powering without bios chip and its the same. My guess is that the Nuvoton microcontroller is bad
                • Kenzi
                  Cannot modify HP Envy 15 ep-00008na BIOS
                  by Kenzi
                  Hi everyone,
                  I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                  I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                  11-09-2023, 05:22 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • sssssssssssssss
                  Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                  by sssssssssssssss
                  I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                  Symptoms:
                  • Laptop powers on but no display at all (completely black screen)
                  • Caps Lock blinks twice with a pause, then repeats continuously
                  • F12 LED stays on permanently
                  • No POST, no boot sequence, nothing on screen
                  Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                  What I've tried:
                  • Hardware reset (battery removal, power
                  09-04-2025, 06:45 AM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • The_Memory_Guy
                  Dell T7820 stuck in Bios Recovery Mode
                  by The_Memory_Guy
                  HI,
                  I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                  What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                  All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                  https://www.dell.com/support/product...BUT090/drivers
                  Some...
                  07-07-2025, 06:52 AM
