Xbox 360 S - power chime, then powers off
  • survivalbloke
    • Aug 2021
    • 302
    I have a 360 S here. I have a solid amber light on the PSU. If I press the power button, I get a chime and fan spins up, PSU LED turns green, then the unit immediately powers down.
    What should be first steps?
    video
  • nick122
    • Jul 2016
    • 110
    • Slovenia
    Re: Xbox 360 S - power chime, then powers off
    I'm a little late, but I think I can help. Usually when a slim board immediately powers on and then right back off, it has something to do with the main 12V rail PWRGD signal. For some reason, the southbridge isn't detecting the 12V PWRGD signal. The PWRGD signal could be missing because of a short on the main 12V rail, a bad HANA which doesn't generates the PWRGD signal when it should, or a bad southbridge that doesn't recognize the signal.
    Keep in mind that it can also be caused by a bad power supply, although that doesn't seem likely, given the fact that the fan spins for a brief second, suggesting there is 12v getting in. I'd start by trying a different PSU and go from there.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Unspun01
      XBOX One no power, random.
      by Unspun01
      XBOX One original, not XBOX One S. Has problems turning on.
      Power supply is good. Touch panel is good. Both work in another xbox.
      HDMI and USB ports are fine.
      The last time this XBOX turned on, it had an ERROR 102 so I know it can turn on, and I know it may have a hard drive issue. But the power issue is driving me nuts.
      When power supply is plugged into xbox, there is no response from the XBOX. Cannot power on, or eject. No lights. no sounds, not even a fan twitch. Power supply LED remains orange.
      Voltages are measured all over...
      03-24-2020, 01:19 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
