Need BIOS MSI GS66 Stealth 10UG please
  • fesen
    • Apr 2023
    • 12
    • Rus
    I used the Amidewinx64 program and changed the bios manufacturer and product name values, after the changes the bios closed and did not change the values, now the msi dragon center does not recognize the motherboard.
    Soldered the bios chip.
    Please give bios dump for MSI GS66 STEALTH 10UG MS-16V3.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Need BIOS MSI GS66 Stealth 10UG please
    Originally posted by Vesko356
    If you don't know - usually MSI put the bios update at their support page as a ready to use file.
    https://www.msi.com/Laptop/GS66-Stealth-10UG/support
    Become a Badcaps supporter
    Thanks to all supporters.​
    • fesen
      • Apr 2023
      • 12
      • Rus
      This does not change the product name in the bios itself.
      Thanks for trying to help.
      After 1 change, the bios was blocked. Now writes a data change error.
      • fesen
        • Apr 2023
        • 12
        • Rus
        I took out the bios chip and took a dump of what is there through the CH341 programmer.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          I can't understand what you mean but all you have to do is download the archive and the bios is inside that archive.
          Don't send replies one after another, use EDIT button.
          • fesen
            • Apr 2023
            • 12
            • Rus
            Renamed to .bin The programmer writes - the file size is larger than the chip size.
            I sent the problem in the image. Instead of correct values - letters / numbers.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              In this case obviously the chip you are trying to program with the downloaded file is not the right one. What are the chip markings?
              Btw I just looked at the attached file in your first post and it's not the bios dump, you dumped the wrong chip. So find the right one at the board. must be 16MB SPI, W25Q128xxxx or something similar as a marking on it.
              • fesen
                • Apr 2023
                • 12
                • Rus
                i got dump from this winbond 25Q80DVSIG
                I replaced the bios chip in the laptop and it still turns on normally. Is it possible that the chip was damaged?
                UPD.
                I still managed to flash the bios!
                Thank you very much, I'm flashing a chip for the first time)
                It was necessary to erase the previous data.
                BUT the problem still remains, the product name and manufacterer are still incorrect.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Yep, obviously. And as I said it's not the right one.
                  What chip exactly you are talking about?
                  I didn't understand anything again!
                  As long as it turns on normally, what is the problem?
                  You want it to not turn on at all, right? Just joking.
                  Try to ask the questions a little more comprehensibly and meaningfully, because I can't help otherwise.
                  Edit:
                  UPD.
                  Are you talking about the DMI data?
                  If yes - the DMI data should be copied (transferred) from the factory bios to the new virgin bios (downloaded from the MSI). Download the dump from your old bios here, along with the serial number from the label at the back cover.
                  • fesen
                    • Apr 2023
                    • 12
                    • Rus
                    Edit:
                    Initially, I used a spoofer to change the hwid.
                    After applying ALL that could only change, the bios data was changed to letters / numbers.
                    Now, when flashing the BIOS chip, the original BIOS taken from msi.com writes an error about the size of the file, and as I understand it, even if it writes, it does not completely write the BIOS, I erase the chip before writing, I remove the chip lock completely in the programmer.
                    My opinion is that the chip is either blocked or burned out, as I understand it, i need to buy a new chip. 25q80dv.
                    Please tell me your opinion on this matter.
                    Also, my laptop turns on, enters Windows and enters the BIOS with a missing 25q80dv chip ...
                    the product name is incorrect on the image in bios without bios chip.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      I don't know what you did or what programs you used to mess up the things,
                      Apparently we are on different pages, because after everything I explained I see from the image that you are trying to write the downloaded dump which is 16MB on a chip which is 1MB. It will never happen.
                      W25Q128XXXXX is 128 Megabits flash memory chip = 128 Megabits (Mb) = 16,384 KiloBytes (KB)
                      So the bios bin file for your machine must be 16,384 KB.
                      W25Q80xxxx: 1Mb = 1,024 KiloBytes (KB) (1048576Bytes)
                      https://datasheetspdf.com/pdf-file/1...d/25Q80DVSIG/1
                      E16V3IMS.111 = 16,384 KiloBytes > 1,024 KiloBytes
                      • fesen
                        • Apr 2023
                        • 12
                        • Rus
                        Where did you find the 1mb bios file?
                        The BIOS file from here https://download.msi.com/bos_exe/nb/E16V3IMS.111.zip weighs 16MB
                        dump I sent 1mb - the very first message, you said the dump is wrong.
                        The dmi values need to be changed to get the laptop back to normal.
                        But I tried many ways - there was always a DMI write error.
                        That's why I decided to flash the BIOS.
                        I flashed the BIOS from under the BIOS - it did not help to return the original name of the laptop and flashed firmware EC.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          I didn't find it, you uploaded it.
                          Again, slowly, for the LAST time: your bios is 16Mb, E16V3IMS.111 is your virgin bios from MSI, you must find the 16Mb chip at the board, you have to take the dump from it to extract the DMI information and to transfer DMI to E16V3IMS.111, than to program back the dump to the chip.
                          Read all my replies carefully again.
                          1Mb file you've uploaded is not your bios, and the 25Q80DVSIG is not your bios chip.
                          • fesen
                            • Apr 2023
                            • 12
                            • Rus
                            Ok, I think I'm starting to understand. I need to find a microchip with a capacity of 16 mb, right?
                            Thanks, I found the bios diagram. As soon as I do everything, I will write.
                            • fesen
                              • Apr 2023
                              • 12
                              • Rus
                              I decided to take the laptop to the msi service center, because BIOS firmware does not solve anything, SMBIOS is most likely blocked by the developer.
                              Thanks for trying to help. As soon as they fix everything, if they say what the reason is, I will write.
                              • fesen
                                • Apr 2023
                                • 12
                                • Rus
                                Hello, i find bios chip =)
                                Now the only problem is setting the correct DMI values.
                                I restored one GS65 laptop (I also used the amidewin program and the BIOS was blocked, I removed one dot (which I set for the experiment) and the BIOS was restored).
                                In the gs66 laptop, all values changed by another program - therefore I don’t know which value is responsible for what.
                                If it doesn't make it difficult - please indicate what data should be, if possible - please send a bios dump.
                                004321f0 - dmi adress in hex editor.
                                I edit dmi, but MSI Dragon Center not started...
                                • fesen
                                  • Apr 2023
                                  • 12
                                  • Rus
                                  I did it!
                                  After changing all DMIs to stock with HxD editor in dump bios from chip, I flashed the EC Firmware from the MSI website, then flashed the BIOS through the BIOS.
                                  Reinstalled Windows and everything worked as it should!)
                                  Thanks to everyone who helped and followed the topic!
                                  From equipment programmer: CH341A, soldering iron TS-80, solder paste 180C, wick CP-2515.
                                  After flashing the BIOS chip, the laptop reboots itself 5 times - this is normal, leave it, most likely it processes the BIOS firmware!
                                  Good luck!)
                                    MSI Gaming GS66 10UG-480ES Stealth Notebook GS Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GS66 10UG-480ES Stealth Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 10UG-480ES Stealth boardview and GS66 10UG-480ES Stealth schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 02:50 AM
                                    MSI Gaming GS66 10UG-482PL Stealth Notebook GS Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GS66 10UG-482PL Stealth Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 10UG-482PL Stealth boardview and GS66 10UG-482PL Stealth schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 01:30 AM
                                    MSI Gaming GS66 10UG-011UK Stealth Notebook GS Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GS66 10UG-011UK Stealth Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 10UG-011UK Stealth boardview and GS66 10UG-011UK Stealth schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 11:20 PM
                                    MSI Gaming GS66 10UG-035ES Stealth Notebook GS Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GS66 10UG-035ES Stealth Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 10UG-035ES Stealth boardview and GS66 10UG-035ES Stealth schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    MSI Gaming GS66 10UG-044AU Stealth Notebook GS Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GS66 10UG-044AU Stealth Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS66 10UG-044AU Stealth boardview and GS66 10UG-044AU Stealth schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
