KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
  • TrueSword88
    • May 2022
    • 7
    Hi All
    I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
    I've reset the unit to factory default & rerun the initial setup but no change.
    IF I choose any other mode, example: Standard, flickering disappears.
    I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
    I've taken the unit apart, cleaned all connectors, re-inserted flex leads - issue still exists.
    I've attached images & a video sample of the issue. I'm thinking it maybe a fw issue but unsure at this stage,
    Any suggestions for further analysis?
  • TrueSword88
    • May 2022
    • 7
    Re: KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
    **BUMP**
    Anyone come across this problem?
    • ducky29
      • Dec 2015
      • 369
      • Europe
      If the picture dosen't show any artifacts like image jumping up down, or different colors. If it looks like only the background flickers then its probably dying leds. The video that you provided is very short but im kinda confident that its a dying led.
      • TrueSword88
        • May 2022
        • 7
        **UPDATE**
        Okay - I've attached a video to demonstrate the effect I'm getting...
        It seems this issue is not limited to 'energy saving' mode. The 'flickering' effect, takes precedence when altering the back-light setting to around 70-71%.
        It just so happens that when choosing 'energy saving' mode, this mode by default rests on 70% but the effect also evident in other modes when varying the back-light to around 71%. At this level, the flickering starts however, choosing another setting, it seems fine.
        Not sure what it could be.
        Could it be a 'dying LED' as ducky29 suggests?
        • TrueSword88
          • May 2022
          • 7
          **Another Nudge**
          Anyone with any further ideas?
          My testing shows that this flickering (as per the video), is only present IF I set the back-light anywhere between 68-71%.
          Any other setting above 71% or below 68% seems fine, no flicker, can watch for hours with perfect picture.
          • cjard
            Dell U27HM flickering/quarter image/black with smeared colors
            by cjard
            Hi all
            Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
            I do have two of these monitors so a compare/swap...
            09-13-2022, 07:12 AM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
            HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) EliteDesk 705 PRO A6-8500B Specification for Upgrade or Repair
            This specification for the HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) boardview and EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
            09-12-2024, 03:36 PM
            HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) EliteDesk 705 PRO A8-8600B Specification for Upgrade or Repair
            HP EliteDesk EliteDesk 705 G2 Small Form Factor PC (ENERGY STAR) EliteDesk 700 PRO A4-8350B Specification for Upgrade or Repair
            This specification for the HP EliteDesk EliteDesk 705 G2 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 705 G2 Small Form Factor PC (ENERGY STAR) boardview and EliteDesk EliteDesk 705 G2 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
