BY-3200 shorted IC controller
  • rattale
    • Nov 2015
    • 28
    • morocco
    I bought this tool as scrap while trying it I found that the magsafe1/2 work well but the type C cable did not by opening the box I found a short in the controller circuit but no name on it .
    I hope someone can guide me to replace this circuit, it is a QFN28 4x4 IC.
    THX.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: BY-3200 shorted IC controller
    It would be better , If you put clear high resolution pictures of the board , at least so , we can identify ground , Vcin , Vc out , etc .. and then compare the component to its destination or equivalent .
    • kamarulhasan
      • Apr 2013
      • 2
      • india
      in number is SW3518S
      • rattale
        • Nov 2015
        • 28
        • morocco
        thank you
        • OOF DIO
          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
          by OOF DIO
          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
          (Had 3 problems, now just 1)
          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
          04-19-2025, 05:03 PM
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • master3112
          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
          by master3112
          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
          10-29-2024, 09:32 PM
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • BalkanBoy
          Dead Razer Blade 14 2022, shorted CPU?
          by BalkanBoy
          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
          I removed coil and injected 0.7V, it draw around...
          09-27-2024, 12:44 PM
