CFI-1115A and CFI-1002A Needed? Or any altyernative that can work?
  • aktinson
    PS Lover
    • May 2023
    • 18
    • Bulgaria
    Hey fellow Redditors,
    Hoping you're all well. I've got a bit of a situation with my PS5 Digital - it's acting like it's forgotten its sole purpose, won't power up at all. Silence is all I get when I poke the power button - no beeps, zilch, nada, even with some enthusiastic button mashing.
    I've done a bit of Sherlocking with my multimeter. All voltages are checking out as they should - PSU's good, I'm getting 5v and 3.3v. Checked in diode mode for any shorts, came up empty there. Even broke out my thermal camera, but no luck spotting any faults. Here's the catch though - when I hit the power button, I'm not seeing the 1v "switch on" line on the left side of the mobo near the Dialog IC.
    I've tried all the fixes I could find, even dug into the depths of GBAtemp and other forums, but nothing's worked so far. On a side note, came across thread #1166746 to fix ps5 not powering up issues on Badcaps with dump CFI-1015, not sure if that's related to my issue.
    Now, I'm shooting in the dark here, but if anyone's got dumps for CFI-1115A and CFI-1002A, I could seriously use them. Maybe they'll help get my PS5 out of its coma.
    Appreciate any pointers, advice, or the aforementioned dumps. Thanks in advance, folks!
    • 31131
    Re: CFI-1115A and CFI-1002A Needed? Or any altyernative that can work?
    this guys video's may give you some ideas - he fixes a lot and is very good at explaining what he's doing.
    https://www.youtube.com/c/TheCod3r/videos
    • aktinson
      PS Lover
      • May 2023
      • 18
      • Bulgaria
      Yes, i know and follow the channel but still unable to figure it out. I need help regarding the dump too
      • aktinson
        PS Lover
        • May 2023
        • 18
        • Bulgaria
        So, guys i fixed it and it's pretty weird. i really think this solution has worked for me only but still sharing as it might be helpfull to anyone else
        After doing some more research, I found a solution that worked for me. I was able to fix the problem by reflowing the BQ24193 power management IC. This chip controls the power input and charging process of the PS5.
        I followed a video tutorial on YouTube, which helped me understand the process and successfully reflow the chip. After reassembling my PS5, it still didn't power up.
        I tried all the fixes I could find, but unfortunately my PS5 still wouldn't turn on. I searched multiple blogs and applied multiple solutions, from checking cables to wall sockets to updates, but nothing worked. However, I came across a pretty weird solution on one blog that might have worked for someone, and surprisingly it worked for me as well. The solution was to insert a disk into the PS5, which could automatically turn on the PS5.
        To do this, I plugged in the power cable into my PS5 and slowly inserted a disk into the Standard Edition PS5 while pushing it slowly. This caused my console to turn on automatically. Then, I pulled out the disk from the console, and the issue was solved.
        I know this might sound like a weird solution, but it worked for me, and I hope it could help someone else facing a similar issue.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8283
          That’s weird… how did the console get into this bad state anyway?
          • aktinson
            PS Lover
            • May 2023
            • 18
            • Bulgaria
            Exactly. it is weird and definitely very frustrating.
            • hollox123
              ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
              by hollox123
              Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
              1. Laptop keyboard doesn't work
              2. The backlight on the laptop keyboard doesn't work
              3. The x2 side LEDs (red) on the laptop don't work
              The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
              I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
              But I am strongly aiming that it is somehow a BIOS-related problem,...
              05-11-2025, 08:05 AM
            • resistor83
              lenovo 330s-15ikb, led num lock key always on and numbers don't work
              by resistor83
              hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
              I tried updating the bios but the problem remains
              https://s...
              05-29-2025, 08:06 AM
            • re-atari
              Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
              by re-atari
              Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
              Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
              02-03-2025, 06:49 PM
              DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
              by sam_sam_sam
              I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
              If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
              One —>the LEDs might be bad
              Two —> the buck converter or regular might be bad
              Three —> the controller might not...
              08-08-2023, 05:12 PM
            • Rhaverz
              My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
              by Rhaverz
              Good afternoon friends
              I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
              I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
              I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
              03-30-2023, 03:56 PM
