I need unlock BIOS AMI Dfi-Hd100-H81
  • Metaspace
    • May 2023
    • 3
    • uk
    Hi, I would like to unlock this Dfi-Hd100-H81 motherboard. It is a LGA 1150 mini itx motherboard, there is not much info to be found on the web about this board. The problem is that the bios has no CPU voltage settings, and I would really like to under volt it to save on power. Are there any BIOS mod or a way to unlock the voltage settings, maybe a hidden menu? I will be using it as a pfSense firewall, so the lower, the better.
    If you see any other settings that could be useful add them too if possible, I hope it is. Thanks!
    Bios page link
    http://www.dfi-itox.com/pages/support/mbd/showhd100.htm ( bios name- HD100_071614.zip (3544KB)
  • Metaspace
    • May 2023
    • 3
    • uk
    Re: I need unlock BIOS AMI Dfi-Hd100-H81
    Sorry there is no bios.zip link to download, not sure how to add it.
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • throwaway327
      Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
      by throwaway327
      ASUS ROG Ally X - (Handheld Gaming PC)
      Model No: RC72LA
      Serial No: SBNVKD001014459
      Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
      I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
      06-18-2025, 05:52 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • cr4zychriss
      [Problem/ Request] Bricked TongFang GK7MRFR BIOS
      by cr4zychriss
      I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
      I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
      • Barebone / Chassis: TongFang GK7MRFR
      • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
