Samxon capacitor esr
  • GEARELECTRONICS
    • Apr 2019
    • 13
    • seychelles
    I need your advice.
    -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
    -Is this esr reading realistic?
    Thank you
    • 31131
    Re: Samxon capacitor esr
    no,
    the fluke cant read esr, esr is done using AC current.
    the fluke is telling you the cap has internal leakage
    if you read capacitance it will probably be well over what it should be.
    • redwire
      • Dec 2010
      • 3912
      Typical 2,200uF 50V cap has ESR from around 0.264Ω-0.030Ω for low ESR types.
      If the cap has 40V on it with 2,207 ohms leakage... that is 0.8W which is a problem.
      Check your Blue ESR meter is working using a resistor, like 1Ω or 0.5Ω
      It does not use AC, but instead a DC pulse of 0.5mA, 5.0mA or 50mA depending on range.
      I have trouble testing with these cheap Asian caps, the electrolyte acts like a lead-acid battery lol then you add corrosion.
      High leakage current and you need an AC test (dual slope) to measure capacitance. I'm not sure what the Fluke 179 is doing, the 87-V is single slope I thought.
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
      • NuclearSpartan
        Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
        by NuclearSpartan
        Hi everyone,
        I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
        The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
        I don't see any other visible damage anywhere else on the board....
        11-14-2024, 02:32 PM
