HP ProDesk 600 G4 SFF - Warning: Bios is not for Production use
  • shinebad
    • Nov 2022
    • 6
    • India
    Recently I received a batch of HP desktops all of which are in testing mode bios.
    They all display the error "Your system is not fully configured. Please contact HP customer support.
    Warning: This BIOS is Not for Production Use".
    It has a main bios and an EC separate on the board.
    while trying to update the bios from the network it connects to the HP site downloads the bios with a version of 2.23 but restarts after downloading, same happens with a recovery pen drive. I tried programming it with a bios from another site didn't work.
    Can someone provide working bios for the PC
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP ProDesk 600 G4 SFF - Warning: Bios is not for Production use
    Looks like it's a prototype/engineering board, retail BIOS might not work properly on there.
    • shinebad
      • Nov 2022
      • 6
      • India
      Is there nothing that can be done
      • peste
        • Dec 2016
        • 12365
        • ROMANIA
        try to see if something changes..
          • 20462
          If flashing the bios doesn`t work this might help
          https://www.badcaps.net/forum/showth...lly+configured
          https://www.badcaps.net/forum/showpo...6&postcount=42
          https://www.badcaps.net/forum/showth...light=sssm.bat
          • shinebad
            • Nov 2022
            • 6
            • India
            Hi tried the files you gave dosent work
            • shinebad
              • Nov 2022
              • 6
              • India
              tried sssm.bat from WNDMIFIT not working either.
                • 20462
                Ok well, as piernov said it could be a prototype/engineering board.Changing the PCH could be the only option.
                • shinebad
                  • Nov 2022
                  • 6
                  • India
                  Using Analyzer i have noticed an option FWUpdate Support │ Impossible
                  is that why I am unable to update the bios using a USB drive. Is it possible to mod the bios to change this option.
                  • ianasystems
                    Need Help Restoring BIOS and MAC Address for HP ProDesk 600 G1 SFF
                    by ianasystems
                    I'm currently dealing with a BIOS corruption issue on my HP ProDesk 600 G1 SFF desktop PC.
                    After the BIOS got corrupted, my PC was showing no display, and I had to take it to a repair shop where the technician removed the BIOS chip from the motherboard and installed a BIOS I provided from a file I downloaded from the official HP website.
                    While the display issue was fixed and the system is powering up again, there's one major problem: the Ethernet MAC address is now showing as FF:FF:FF:FF:FF:FF, indicating that it's been wiped or corrupted as well....
                    04-16-2025, 02:04 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • beBoss
                    HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                    by beBoss
                    as noobie to this please excuse my lack of experience.
                    I am trying to remove a BIOS password from this machine:
                    HP ProDesk 400 G6 Mini
                    but so far I still have no success.
                    I bought CH341 programmer and decided to give it a try.
                    The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                    I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                    05-30-2024, 12:48 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
