Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
  • torchzack
    • Aug 2023
    • 2
    • United Kingdom
    Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
    I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
    Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't think it's worth it given sometimes it will boot.
    The cycle is:
    >Black screen with "Samsung Smart TV" white text
    >blank > to black screen with the same test (but top left of that seems to fade out slightly)
    >Repeat until 1 time in 10 minutes it will boot normall and be fine.
    I took the screen apart and disconnected the left and right ribbon cables separately and with either/none the backlight comes on and stays on. With Left OR Right plugged in ONLY the backlight will come on and stay on.
    When BOTH are plugged in on the first time after (uplugging either side ribbon cable) it will boot straight away - then will go back into boot loop cycle.
    Given the main (power) board is £25, and the "TCON" board is £40 - i feel like i should just buy one to see if that works.
    Ideally looking to see if anyone's knowledge would lead it to be suspect of either of the boards. My first thought was power issue as it works sometimes - but then with the ribbon cable removed issue i think TCON board is more likely.
    Any guidance or ideas would be great.
    I'll grab some pictures if there's anything specific you think i should be looking at.
    Thanks - Z
  • MrBrick
    • Oct 2023
    • 5
    • United Kiingdom
    Re: Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
    I have the same issue with my "55 Samsung - did you find a solution?
    • nomoresonys
      • 12241
      • U.S.
      For a quick test try #2, that's on the powerboard.
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        My thinking is if it were an issue with the panel you would not be able to boot at all and the TV would give no display with flashing error codes at the status light.
        Chances are its also not a backlight issue either.
        Bcos you are also having video distortions my guess is a video related ICs ball grid array is starting to go. This is on the mainboard. A refball is necessary to rectify it. Some have temporary success by heatig the chip to get the solder beads to reorient themselves. This is called a reflow and i have never known this fix to last very long though.
        I dont know of a way to test this theory in a nondestructive manner. Your best bet would be to order a replacement mainboard and see if it curse your issue. You didnt mention the price of a mainboard. Not sure if having the chip reballed is an economical option but it usually isnt.
        Good luck and keep us posted.
        • nomoresonys
          • 12241
          • U.S.
          The cycle is:
          Thanks - Z
          Yes, ALWAYS pictures, need good straight on focused pictures of each board and one of the whole back as to see how everything is connected.
          • nomoresonys
            • 12241
            • U.S.
            Simple test, with tv unplugged from power, unhook cable from powerboard to mainboard, leave it off, plug tv into power, do backlights come on and stay on.
            • Storyteller12
              • Jun 2020
              • 625
              Mu series Tvs seem to have a lot of eeprom issues. Could be bad eeprom chip or it’s starting to go corrupt. You can try freezing the chips then powering on to see if any change. These are always Winbond chips in my experience.
              Lotas usually assist everyone here with fixing there eeprom software if you have a programmer/ reader.
              • EazyBone
                • Jun 2023
                • 1352
                • United states
                My guess is it's still the panel. Pictures would help though, are you disconnecting each side of the ribbon cables coming from tcon to panel driver? If you are, try disconnecting a panel driver cable to panel driver cable instead. No pictures to see if there is two cables but just an idea.
                I would also just try a piece of tape on each side of the cable anyways since you can quickly move the tape a few times and cover like 8 pins turn it on and off, if one of those gets it to stay on for a bit then that's probably your answer. YouTube fixing Samsung with tape if you don't already know.
                But it is odd that sometimes it "turns on"
                Bootloop I believe is not usually power board or TCON, I would definitely not buy those parts until you do some tape method.
                • MrBrick
                  • Oct 2023
                  • 5
                  • United Kiingdom
                  #6 I have unplugged the cable as per your instructions and the backlight came on and stayed on.
                  Attached are some photos.
                  • nomoresonys
                    • 12241
                    • U.S.
                    Ok, that in most cases means the backlights and powerboard are alright, so you can concentrate on the rest.
                    • Takeatry
                      Yet another Samsung QLED Boot Loop
                      by Takeatry
                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                      10-04-2024, 02:57 PM
                    • NolesFan
                      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                      by NolesFan
                      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                      10-24-2024, 06:36 PM
                    • eigma
                      Samsung UN40H5003 boot loop every ~8 seconds
                      by eigma
                      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                      Main board: BN94-07592P / BN97-08922R...
                      11-20-2024, 10:31 PM
                    • blaster_
                      Samsung UE49MU6105K - boot loop, horizontal lines
                      by blaster_
                      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                      06-22-2022, 05:19 PM
                    • signedupfordownload
                      Samsung UE49KU6500U boot loop
                      by signedupfordownload
                      My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                      With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                      I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                      07-29-2024, 01:56 PM
