Vendor-Series Equivalents
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    This is organized vertically, higher Z to lower Z ratings (based on 50V, 16mm x 25mm parts for the 5K-10K hours series, and 2200uF, 10V, 10mm x 25mm part for the 2K hours series) and alphabetically L-R. The rated life is noted for each group.
    Nichicon PJ // UCC LXV
    Nichicon PW // Panasonic FC // Rubycon YXF // UCC LXZ (8k Hrs. except FC 5K Hrs.)
    Rubycon YXG (6K Hrs.)
    Nichicon HE // Rubycon YXH // UCC KY (10K Hrs.)
    Nichicon HD // Rubycon ZL // UCC KZE (5K Hrs.)
    Rubycon ZLH // UCC KZM (10K Hrs.)
    Panasonic FM (7K Hrs.)
    Nichicon HM // Sanyo WG // UCC KZJ (2K Hrs.)
    Nichicon HN // Rubycon MCZ // UCC KZG (2K Hrs.)
    Nichicon HZ (2K Hrs.)
    PeteS in CA
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
    11-20-2024, 08:52 PM
  • burom
    Xbox 360 Xenon Modern Capacitor Replacements
    by burom
    I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
    I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
    06-07-2024, 05:10 PM
  • iMic
    Vintage AT Power Supplies - Selecting Capacitors
    by iMic
    Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
    The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
    02-19-2023, 06:45 PM
  • nick3092
    Mid/late 80's Nichicon Yellow Caps
    by nick3092
    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
    08-28-2022, 03:56 PM
