I picked up this sharp lc-32sb24u and it has a flashing green light seems to be an even pace of 1 flash per second. Holding down the input and volume down while plugging it in resets the error and it will start and run for about 3 seconds.
I consulted the manual for this model which says to just read the manual for lc-32d44u. So in that manual it says that 1 green light flash is an error with the bulb.
Normally after knowing the bulb / inverters are probably the issue i would see if i could disconect each bulb seperately and test the tv with 1 disconected at a time, but if you look at the picture of this unit the inverter is screwed directly into connectors for the bulbs, so im not sure if there is any easy way to disconect 1 at a time.
Second thing to check is if the windings have the same resistance on each inverter, which im going to try and check, but im not sur eif the secondarys have any exposed pins considering the way they go through the bottom of the board and connect straight to the bulb connectors.
