Replacing LCD CapXon Caps
    I have this LCD monitor that uses
    CapXon, 220uF, 25v, KF 105c, P552, VENT [11mm-*12*mm tall, 8mm dia]
    CapXon, 1000uF, 25v, KF 105c, P546, VENT [21mm tall, 10mm dia]
    So I read these are badcaps and so... please suggest what goodcaps to replace them with. I'd also like to mention this is the first time I'll be soldering and I'll need a soldering kit too... but anyway, just the caps to begin with.
    I will be buying from http://my.element14.com and I'm very confused by impedance, ESR, Frequency Tolerance:..... some fields that are mentioned in one but not mentioned in the other...
    I read that nichicon/rubycon are good.... but there's no exact match...
    this appear to be the closest match http://my.element14.com/united-chemi...ial/dp/1690775
    but I'm not sure at all.. because it has ESR specified.. while most don't.
    Many thanks.
    Re: Replacing LCD CapXon Caps
    It's not quite the same thing, but for all intents and purposes you can use the Impedance value for the ESR.
    To keep it short :
    Capacitance needs to remain the same.
    Voltage rating of the new capacitors should be the same or higher. Sometimes if you have no choice, you can use capacitors with lower voltage rating, but unless you know what you're doing you should never do that.
    Ripple value of the new capacitor should be equal or higher. In the worst case if you have no alternative, it should be very close to the old capacitor's ripple value.
    ESR/Impedance should be equal or lower. Very rarely, it "hurts" if the new capacitor's esr/impedance value is much, much lower than the original capacitor's value.
    CapXon KF datasheet is here:
    Basically you have :
    220uF 25v 8x11.5mm , 550mA ripple, 0.15 ohm impedance/esr
    1000uF 25v 13x20mm , 1650mA ripple, 0.045 ohm imp/esr
    You say this last one is 10x21mm - there's no KF series capacitors at 1000uF/25v - the one matching this size is 820uF one. Perhaps this is not a KF series or you read the capacitance/voltage incorrectly?
    So basically you go on element14.com, at the capacitors.
    For the 220uF, 25v :
    Check radial leaded,
    check 8mm and the sizes that would fit in the space you have on the board (if 10 mm capacitors fit in there, check the size, repeat with larger diameters)
    Check 220uF
    Check 25v and values larger than that, like 35v, 50v - you can go up in voltage without any problems and capacitors with higher voltage rating have better specs but they're a bit larger.
    Now click show products to get some results.
    Now, from the left side, click on select manufacturer and click on Nichicon, then repeat the process with Panasonic, Rubycon, United Chemi Con - these 4 brands are quality ones.
    Now, if you only selected 8 mm diameter, sort the results by price. Usually, better quality capacitors are more expensive but that's not always the case - if the stocks are limited, element14 increases the price. Still, it's a good start. If you can fit several diameters and you checked several, skip this step because you'll sort later by diameter.
    From this point, if needed, check "In stock" from left side and press apply and the list should be smaller.
    Now open one at a time and see which one has ripple value higher or equal than your capacitor's value and impedance lower or equal.
    Here's my results page for the 220uF 25v:
    http://my.element14.com/jsp/search/b...alues%3D202457
    I picked 25v and 35v and 8mm and 10mm, only the quality brands, only what's on stock.
    So from that page, as I selected both 8mm and 10mm diameter, I sort by the diameter to get the 8 mm ones first and then I check the datasheets for each result (there's a chart inside with voltage and capacity and the values for the combination) and find :
    Panasonic HE , 220uF, 25v, 8x12mm , 640mA, 0.13 ohm ... about the same as your current one : http://my.element14.com/nichicon/uhe...ial/dp/1823642
    Panasonic FM 220uF 25v, 8x11.5mm, 950mA ripple, 0.056 ohm better http://my.element14.com/panasonic/ee...25v/dp/1219468
    Rubycon ZLJ 220uF 35v , 8x16mm, 1600mA, 0.059 ohm... even better if you can go to 16mm in height http://my.element14.com/rubycon/35zl...0uf/dp/1831280
    ... and there's others which you can pick fitting your need.... make a list and pick whatever's more convenient (price per quantity)
    Now repeat what I said and make a list for the 1000uF capacitor (or 820uF, or another series... I don't know, there's no Capxon KF 1000uF at that size)
    Paste here your selections for 1000uF and I (or others) can check if what you selected is good.
      Great forum, no, you're great. So much details to help this beginner me.
      Options:
      RUBYCON - 25ZLJ1000M10X20 - CAPACITOR, RADIAL, 25V, 1000UF
      http://my.element14.com/rubycon/25zl...0uf/dp/1831277
      PANASONIC - ECA1EHG102 - CAPACITOR, RADIAL, 25V, 1000UF
      http://my.element14.com/panasonic/ec...0uf/dp/1848543
      NICHICON - UVZ1E102MPD1TD - CAPACITOR ALUM ELEC, 1000UF, 25V, RADIAL
      http://my.element14.com/nichicon/uvz...25v/dp/1822672
      I hope I did well. A "B-" will do.
      So..
      220uF: Nichicon HE vs Panasonic FM
      1000uF: Rubycon ZLJ vs Panasonic EH vs Nichicon VZ
      How do I judge which one's best? How should I make my decision from here?
        Rubycon ZLJ is OK.
        The Panasonic one isn't - its ripple value is only 680mA - the old capacitor has 1650mA ripple and 0.045 ohm imp/esr , so you should get one that has at least about 1300mA ripple.
        Same story with VZ.
        You really have to look inside the charts in the datasheets.
        Anyway, not much out there other than the Rubycon ZLJ, at those diameter and height restrictions.
        If you go to 20-23 mm height and maybe 12.5mm diameter you have more options.
        As for the 220uF, I stopped at those 3, Panasonic HE or FM and Rubycon ZLJ. But there's tons more models that fit your needs, especially if you have 18-20 mm of height you can play with. From those three I gave you as example based on your restrictions (diameter and up to 12-16mm height), The FM and ZLJ are the better ones according to specifications. But you can pick whichever comes out cheaper at the end, all three are good.
          Panasonic FR 10x20mm: http://my.element14.com/panasonic/ee...0uf/dp/1907238.
            1
            1831277 4 CAPACITOR, RADIAL, 25V, 1000UF
            RUBYCON
            25ZLJ1000M10X20 RoHS Compliant Yes
            2
            1144699 4 CAPACITOR, 220UF, 25V
            RUBYCON
            25ZL220MEFC8X11.5 RoHS Compliant Yes
            3
            1281814 4 CAPACITOR, 220UF, 25V
            RUBYCON
            25ZLG220MEFC8X11.5 RoHS Compliant Yes
            These items are in my shopping cart now.. and yeah I bought a couple of extra's since they are cheap... not sure if that's too many extras or unwise anyhow.
            My eyes are now on the Hakko FX-888 soldering kit?station? What else do I need?
            solder sucker? pump? braid? flux? I should get a holder.. hmm...
              If you're just planning to repair this monitor, it doesn't really make sense to buy a Hakko FX-888 soldering station - it's kind of expensive.
              The board is simple enough that you would be able to de-solder the old capacitors and put the new ones with cheap soldering guns. You should be able to just apply some flux over the old solder, add some solder over the one there, heat up both wires of a capacitor and pull it out from the pcb... then just push the new capacitor in, keeping the polarity the same.
              For example, this 40w soldering iron one would work ok, if you're patient enough until it gets hot (about 3-5 minutes) :
              http://my.element14.com/duratool/d00...lug/dp/1568161
              For something better but not quite as good as a Hakko, this is OK:
              http://my.element14.com/duratool/149...-eu/dp/1737236
              If it costs 80$, it's a good deal.
              If you're willing to buy a quality soldering station, the Hakko FX-888 is a very good one. Generally, the 240v ones are marketed towards the Europe and Australia and they're very expensive compared to the 120v station.
              However, there's a version available made for the Chinese market, which is cheap and should have the same standards of quality:
              http://www.dealextreme.com/p/hanko-f...ac-220v-126505
              I don't think you'll need a solder sucker... I don't use them. Solder braid would help: http://my.element14.com/edsyn/sw091-...-0mm/dp/876835
              Flux definitely helps - try to get a "no clean" one, for example this would be ok:
              http://my.element14.com/kester-solde...der/dp/1925200
              With others that are not "no-clean" you would have to clean the pcb area with water or with isopropyl alcohol after soldering.
              You might find cheaper flux locally, but the one I linked is very good.
              The holder is also not really needed and if you get a soldering station, they come with one.
                Thanks once again for the marvelous suggestions.. I haven't come to a conclusion with a solderer but I may be able to pick up the Hakko FX-888 for ~$80-100.. I'll need to make some calls Monday. In any case, I've the below in my shopping list.
                1
                1925200 1 CHEMICALS,SOLDER
                KESTER SOLDER
                83-1000-0951.
                2
                876835 1 DESOLDERING BRAID, 2.0MM
                EDSYN
                SW091/2.0
                3
                1367049 1 CLAMP TOOL, WITH MAGNIFIER
                DURATOOL
                D00269
                I will be working on LCD monitors, psu, motherboard, gfx cards. POSSIBLY interested in making my own audio DAC in future...
                So I guess that's about everything to get me started yeah and a little beyond?
                  If you're sure you're going to work on other electronic devices, get a soldering station - if possible that Hakko model. It pays off in time, it's much easier to work with.
                  I wouldn't get the clamp tool with magnifier... it's a very cheap model that's not so good - I mean it won't be able to hold boards commonly found in monitors, video cards, it bends down from the weight. The base is not that solid also.
                  Something like this:
                  http://www.amazon.com/Ramsey-RTS13-P...4518822&sr=8-7
                  would be more suitable.
                  These Panavise things are recommended by engineers often: http://www.amazon.com/s/ref=bl_sr_in...xtbin=Panavise (you pick a base and then whatever you want on top, circuit board holder or whatever else)
                  No clean flux you should be able to find in local stores in larger quantities and a bit cheaper, though I wouldn't know how good it is. I personally bought from a local store a 50 ml no-clean flux bottle for about 4$ - that pen style flux is probably only 10-15ml.
                  Anyway, it will last you a long time.
                  You should also get some solder wire... get quality one with no-clean flux inside. Even with no-clean flux inside you will see sometimes you have to apply additional flux on the area you wish to solder.
                  You also need to add solder sometimes to the lead free solder on the pcb so that the heat from the soldering tool tip is transmitted onto the hole that's soldered.
                  Probably all you're gonna work with is lead free solder, but there's no point in buying that - you'll only have a hard time with it due to lead free's solder temperature, which is higher at about 217c.
                  Get one of the variants with lead... I personally use 63/37 but the most popular one is 60/40.
                  63/37 is euctetic meaning it turns liquid at a much narrower temperature range and it also turns solid much faster. This is good when you work with soldering wires on jacks or when you want to just remove the tip from the solder and see the solder harden in 1-2 seconds as the temperature drops.
                  60/40 has a much wider range, which means it's easier to work with when you have crappy tools, it stays liquid for a much longer time, and turns liquid faster... but the disadvantage is once you apply solder where you want to make a connection, you need to keep that wire and everything steady for a few seconds until the solder turns solid, otherwise you may get a poor quality soldering.
                  A 100g or bigger roll should last you a very long time - I personally went and got a 500g roll and it will probably last me 5-10 years.
                  The thinner the diameter the better, but pick something that has at least 2% flux, and that one preferably no-clean one.
                  Here's something that I would recommend :
                  http://my.element14.com/edsyn/ss5250...-5mm/dp/871436
                  60/40 http://my.element14.com/multicore-so...50g/dp/5090787
                  63/37 http://my.element14.com/duratool/spc...5lb/dp/1530151
                  (I'm reluctant to recommend the Duratool, it's somewhat of a "store brand", they're just rebranding stuff other people make. But this one is cheap and 63/37 being not so popular you only find it in 500g spools which is more expensive.
                  If you can, stick to Multicore, Kester Solder, Stannol, Edsyn.. these are established brands and you can be sure the quality is consistent.
                  There's also other varieties that have silver or copper in them - silver ones are better for soldering surface mount components as some SMD chips have silver at the ends so the chemical "gluing" is better with this kind of solder.
                  http://my.element14.com/multicore-so...250g/dp/419540
                  I don't think it's worth paying that much extra for this variety, even if you do work a lot with SMD components.
                  ps. and you absolutely need to watch at least part 1 and 2 from this tutorial:
                  http://www.youtube.com/watch?v=J5Sb2...ure=plpp_video
                  http://www.youtube.com/watch?v=fYz5n...ure=plpp_video
                  http://www.youtube.com/watch?v=b9FC9...ure=plpp_video
                    Solder station:
                    So it's decided that I'll be taking the Hakko FX-888. Done. $150 Real bummer. Getting overcharged here.
                    Vice:
                    It has to be one of these 3... it's actually over my budget already. I was thinking to do away with cheap beginner goods. I just needed something to hold. I hope I'm doing the right thing, it's quite the investment. Care to share your opinion?
                    http://my.element14.com/draper-tools...5mm/dp/1706192
                    http://my.element14.com/panavise/301...ose/dp/1653517
                    http://my.element14.com/stanley/83-0...ice/dp/1696668
                    Solder:
                    http://my.element14.com/multicore-so...50g/dp/5090866
                    http://my.element14.com/multicore-so...50g/dp/5091020
                    There's lead, and lead free... not sure about the flux part, but they have different 'flux types'
                    Is 0.5mm big?
                      I'd go for the Panavise one, but if you have limited budget save them for later, you will manage to work on boards without one of these, until you have money to get a proper one.
                      Solder, must get one with lead as I explained, it's much, much easier to work with.
                      Lead's chemical element is Pb, so you must get one that has Pb in the composition - the only one you list is the first which has 62 / 36 / 2 Sn / Pb / Ag or 36% lead.
                      The first is good, but a bit thick in diameter. Try to make an effort and get one that's close to 0.5mm or even thinner.
                      For reference here's my 0.56mm one - as you can see it's a bit thicker than the lead of a capacitor:
                        Vice (revised):
                        acceptable? or can i just use my bear hands. if i eventually purchase the panavise i'd be spending more in total. do suggest. http://my.element14.com/dremel/26152...pcs/dp/1869045
                        Solder (revised):
                        Didn't notice it was 0.7x mm.. I swear I set 0.56 as the upper limit lol.
                        *my choice* cheap: http://my.element14.com/edsyn/ss5250...-5mm/dp/871436
                        double the price: http://my.element14.com/multicore-so...250g/dp/419564
                        worst candidate?: http://my.element14.com/multicore-so...50g/dp/5090787
                        Actually..
                        I did some googling on lead vs lead free. It does appear health concerning.. so I may secretly do away with a lead free version. It may be more difficult, especially in the beginning, but I think I should be able to get the hang of it in time.
                        My only concern is the higher melting point which may damage the pcb. Tough decisions. So maybe after all I'll just inhale some lead..
                        Update: Further googling suggests no cause for concern. Countries are worried about lead poisoning is more due to dumping lead products into the waters than lead inhalation. So I'll just buy the lead version and do the world more evil.
                          Just don't buy a vise.
                          Your first choice is good.Go for the ~0.7mm ones if smaller diameter ones are no longer available in the Singapore location (I assume that's what's cheaper for you)
                          Yeah, no need to worry about lead, just wash your hands after soldering a lot. Lead doesn't burn when soldering, unless you eat it you won't have anything to worry about.
                          In fact, the flux inside the solder is what's making that smoke which is actually a bit bad for you - in time, it can irritate your lungs and throat. Generally, a simple computer fan blowing some air across the desk where you work and a ventilated room is enough, but there are fans with special filters designed to absorb that smoke.
                          I posted some links to a youtube tutorial about soldering just a few posts above - I see you didn't watch it as it explained all this. It's really useful and informative and shows you a lot of what I said, you should watch it.
                            Okay.. you're right I haven't watched this. As funny as it may seem, I'll be getting my gf to watch it as she will be doing the soldering. My hand shakes as hell so I'm probably no good at this. I saved the links though, I thought I should watch them after purchasing. Incorrect assumption.
                            Now I realize, everything you say is very absolute.
                            Proceeding with purchase now.. a very big thanks for all the help and recommendations.
                              It just occurred to me.. will I need decent tweezers to hold caps? Searching element14.. there's a whole range of these goods...
                              http://my.element14.com/proskit-indu...pcs/dp/1666210
                              http://my.element14.com/arexx/at-700...tic/dp/1280092
                              Are goggles highly recommended for safety or are havocs very very very unlikely?
                                I did have flux hit my face in the past (had to put some liquid flux on an oxidized connection and boiled when i put the solder tip on the pad)
                                So I got one of these: http://my.element14.com/north-safety...ame/dp/1762958
                                They're clear enough they don't bother me at all when working, they're much clearer than what the picture shows.
                                These will probably work just as well: http://my.element14.com/north-safety...gle/dp/1696197
                                They're rated only for protection against dust but they will probably also protect your eyes from broken drill bits and other things, they just don't have that rating.
                                I just use some tweezers that came with nail clippers and other things my sister uses. Technically it's not recommended because they can get charged with electrostatic stuff or get magnetic but I don't work with so sensitive equipment to care.
                                I guess if you want, you can get the ones in the first link.
                                  If you're interested to know, I've successfully revived the monitor with all the recommended items you provided, not to mention with bad solder work. I guess experience is needed. That braid was rather thin though. Didn't quite like that. Had difficulty getting the solder to stick to the braid.
                                  OK, many thanks for your replies.
                                  BTW: for desoldering, is a 60/40 better? I notice adding some solder helps in desoldering.. then i couldnt help but wonder if a 60/40 would work better for that.
                                    60/40 stays liquid for more time. So 60/40 would help you a bit when desoldering, as you can heat, put down the gun and maybe still have time to pull out a capacitor with the hand you kept the tool in while the solder is still liquid.
                                    But at the same time, you could just add solder to the leads, grab your solder wick and heat it up with the solder tip until the solder on the leads simply "crawls" up the wick, leaving the holes nearly empty.
                                    So no, 63/37 is overall much better imho, being eutectic and the advantages outweigh the cons.
                                    Maybe you weren't patient enough to heat the wick until it was "ready" to do its magic. Sometimes it also helps to put a drop of liquid flux on the solder wick and the soldered leads and it also helps to move the wick slightly near by the solder so that it gets on new surface.
                                    Here's a pretty good video showing how solder wick works: http://www.youtube.com/watch?v=htrcZuK_ZsY
                                    I'll be honest and tell you my solder wick doesn't work as nice as his, but when I apply a bit of liquid flux on it and the soldered leads it's nearly as nice as in the video.
                                      I'm going to purchase a new solder wick. (2mm seems a bit small and difficult..)
                                      My eyes are on
                                      3.9mm wide oxygen free copper
                                      5.3mm wide rosin oxygen free copper
                                      which would you choose? I feel 5.3mm is rather too wide... but I'm not sure if being extra wide causes for-now-unforeseen problems.
                                      Maybe i'll buy some liquid flux.. not very sure if that flux pen works at all haha... or im using it wrong. Any tips on liquid flux? Also, how do i clean off flux, alcohol?
                                      Would like to ask also... why do caps go bad? I've noticed high end power supplies use "branded" caps, true. Bad power supplies use no-name caps. But this cannot be the only possible conclusion.
                                      I got the thinking that, in order to "limit" a product's life.. they could be stressing out components, well like capacitors! If so, what could actually cause the caps to bulge? Overvoltage? Undervoltage? Capacitance too high? too low? Ripple below recommended? ESR slightly higher than recommended?
                                      Which would it be so that I'll go out and purchase capacitors higher rated than the ones i pulled out.
                                        It's usually simply because the original capacitors are crap quality.
                                        -David VanHorn
