AAA - Agilent Advisor Advice
  • Shodan486
    • Nov 2009
    • 203
    Anyone has any experience with the Agilent Advisor series, particularly a J2300E model with J3444 Fast Ethernet undercradle? I was trying to plug it in to our company intranet, got some readings for the first and second time, but now I cannot read the network at all, pops up a few errors of failed initializations of various types, regarding to network parameters of course.
    BTW, it never worked at home.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
  • davg
    Home network connection problem
    by davg
    I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
    03-06-2021, 07:13 AM
  • japlytic
    Maximum speed should be marked on network ports
    by japlytic
    I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
    One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
    12-19-2024, 05:04 PM
  • hikomalek
    SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
    by hikomalek
    Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
    When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
    Transformer:
    |Info| Primary | Aux | AB | CD|
    |Ratio|1|25|40|12|
    |Voltage AC|230V|9.2V|5.8V|19V|
    |Voltage DC (*1.41)|230V|13V|8.1V|27V|
    I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
    09-19-2025, 03:30 AM
  • Ady2017
    SMD fuse soldering advice please
    by Ady2017
    Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
    11-07-2025, 12:03 PM
