Honda Civic ECU
  • almoodie
    • Jan 2010
    • 66
    Honda Civic ECU
    Anybody know if auto ECUs are subject to cap failure
    Have Honda Civic EX 2006 135k miles.
    For the last 18 months its had a starting problem, sometimes it will start first time, other times it requires 4 or 5 attempts. It always starts, just has to be "coaxed"
    Problem is the same hot or cold.
    Shows no trouble codes using my ODB scanner.
    Took it to large local Honda dealer, still no trouble codes.
    They had it for a day and a half. Checked the battery, replaced earth straps and tested a whole bunch of sensors.
    Even sent live data feed to Honda HQ in California, no progress.
    Honda HQ says try replacing the ECU computer module. Had to take the car back before they tested with replacement ECU. They will test it when we can spare the car.
    If I need to replace the ECU, is it something that is worth opening looking for bad caps.
    Al.
  • turbozutek
    • Jan 2009
    • 71
    Re: Honda Civic ECU
    The automatic transmission controller ECU in my Volvo gave hard shifts due to bad capacitors.
    http://www.matthewsvolvosite.com/for...454b32814d58af
    The caps looks perfect, no bulging or swelling, but every one was knackered. Repair was easy, swapped in new caps!
    Chris...
    • twbranch
      Mad Nerd
      • Oct 2012
      • 153
      Re: Honda Civic ECU
      My Jeep computer had bad caps in it. I would assume all of those car electronics are made with junk caps.
      • jetadm123
        • 2169
        Re: Honda Civic ECU
        Probably wouldn't hurt to look at some of the honda forums to see if others have been experiencing the same problem.
        • turbozutek
          • Jan 2009
          • 71
          Re: Honda Civic ECU
          Actually, every car ECU I've ever worked on has had very GOOD caps. Ni's, Panasonic, Ruby's - stuff like that. Even the cheaper, crappy cars I've worked on (think Daewoo, Dacia, etc etc) had decent caps under the panels.
          I guess when a device costs $10,000+ and you have to warranty it, it really doesn't pay to use TEAPO or SU'CON.
          Of course, even decent caps can fail!
          Chris...
          • twbranch
            Mad Nerd
            • Oct 2012
            • 153
            Re: Honda Civic ECU
            My Jeep TJ had junk in it!
            • turbozutek
              • Jan 2009
              • 71
              Re: Honda Civic ECU
              American cars; designed by a committee of accountants.
              Chris...
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Honda Civic ECU
                i see lots of cap failures in automotive electronics.
                last week i fixed a friends cluster from her impala ss.speedometer was dim.i noticed it 2 years ago.yep bad caps that got sharply worse.i thought the vfd was dieing off.
                was easier than the optispark i rebuilt on it.
                • turbozutek
                  • Jan 2009
                  • 71
                  Re: Honda Civic ECU
                  On the Euro cars I normally work on, soldering can be a problem. Certain years of Volvo's, have a 70% failure rate of the dash information module from dry joints and crappy lead free solder. A re-flow with some fresh solder usually does the trick.
                  The only North American cars I've ever worked on are Saturns and no electrical problems yet... Just literally everything else.
                  Chris...
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Re: Honda Civic ECU
                    Saturns seem fine to me. With the cars, just watch out for the SOHC 1.9s.
                    The SOHC versions, the base version of the 1.9 motor, reportedly are prone to head issues. The DOHCs seem to be better.
                    How to tell if it's a DOHC or SOHC?:
                    If the red line of the tach is less then 6,000 RPM, it's probably the SOHC version.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • turbozutek
                      • Jan 2009
                      • 71
                      Re: Honda Civic ECU
                      Off topic, but it's an ECOTEC (so dual cam). Steering pump driven from Cam, prone to timing chain failure, garbage. Problems finding parts and the subframes like to rust; especially here in Canada. Quality Mexican steel.
                      So yeah I really miss the Volvos, Mercs and BMW's I used to drive when I lived in the UK.
                      /Back to Honda ECU's.
                      Chris...
                      • Hondaman
                        • Sep 2008
                        • 1086
                        Re: Honda Civic ECU
                        Once it starts, do you have any problems?
                        My sister had random failures back around 1987 (wouldn't start, and engine would die with no warning, even when warm).
                        It was bad soldering (German fuel injection module, 1978 Datsun 810 4-door sedan, automatic gearbox. They used the 2.4 liter engine from the 240Z).
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          Re: Honda Civic ECU
                          anyone get their hands dirty and check under the hood yet?look for things like fuel pressure,spark,injecter pulse,ect.
                          iirc it was a nissan xterra i bought as a flipper that was real hard to start.had a bad fuel pump and check valve.would lose its prime and take many attempts to get enough pressure to start.this offered no codes either.sorry but you cant always fix it with a scantool.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Re: Honda Civic ECU
                            Sounds more like a lawn mower than a recent model EFI engine.
                            Arc A770 16 GB
                            • krazykev64
                              • Feb 2009
                              • 49
                              Re: Honda Civic ECU
                              I have a friend with his own Nissan business. in the past i have rebuilt absolutely loads of throttle bodies for him from the Mark 2 micra's. there are no faulty caps but the problem has always been dry solder joints on the same particular joints. its a simple fix as this video shows. dont forget to clear the stored fault code if the management lamp came on
                              https://www.youtube.com/watch?v=hW3KYDbXwog
                                • 31144
                                Re: Honda Civic ECU
                                all honda obd1 ecu's have a cap that fails and burns the board - it's near a big diode.
                                if i had any 90's honda ecu's i'd recap them before they burn.
                                • mntegra01
                                  • Nov 2014
                                  • 31
                                  Re: Honda Civic ECU
                                  Being a 2006 model I would suggesting ignition switch or main relay (responsible for fuel pump and starter)
                                  Do you get anything when you try to start? any dash lights? any clicking from starter? or just completely dead?
                                  sadly an old thread and OP never came back with what happened so we can learn...
                                  • LatinMcG
                                    • Jun 2015
                                    • 73
                                    • USA/Puerto Rico
                                    Re: Honda Civic ECU
                                    my accord 96 DX auto had 2 bad caps.. you can barely see the leak on the nichikons.
                                    symptoms: take 2 to 10 mins for fuel pump relay to turn on.
                                    on older 91 hondays the main relay had a bad solder joint on 2 pins usually.
                                    or the distributor pickup coils aka trigger coils it had bad insulation inside that gave way less resistance and thus no signal received by igniter once it warmed up.
                                    simple test for this issue was to cool distributor with a ice cold wet towel on metal of it.
                                    lol i did it for a guy at 7-11 and he drove to the mech shop witha big cup of ice and a old tshirt lol
                                    • michalk3777@gmail.com
                                      Sharp Hisense - LC-65N7004U Error codes
                                      by michalk3777@gmail.com
                                      Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                                      Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                                      Regards,...
                                      12-15-2024, 09:20 PM
                                    • Paulo11
                                      Iphone 12 mini boardview component codes
                                      by Paulo11
                                      Have somebody please iphone 12 mini boardview with component codes that are same like in schemas ? I need at least a picture of caps around nand. Or is there a way of "pairing" a component code from boardview with schemas ? I have boardview file from that large XZZ dump what can you find in this forum.
                                      02-20-2025, 04:37 PM
                                      LCD LED TV Service Menu Codes
                                      ALL LCD LED TV SERVICE MENU CODES
                                      Service Menu Code with Board Name
                                      China Universal Board / Jumper Board Service Menu Code
                                      Changhong Ruba Service Menu Code
                                      Ecostar LED TV Service Menu Code
                                      Orient LED TV Service Menu Code
                                      Haier LED TV Service Menu Code
                                      TCL LED TV Service Menu Code
                                      Samsung LED TV Service Menu Code
                                      LG LED TV Service Menu Code
                                      Videocon LED TV Service Menu Code
                                      Supra LED TV Service Menu Code
                                      Toshiba LED TV Service Menu Code
                                      Symphony LED TV Service Menu Code
                                      Veste/ LED TV Service Menu Code...
                                      10-31-2024, 03:58 AM
                                    • lti
                                      Honda Civic speedometer cluster - "inverted gas gauge"
                                      by lti
                                      This seems like a common problem, so I thought I would post it here. This cluster also had one flickering segment in the speedometer display. There are three LCDs in this cluster, and there were cracked solder joints for the fuel gauge (image 1) and speedometer (image 2) LCDs. The temperature gauge LCD (image 3) looked okay, but I resoldered all three LCDs. There is conformal coating over most of the solder joints on this board, so that should be removed first. It does melt with heat, but melting through it with the soldering iron isn't the best idea.
                                      This car hasn't been driven enough...
                                      02-01-2020, 05:52 PM
                                    • omgitdrifty
                                      Honda. 31570-VP7-A01
                                      by omgitdrifty
                                      Hi guys
                                      Got a Honda. 31570-VP7-A01 mother board here with a K0CA 7A fuse.
                                      I cant find this fuse.
                                      Question is what can I replace it with.. I know it AC 7 AMP fuse but what does K0 stand for?
                                      09-06-2024, 02:02 AM
