I want to know the proper way to remove a smd voltage regulator like the one in the photo without burning it up? The chip is soldered in three locations (the two pins & the back). Please be specific like tip size, solder type etc. I am not sure if this is the proper forum so please don't be angry with me. I posted in general electronics section but I have not received a reply as of yet. I thank you for any help provided.
How do you properly remove a surface mounted voltage regulator
Re: How do you properly remove a surface mounted voltage regulator
Hot air rework, or a $20 heat gun from harbor freight. -
OR
Put the solder iron tip on the tab, right about where the join between the tab and the pcb is.
Wait a few seconds for the chip and pcb to heat up and then add 60/40 solder to the join point between the tab of the chip and the pcb. Basically put a big blob of solder there. Move the iron tip back and forth on the tab to warm up the whole width of the tab equally. Don't press too hard on the iron top because you might break the pcb traces and pads.
Add a bit of solder to the legs of the chip as well.
Now move your iron between the legs and the tab several times, the 60/40 solder remains for a few seconds in a liquid state so you should be able to get all three points liquid.
When you think this happens, you can just push a bit on the sides of the chip with something (a match, a screwdriver tip, not your finger because the chip is very hot by this time) and the chip should move away from the board.
You're sort of doing the steps here in the opposite way: http://www.youtube.com/watch?feature...fAlfQE#t=1850sComment
I removed a voltage regulator by desoldering and lifting the two pins, then heating the tab while adding solder. The regulator was extremely hot after it finally came off, but it still works. I did this with a 25W soldering iron.Comment
Ding!! We have a winner! Since the legs are easy, lift 'em first. Kind of a waste to get the tab heated enough only to be stopped by the legs.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....Comment
This is not generaly good, for me the plastic corner usually break when I try to lift the legs.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Well, if you want to spend money, you might as well get ChipQuick, which is a special solder that stays liquid for close to (if not more than) a minute.
It makes desoldering really easy.
But really, with a good solder iron, it's really easy to desolder.
In reply to smason, sometimes it's not a good idea to go on the legs first. There's usually a bit ground pad and the legs are just on thin traces - the ground pad might pull a lot of heat away, so by the time you actually get the lead free solder liquid to get the legs up, you might pull the thin traces up as well.
Heating up the tab also heats the board so when you actually add a bit of solder to the legs, the legs are already hot, it's very easy to add a tiny bit of solder and after a bit of re-warming of the tab, the chip will just slide away.Comment
Desoldering is piece of cake if you have powerfull enough lamp or other tool. But soldering in replacement, that's different story if you want the tab to be soldered properly to a board
Hot air on the small legs, a standard solder iron on the tab. With practice you know how much heat part needs to minimize heat damage. If the board is vertical then the part will just fall off.
Other ways work but will destroy the transistor, the board, or both.Comment
The voltage regulator was in a DPAK package (nearly identical to the TO-252 package shown in the picture). It came off with no damage to the board or the regulator.Comment
Same here. I did manage to remove a few with lti's method without breaking them - these were the first that I attempted, though. The ones following that I kept breaking. Beginner's luck I suppose.
Since then, I have experimented with many other methods. Hot air works fine but is too slow IMO. So my favorite method (and the one I have most success with) is with 2 powerful irons (50W to 60W minimum, preferably with chisel tips and temperature regulated). When removing a standard DPAK MOSFET, for example, I first add lots of solder to the tab of the MOSFET. Next, I add lots of solder across the legs, usually enough to bridge at least 2 of them. Finally, I heat the tab with one iron and heat the blob of solder over the legs with the other iron. In just 3 seconds, all I have to do is just push the MOSFET away from its spot and the job is done. No preheating required and no possibility of damage to the nearby components like you have with hot air. Also, after I'm done using this method, I re-collect the solder left on the board and the MOSFET with the soldering iron and then collect it in a container for reuse again with this method.
Also, the above method is not limited to DPAK MOSFETs. I've used it for removing SOP ICs as well (up to 20 pin). Just put 2 blobs of solder across the IC's leads on each side and heat with the irons.Comment
I now have 125W pistol iron, so I heat up tab with some solder, than either lift it whole up , desoldering just legs than, or go around heating tab, first leg, second leg and tab again. After few tries, it can be removed.
In the worst case scenario I get my 60W monster pen iron and when it heats finally, I can burn through a wall with that
Once kept it running and the pike, massive piece of cupro-alloy ~8 cm in length and 1 cm in diameter, being stabbed into something massive and metal, just bend down under all the heat and weight
But the hot air gun is good if you are desoldering lots of stuff from dead PCB, including FETs. Once it's all heated, you just pick everything up with your pliers, one after other
Hot air alone would be very slow to remove a DPAK. The entire board would be practically on fire before anything would move. That's why I put the solder iron on the tab which not only dumps lots of heat under the transistor, the solder iron can help kick the part off the board. The first transistor takes about 45 seconds to remove. Once the area is warm transistors take about 8 seconds to remove.Comment
They are the same thing.
Why does that package have two different names, and why do component datasheets list only one of those names like they are incompatible packages?
On the board I removed that part from (the main board from a dead CD-ROM drive), it was easy to remove with a 25W soldering iron.Comment
Aluminium foil helps with heating only the very area you want to heat and dumping heat from other parts away.Hot air alone would be very slow to remove a DPAK. The entire board would be practically on fire before anything would move. That's why I put the solder iron on the tab which not only dumps lots of heat under the transistor, the solder iron can help kick the part off the board. The first transistor takes about 45 seconds to remove. Once the area is warm transistors take about 8 seconds to remove.Less jewellery, more gold into electrotech industry!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Channel: Troubleshooting Computer Displays
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 08:10 PM
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 08:10 PM
- Loading...
- No more items.
