Why does a cap vent?
  • Tom41
    • Oct 2005
    • 338
    • England
    Like the title suggests, what exactly causes a cap to vent? Does it heat up and 'boil' the electrolyte? Does electrolysis occur and produce gas?
    I vented a cap recently - by pumping 20v into the 10v-rated cap on reversed polarity and the pic in my avatar shows the result. It 'exploded' with a load of smoke. The cap was very hot afterwards, so maybe it boiled?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Why does a cap vent?
    The theory is that of a pressure cooker. They heat, things expand, have no place to expand to, and poof.....they vent. They do it faster with shoddier brands, as the electrolyte is water-based, and evaporates at temps a lot lower than good ones.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • gonzo0815
      • Feb 2006
      • 1600
      I think it is the H2, wich is generated by a chemicall reaction of H2O and AL if no inhibiting additive is in the elektrolyt. The H2 would be collected at the top of the cap, abd if the pressure is high enough the safety vent will burst.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        both. electrolysis starts the bulging.as it dries out esr rises and heating occurs.as the vent opens and more electrolyte is lost the cap looses capacitance and goes open.
        • whiz
          • Aug 2006
          • 48
          some stupid questions
          1)What is the "X" mark or the "T" mark on the top of the caps? is this the escape door?
          2)The electrolyte is it corrosive for our skin? is it dangerous to smell it?
          3)do we know the chemicals it contains?
          4) The thin metal film inside the cap what is it? aluminium or some other metal?
          thank you...
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            It's an intentional "weak" spot in the can. It make it less likely that the whole can will launch like a little rocket. The scorings vent at a fairly predictable pressure - electrolyte vapor and/or hydrogen. BTW, electrolytes with significant water content are not peculiar to crap caps: e.g. all Rubycon low impedance caps have significant water content, but Rubycon (the other two 'cons and Panasonic also) knows what to add to stabilize the electrolyte.
            As a whole, no, though I wouldn't use electrolyte as soap or a beverage.
            The basic ingredients are known publicly.
            Aluminum
            PeteS in CA
            • whiz
              • Aug 2006
              • 48
              quite interesting effect if they could lift off...
              thank you for the analysis...do you know any good sites so i can read
              about the composition of electrolyte?
              • VILE DISRUPTION
                • Jun 2006
                • 47
                probably google. try "capacitor electrolyte" or something.
                Stats Reset Every Month.
                My Forums
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Think this i somehow a secret wich is kept closed to the public. As today to mutch well skilled competitors in low cost countries are waiting for the proper rezept.
                  • arneson
                    • Sep 2005
                    • 1267
                    The write ups Iv'e read on this go quickly over my head but detail the tweaking of test solutions. Adding stabilizers, nuetralizers and removing water.
                    Lots of graphs and math. I don't think the prefered formular is secret but any improvements would certainly be, unless HP taps the phone.
                    Jim
                    • PedroDaGr8
                      • Oct 2006
                      • 130
                      Any chance that you could send me some of these, or the links / names etc. I am trying to find out as much of this as I can inorder to try and put together a plain english article on why capacitors vent (initially I was going to do some research but the Hillman et al. article is quite good on the research).
                      • davmax
                        • Dec 2005
                        • 899
                        I have used thsi reference before: http://industrial.panasonic.com/www-...ABA0000TE4.pdfBasically the internal cap pressure is claimed to be caused by excessive hydrogen. Good electrolyte formulae absorb the hydrogen whilst the bad cap brands have used an incorrect formula and excess hydrogen is the result. Too much and pop goes the vent.
                        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                        160Gb WD SATAII Server grade
                        Nvidia 8500GT 256Mb
                        160Gb WD eSATAII Server grade for backup.
                        Samsung 18x DVD writer
                        Pioneer 16x DVD writer + 6x Dual layer
                        33 way card reader
                        Windows XP Pro SP3
                        Thermaltake Matrix case with 430W Silent Power
                        17" Benq FP737s LCD monitor
                        HP Officejet Pro K5300 with refillable tanks
                        • PedroDaGr8
                          • Oct 2006
                          • 130
                          Nice article, covers a wide range of failure modes.
                          The mode of failure for the tiawanesse capacitors was investigated by Hillman et al. Article It appears to be more complex than this. The good electrolytes actually prevent the H2 generation in the first place. It seems that the bad electrolytes are usually marked by pH>=6 while the good ones are have a pH of around 2-4, bad electrolytes also seem to be lacking in phosphate ions compared to the good electrolyte. The reason that the pH is important, is that it degrates the aluminum oxide dielectric layer. Which I explain the mechanism in detail in this thread https://www.badcaps.net/forum/showthread.php?t=3047
                          The dielectric degredation is characterized by a gradually rising capacitance value (as the dielectric layer gets thinner and thinner) until there is a sudden spontaneous drop (dielectric layer is gone, now have highly conductive electrolyte bridging to plates).
                          • mbutts
                            • Dec 2007
                            • 2
                            Very informative thread!
                            on a side note
                            Eons ago when I was in college I was doing a lab project. I had an axial cap on a breadboard in a circuit and was attempting to take a voltage reading. The DVM counted down toward zero volts. Just be for it hit that magical number there was a very loud pop followed by small quantities of white hair like debris floating in the air. I had inadvertently put a cap in backwards and it blew up. One end of the cap was still on the breadboard, the other had shot to the ceiling and bounced back down on the bench top. Needless to say I got the attention of the rest of the lab. I picked up the piece off the bench and burnt the heck out of my fingers. Since then, it has been down hill with my love affair of bad caps and I replace them every opportunity I get.
                            Puppy Linux user
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Bit of caution as to:
                              The answers I see are pertaining to the low ESR caps this site is about.
                              I agree, those aren't especially nasty chemicals.
                              But other types of caps indeed have very some nasty stuff inside.
                              [off the top of my head.]
                              - The electrolyte in Tantalum foil capacitors may be as much as 40% sulfuric acid.
                              - Old oil filled caps may contain PCB's.
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Most "on site topic" caps are rated for 1v max on reverse polarity.
                                Reverse polarity strips the oxide layer off the aluminum.
                                (Due to electrolysis in the wrong direction.)
                                The oxide layer is the bulk of the dielectric (insulator) between the plates.
                                When it's gone the cap is effectively shorted internally. (Or partially so.)
                                More current. More heat. More gasses?. Thermal expansion?(electrolyte)
                                ~Pop~
                                - Dr Seuss
                                • DRHCREEK
                                  • 1
                                  Years ago while working on tube television chassis inside a wooden console, I saw an aluminum can electrolytic launch the can into the top of the wooden console. It planted itself into the wooden top enough to cause the top of the furniture to require refinishing.
                                  Caps in those televisons were 400+ uf's at up to 600 volts. They became grenades if installed incorrectly. Be very careful about ploarity when installing any cap.
                                  • Hondaman
                                    • Sep 2008
                                    • 1089
                                    Seven years ago, my vocational school teacher had his own HVAC business in the daytime and taught us at night. He told us a story once about a capacitor that blew on a rooftop air conditioning unit. He bent down to pick up a tool and heard it explode. It is a good thing he bent down.
                                    (I don't know why a capacitor the size of a 330 or 354 milliliter cola can would be mounted on its side, 5 or 6 feet above the surface of the roof. And I presume the power was off when it blew. What could cause such a time delay before the explosion?)
                                    Anyway, the top blew. The contents struck the cover panel of the neighboring air conditioning unit (because it was laying on its side). It was a hot mess.
                                    (Why would the capacitor blow after power was removed?)
                                    It is a good thing my teacher bent down when he did!
                                    (He also told us about the time he was working on a rooftop unit at a small corner food store [Dayton Ohio, probably late 1970s]. He came down from the roof to take a break and discovered that someone had brutally murdered the two workers and put their bodies in the freezer while he was working up there.)
                                    Anyway, be safe out there!
                                    • Uniballer
                                      • Jul 2013
                                      • 334
                                      I would assume the power was on. There are plenty of things an HVAC guy may want to do to a rooftop compressor with the power on (e.g. measuring refrigerant pressures).
                                      • Hondaman
                                        • Sep 2008
                                        • 1089
                                        Maybe the power was on, I'm not sure. The teacher gave the impression that "it wasn't supposed to happen", so I assumed the power was off and the cap was discharging. Please wear safety glasses around high voltage. And don't wear jewelry (wedding ring) which could cause a short or get tangled up with parts when working on stuff.
                                        • triplefour
                                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                          by triplefour
                                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                          he said it sometimes would just flash color patterns.
                                          and sometimes it would just work
                                          i figured it had some intermittent mainboard issue.
                                          i stored it at home for a while before looking at it
                                          when i plugged it in for the first time, i heard some popping noises
                                          and then a big cloud of white smoke came out of the back of the tv!
                                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                          i unplugged it and took the back off and discovered...
                                          12-18-2022, 12:38 AM
                                        • SwedishDiesel
                                          Panasonic caps - dried electrolyte on leads/bung from factory?
                                          by SwedishDiesel
                                          I just bought these from Mouser and upon closer inspection the area where the bung and leads meet has some dried green substance on it, presumably dried electrolyte. Is this normal?...
                                          03-03-2022, 06:06 PM
                                        • nmantas
                                          Nichicon radials without the X vent?
                                          by nmantas
                                          I recently bought some Nichicon caps on eBay (yeah, I know). These are small 4x7 radial 16V 10uF caps. I feel they are fakes because the plastic pattern on the bottom and they don't have the X-vent stamped in the aluminum end and all the datasheets I have read indicate there is a vent(not exactly sure what series they are....or are supposed to be). I don't really care about the couple dollars wasted but when I let the seller know he thought they were real and he doesn't want to sell fakes. I thought I would do a little research and let him know. Is the lack of the characteristic X enough to prove...
                                          02-15-2019, 08:00 PM
                                        • Perry Babin
                                          Electrolytic cap endurance
                                          by Perry Babin
                                          From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                                          Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                                          Why do polymer capacitors...
                                          10-18-2025, 05:21 PM
                                        • DrewPhillips
                                          Capacitor Diarrhea - Nichicon PL Series
                                          by DrewPhillips
                                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                          03-02-2025, 10:18 PM
