Hi guys. I saw some Amico branded capacitors on Amazon. They're really cheap and appear to of Chinese origin. Some of the reviews say they've used them for Audio repairs and various projects with good results. Nothing with respect to motherboards though. Anyone used this brand to recap a motherboard? Appreciate your feedback.
Amico Capacitors
Re: Amico Capacitors
Haven't heard of them. Sounds like they might be OK for general purpose usage, but motherboard filter capacitors are a very high stress usage. I would recommend not using them to repair motherboards.
I wish I could suggest something that would work for you - knowing what brands and series are good is relatively easy, but I don't know what would be available to you in Trinidad. If Newark, Farnell, Element14 or DigiKey (all are distributors, not manufacturers) sell to Trinidad, those would be good starting places.PeteS in CA
Sorry for the late response guys, appreciate your responses.
That's exactly the problem PeteS. Any of the quality items that I need must be imported. Most of what's available here are generic brands...you never know what you're going to get.
I took a chance and ordered the Amicos already though. The set I ordered were labelled specifically for Motherboards. They should be here sometime this week. I'll install them and report on how they fare.
Thanks again.Comment
If they are ordinary low ESR, it will probably work OK, but they will not last very long.
If they are general purpose I don't expect them to work at all.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I got them and replaced 4 bad caps on a Dell Dimension 4550 Mobo. The board is behaving the same as before: sometimes it boots to bios, but at no time does it get to the OS splash screen.
Can't say for certain that these new caps are no good as the mobo may have other problems with it.
I've attached a couple of pictures to show what they look like.Attached Filesif you find these attachements useful please consider making a small donation to the site
The ones in the picture aren't Amico, they're made by ChongX :
http://www.chongx.cn/en/cp_view.asp?id=567
But on their site , the CD110X are only rated for 2000h @ 85c
Still crappy capacitors but they would at least get the board running. But your motherboard probably also has some capacitors that are not swollen or visibly bad and those still affect how the board works.Comment
No, Chang are Changzhou Huawei Electronics Co., Ltd and they're basically from 1987, so they should know something about capacitors:
http://www.huaweiec.cn/product_list_e.asp
I didn't see a lot of them fail, and even my Tenma linear power supply uses Chang exclusively and I'm not gonna bother replacing them.
These ChongX are (supposedly) made by "Changzhou Hua Hong Electronics Co.", and these started in '98.
They seem to be copying the Chang logo (but it's O instead of A and the N is much thinner)
http://www.chongx.cn/en/about.asp
later edit: and there's also chengx, chong etc.. clones or relabeled or no longer made stuff : http://translate.google.com/translat...chengx&act=urlLast edited by mariushm; 01-04-2013, 04:24 PM.Comment
cheap capacitors are never a bargain - just import the good stuff (Rubycon, Chemicon, Panasonic, Nichicon) and even if it seems expensive, it is still a very cheap way to get a computer running again.
PS - Cheech & Chong brand is my favorite!
the BIG 4
~~~ the top tier of low-ESR electrolytic capacitors ~~~
beat me to it!
Those are utter garbage, but one would expect them to at least get the board up and running for a few days. Pop open the power supply and have a look, you probably have a bunch of bad caps in there too.I got them and replaced 4 bad caps on a Dell Dimension 4550 Mobo. The board is behaving the same as before: sometimes it boots to bios, but at no time does it get to the OS splash screen.
I've attached a couple of pictures to show what they look like.Comment
by qwerty99Hello!
I need to change the capacitors on my three original Xboxes.
Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t... -
by amelbyeHi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
I have already replaced the PSU.
The board is a gigabyte x79 ud3....-
Channel: General Capacitor Questions & Issues
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
After all of... - Loading...
- No more items.
