Sharp LC-46D64U Image flickers then dies
  • Mikey130
    • 5
    • United States of America
    Hello, I have a Sharp LC-46D64U that I recently acquired that is having some weird problems. When I first received the Television set I could not get any signs of life besides the power light, which flashes green at a steady interval. After some research I discovered the reset trick, (Channel down, volume up or the other way around while powering up the set.) After doing the reset I had some signs of life and thought I had fixed the set. My excitement was short lived, the set powered on, flickered 3-4 times then died. I could make out the input selector menu before it died and that was it. If the set is power cycled then the same results will occur. Occasionally it will go back to the power light flashing, which I assume is some sort of error code but I can not find out what it is. I pulled apart the set figuring it might just be a bad cap or something having fixed a couple monitors and sets before with bad caps/boards. To my dismay it had no bad capacitors or anything obviously wrong with the boards. After this I began research and troubleshooting, I've done the following:
    -Checked Pre-power board, it is outputting 120 volts as desired.
    -Checked all outgoing voltages from the main power board, all are within 1 volt of desired voltage.
    -I have unplugged all input/tuner boards and received the same effect so I do not believe it is them.
    -If I unplug the TCON board I get similar results before the set shuts off 3 flickers in and throws me a error code, so I do not believe it is the tcon board but I am not sure.
    -I have also noticed the mainboard has two red LED's that turn on and off seemingly randomly while the set is on, I don't know if this means anything.
    Any thoughts on what the issue might be and how to troubleshoot further? I've read some places I should check the transformers on the inverter board but I do not know how I would go about this. Any help would be appreciated, thank you.
  • martyparish
    • Dec 2012
    • 313
    Re: Sharp LC-46D64U Image flickers then dies
    Have you tried unplugging the inverters and then powering up w/ main hooked up?
    • randtek
      • Oct 2011
      • 280
      • US
      You haven't been very specific about the LED flashing, what error code are you getting? Is the green LED flashing fast or slow? I think you are probably looking at a lamp error, if the green LED is flashing at a steady rate of 1 flash/second. To get the most help, you should submit some good clear photos.
      • Mikey130
        • 5
        Marty - Unplugging which cable, the inverters all together?
        randtek - It would be hard to display the flashing in a picture, I will post a video tomorrow, I would say 1 flash per second.
        • randtek
          • Oct 2011
          • 280
          • US
          Sorry, I was not clear. I meant photos of the boards and the back of the set with everything connected. Clear photos with enough resolution to read lettering on the boards.
          • drpj23
            • May 2012
            • 528
            1 flash per second is an inverter failure
            On Sharps it may be worth it to check for bad CCFLs
            • tieny
              • Feb 2012
              • 478
              I'm guessing most likely a loose ccfl lamp connection (could be a bad lamp also). Or a bad inverter board (a bad transfomer on it).
              When the set flickers and then goes off, try shining a flashlight and see if you can make out any pictures on the screen. (still could be hard to see) If you can see a faint picture then the problem would be with the ccfl or the inverter board.
              • Mikey130
                • 5
                The flashlight test was one of my first tests, I will repeat the test though just to make sure. Also how do I test transformers, can i test the whole board at once or individually? Also where to the CCFL's connect?
                • drpj23
                  • May 2012
                  • 528
                  If it goes into the error mode (flashing) after the flickering then there will be no visual since the set is shut down.
                  • tieny
                    • Feb 2012
                    • 478
                    I had a sharp that turned on for a second with a green led but then the screen went dark and the led went blinking red, but I did still see snow on the screen and the input menu. Not sure but I did find it odd. It turned out to be a bad transformer on the inverter board.
                    You can measure the resistances of the pins of the transformers and compare them with the others.
                    But sometimes I find it difficult to test transformers... I measured the pins before but it read out of range for my meter. (or it was just open circuit but I wouldn't know)
                    Or the tedious way, You could tear down the TV down to the backlight ccfl's, (The lcd panel is extremely fragile!, so careful with it and the tab bonds on the sides of it) then plug in the TV and see if you can see if there's a bad ccfl.
                    • Mikey130
                      • 5
                      Mmmkay I will try testing the transformers, I take it that I have to take the inverter boards off the TV to test them? Also pictures are being a PAIN to upload for some reason, I will try and upload them tomorrow from a different internet connection.
                      • Mikey130
                        • 5
                        Pictures don't want to upload so I will have to use my phone, what pictures specifically will be helpful so I don't use all my data up? Also tested the transformers and didn't get any extremely abnormal results, all are within 10 ohms of each other.
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          09-06-2024, 10:56 AM
                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
