bad caps of the 1990's played havoc with car ECU's
  • theOracle
    • Nov 2012
    • 163
    the Nichicon PF (M) series from the late 1980's through most of the 1990's had leakage issues, these caps played havoc with many automotive ECU's, especially high end Japanese cars. (i.e. Lexus LS400, Toyota Supra, etc.)
    The problem was the use of quaternary ammonium salts.
    the following capacitors from this time period had issues:
    Nichicon: RZ, RT, VZ, ET, PR, PY, PF, PL, PQ, PG, MX, WX, WP, MP
    Nippon Chemicon: LXF, TXF, SXE, SXG, MVK, MFK, MVF, MFF
    Elna: RSH, RSG, RSE, RC2S, RC3S
    The production of capacitors that contain quaternary ammonium salt compounds was ended in September 1998. The final one was Nichicon PF series. The PF series was kind of special version with expensive materials both rubbers and lead wires used. These had extended lifespan over the other caps above, but still it was shorter than conventional ones.
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • japlytic
    • Oct 2005
    • 2086
    Re: bad caps of the 1990's played havoc with car ECU's
    I've seen Nichicon low-ESR units from around that era go bad (and found to be leaking). Also, I have seen certain series of Rubycon electrolytics from around that era go bad too.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      ^ Do you remember what series those Rubycon capacitors were (if you don't mind me asking, just out of curiosity)?
      • japlytic
        • Oct 2005
        • 2086
        One of them included SSP series.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I remember finding a blown Elna listed in a 1997 Pioneer headunit... sadly, that wasn't why it was fried (PO overdrew it's power)
          sigpic
          (Insert witty quote here)
          • dmill89
            • Dec 2011
            • 2534
            Although I'm not sure they it so much an issue of "bad caps" as decent caps that have exceeded their lifespan and failed. An engine compartment is a rough place for a capacitor with massive temperature extremes, and the vehicles in question are now 15+ years old.
            • PaulMc
              • 5
              I understood the OP to mean that the caps failed during the '80s and '90s. Not that they were now failing. I remember a lot of ECU problems during those decades. Did I misunderstand? At the time I was working in the HVAC field and solid state boards were just becoming common in a/c and heating equipment. Now I wonder if some of the many failures were due to bad caps.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                But, most of them at least lasted longer than many caps of the early 2000s.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Nichicon PR definitely seem to have that problem. I pulled a small bunch from an old monitor/TV board and almost all of them have started to leak from the bottom, especially in the last 3-4 years I've had them in storage.
                  • lti
                    • May 2011
                    • 2557
                    I have a dead socket 7 motherboard from 1997 with Nichicon PL caps on it. They haven't started leaking yet.
                    • theOracle
                      • Nov 2012
                      • 163
                      yes, this is exactly the point
                      the best of these bad caps I listed, the Nichicon PF (M) series was the most premium cap money could buy in the mid-90's and generally lasted at least 10 years before leaking and failing.
                      they were used in some high end luxury cars such as Lexus
                      actually they were bad caps in the sense that their lifespan was prematurely short, but still generally 8-10 years or more. The error of your thinking is that automotive ECU's live in the harsh and high temperature engine compartment, they don't, they are located in the climate-controlled passenger compartment, typically in the passenger side kickpanel, behind the glovebox, under the passenger seat, etc. - The auto manufacturers wised up very early to the fact that the main computer for the vehicle needed to live in a gentle environment, as it is so critical and may control not only the engine, but the transmission and climate control as well.
                      the BIG 4
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        • USA, Unsure of Planet
                        momaka, Nichicon stoped making the PR series in 2005 or 2006, IIRC. So at the least, thse PRs are 7 years old, and thePR series was a 3000 hour series (at rated max temp and ripple current), IIRC. These things have a finite life, even in storage.
                        PeteS in CA
                        • dmill89
                          • Dec 2011
                          • 2534
                          That depends on the vehicle. I'm not too familiar with these 80-90s high end Japanese cars so that may very well be the case with them but it is certainly not the case with all vehicles. Both of my vehicles have the PCM/ECM under the hood. My 95 Jeep Cherokee (4.0L I6) has the PCM mounted on driver side inner fender, on the same side of the engine as the exhaust manifold to be specific. Even many late model vehicles still have the PCM/ECM under the hood, my 07 Pontiac G6 (3.5L V6) has the ECM mounted in front of the battery, right behind the driver side headlight, this is significantly farther away from heat sources and offers much better ventilation than the PCM location on the Jeep but is still under the hood. While the Pontiac G6 may be discontinued (since Pontiac no longer exists) it is based on the GM epsilon platform and virtually all current GM midsized vehicles use the same design including the Chevy Malibu, Buick Regal, and Opel/Vauxhall Insignia.
                          • severach
                            • Aug 2007
                            • 1055
                            The entire car varies from -30*F to 150*F. The engine isn't substantially worse than the interior. In the winter the interior varies more than the exterior. The newer the car the more modules it has and they place them randomly inside or outside the passenger compartment.
                            sig files are for morons
                            • PeteS in CA
                              • Aug 2005
                              • 3583
                              The entire car ... hmmmmm ... I lived for several years in the Phoenix, AZ area. I could easily believe the engine area getting up to 150F and the passenger area up to 125F or 130F, but I doubt the passenger are got much hotter than that. OTOH, I could easily believe temps in Nome AK or Anchorage, AK getting lower than -30F.
                              But the basic point is true. There's no part of the car that doesn't get exposed - possibly for short durations - to significant temperature extremes. In more practical terms, Part 1, 130F is >55C, and when the electronics dissipate heat that will raise the ambient for those electronics close to their maximum ambient temp. In more practical terms, Part 2, -30F is getting close to the minimum rated temp for low impedance types like Nichicon's HE series, and at that temp the impedance will be up to 3X-8X the 20C impedance (both per Nichicon's datasheet).
                              PeteS in CA
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                I've recapped quite a few Mitsubishi 3SI ECM's (Stealth and 3000GT). Back in the 80s and early~mid 90's, the bad cap issue wasn't even on the radar...but looking at it today, does it really surprise anyone that 20+ year old electronics are failing? It shouldn't....hell, some of these cars, the manufacturers never intended to still be around that many years later.
                                <--- Badcaps.net Founder
                                Badcaps.net Services:
                                Motherboard Repair Services
                                http://folding.stanford.edu/
                                Team : 49813
                                Join in!!
                                Team Stats
                                • larrymoencurly
                                  • Oct 2004
                                  • 960
                                  Engineers at the GM test track east of Phoenix, in Mesa, measured over 160F in the passenger compartment.
                                  I have a TV digital converter box that needed most of its capacitors replaced in the first 2 years. In comparison the vintage 1976 TV connected to it still works and has needed just 3 of its original white Sanyos replaced. I credit the protective powers of the TV cabinet's fake wood grain,
                                  • theOracle
                                    • Nov 2012
                                    • 163
                                    maybe inside ECU placement is a Japanese thing
                                    I have owned
                                    1984 Nissan 300ZX
                                    1986 Nissan 300ZX
                                    1992 Honda Accord EX
                                    1996 Lexus LS400
                                    1996 Acura RL
                                    1997 Toyota Camry
                                    2000 Toyota Avalon
                                    2004 Lexus LS430
                                    ECU location on all of these cars was inside car (usually passenger side area)
                                    the BIG 4
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Well, mine are actually from the early-mid 90's - so yeah, they are quite old indeed. I've seen (and have) older caps that still work fine, though. The fact that all of my PRs leaked from the bottom (I have like 10 or so) just tells me that perhaps they did have some problems (though probably nowhere near as bad to call them "bad" or "unreliable").
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3583
                                        True. I remember seeing some Sprague axial lytics (30D series, IIRC) that had to be replaced in 2007 ... the date code on the parts was 1977.
                                        PeteS in CA
                                        • dreamlayers
                                          Weird clipping on Logitech Z-10 speakers
                                          by dreamlayers
                                          I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                                          05-22-2025, 11:41 AM
                                        • x_orange90_x
                                          LG 55UP7000PUA washed out and dim
                                          by x_orange90_x
                                          So I've got this 55UP7000PUA that has a very washed out and dim image. I've played with all of the settings, turned brightness to 100 as well as panel backlight, made sure no eco settings are on, etc. It looks like the backlight is at 50% or even less. I've been reading online that this is a pretty bad model with poor contrast and image retention issues, but I haven't seen anyone say it's dim like this. I've seen quite a few LGs with bad backlights before and they are usually blue. This doesn't appear blue, just washed out and dim. I've likewise never seen ANY backlights simply dim as a failure....
                                          11-07-2025, 05:43 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
