Pic of cap, is it a Badcap?
  • r-p
    • Feb 2013
    • 44
    • Netherlands
    Following from another article on here where I used my powersupply and I got some strange readings, I accidently opened up my SMPS:
    Is this cap broken?
    It is a 0-30V 0-10A PS and it had a flickering currentlimiting LED at 20V and 4.5A. It has never delivered full power at lower voltages, but 7-8A was never a problem.
    The cap, as far as my limited knowledge goes, is not damages: it is just a lacquer type top that appears cracked. I plan on opening it up again eventually, but all my high voltage caps are not available right now (behind several kW of solarpanels that need to be mounted first... I do have a 400uF 350V very old cap that might fit).
  • DaveHignett
    • Feb 2013
    • 3
    • England, UK
    Re: Pic of cap, is it a Badcap?
    Hi!
    Have you tried clipping a lead and testing the cap? I'd try an oscilloscope on the output of your PSU to see whether there's an excessive amount of ripple etc. The cap in question looks like a big old smoothing cap, so if it has passed it's best, then I'd expect a lot of movement in the output of the PSU. On the other hand, you're dealing with relatively high currents, so heat won't be in short supply inside the case of the PSU, so it's inevitable that the laquer will have seen better days really.
    Hope this helps!
    I'm Dave by the way!
    • c_hegge
      • Sep 2009
      • 5219
      Looks like the rubber seal is ripped. It's hard to tell whether it's leaking or not, though. Is the area around the hole wet?
      • r-p
        • Feb 2013
        • 44
        • Netherlands
        Not sure my scope (old one being thrown out at work) works, but that's a good idea.
        It could be hardened rubber instead of lacquer.
        And it's not leaking anything.
        I recently acquired an LCR meter, so I could (and planned) to measure the capacitance, but not sure if a proper reading there would tell you something about its behaviour when needing to deliver full power.
        I'll follow up once I get new info. Thanks guys!
        • c_hegge
          • Sep 2009
          • 5219
          If it's not actually leaking then it's probably still OK.
          • r-p
            • Feb 2013
            • 44
            • Netherlands
            Follow up: when getting the cap out I couldn't even hook it up to the LCR meter as the lead fell off.
            I did not have a proper cap at hand, and parallelled two 100uF 400V caps. It was/is a simple smoothing cap for the 230V input, so the powersupply works perfectly with the smaller capacitance.
            I had a better suited cap, but the diameter was too big (it is a very shallow (~5cm/2") powersupply).
            Will keep looking for a better replacement, I even have plenty, but they are in powersupplies I might need lateron for projects... For now, it works just fine.
              • 31303
              it's bad.
              i'v not seen one of those in a very long time, it's an epoxy sealed cap.
              they poured epoxy over the rubber bung to stop it leaking so easy.
              if the resin is pushed out like that then it's gassed.
              your gonna love how much smaller the replacement will be!
              • r-p
                • Feb 2013
                • 44
                • Netherlands
                Thanks for the background info!
                I'm Dutch = I'm tight
                So replacement is probably from my own collection, so likely not much younger
                But you're right, in the same volume, I could probably fit 4x150uF 400V caps from a more modern serversupply (the one I didn't want to sacrifice yet for this)...
                This forum is not good for me... I don't want to acknowledge that caps age, not with a big load of 75V caps from the early 80's (~400,000uF) and probably close to a Farad in 50V caps from that era...
                • r-p
                  • Feb 2013
                  • 44
                  • Netherlands
                  Follow up: I replaced the cap with a (probably) Chinese capacitor of pretty much same size and little bigger capacitance and it worked perfectly. (450V 470uF 105ºC iirc instead of the original Sprague 400V 390uF 105ºC cap)
                  I made a joke about the thing only living for ~25 years before failing on a Dutch electronics forum (the powersupply is from a VERY reputable Dutch powersupply maker, not to be confused with powersupply makers with the same name from other countries. E.g. >90% of schools with technical subjects in the Netherlands will have several of this brand and many will be decades old).
                  I then got a private message from someone within said company saying I should have contacted them, and I would have received a new capacitor. And that the used/failed capacitor was the absolute best they could get at the time the powersupply was constructed.
                  Long story short: I received a new capacitor (and placed it instead of the Chinese one) and new adjustment knobs (even though I only asked for the caps of the knobs) for the powersuppy free of charge.
                  How's that for service... free replacement parts for a device that was well over 20 years old when failing.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    That's pretty cool
                    Too bad the pics are lost in the first post, if you still have them I can re-upload them...
                    • r-p
                      • Feb 2013
                      • 44
                      • Netherlands
                      Hi. Since I never throw something out... it was easy to find the old cap again.
                      The blue one is the old cap. The brown one is the replacement sent by the company. But it is build-in, and obviously the text is on the bottom side
                      The second pic is where the 'laquer' was broken, but no obvious spillage of any kind.
                        HP OMEN 870-010a OMEN i7-6700K Specification for Upgrade or Repair
                        This specification for the HP OMEN 870-010a can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN 870-010a boardview and OMEN 870-010a schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP OMEN...
                        09-12-2024, 03:44 PM
                      • titomno2
                        Surface Pro 7 1866 won't turn on...
                        by titomno2
                        Hi guys,
                        Just have a surface tablet pro 7 (type 1866) with motherboard JALAMA_ICL_MB DV:2.0.
                        Can't power on the surface tablet, no reaction on the button whatever the charger (working) is plugged in or not.
                        After dissassembly I made a physical inspection without seeing any damaged component (nothing visible at least).
                        Made measurement:
                        With battery (low voltage 7.9V) the led D7013 is on (red)
                        Charging seems odd and decided to let it apart and working only with DC input.
                        With power supply 15VDC (white light on the charging cable).
                        D7013...
                        02-23-2025, 07:59 AM
                      • corrize
                        How to find smd badcap onboard ? (Tool, method)
                        by corrize
                        Hello, if 5 capacitors are in parallel, and one of them is shorted, how to find the shorted one without disolder anything ? And except courant injection.
                        It's seems not possible but maybe there is trick or tool working ?
                        Ultra low resistance meter ? Maybe with heat ? If cap is shorted, it become conductor, so conductor of heat too. And maybe a heating element at a side of cap and thermalmeter at other side and mesure time for reach a valor ?
                        So have you seen or tested such tool or method pls ?
                        06-08-2021, 06:46 AM
                      • pixelcap
                        Pioneer Plasma 111FD To Solder or Not to Solder.
                        by pixelcap
                        Hello out there in Badcap land.
                        I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
                        are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
                        Thank you
                        Pixelcap...
                        03-08-2025, 07:10 PM
                      • lapfix
                        Asus X540UB no vcccore
                        by lapfix
                        Model :Asus X540UBR
                        M/b: NX540UBR Rev 2.0
                        Problem: turn on when PSU cable is inserted, consumption 0.106 amp .No display.
                        Observation:
                        1. No liquid spill or corrosion observed.
                        2. 3v/5v alw present.
                        3. 1.2/+vtt/+2.5v present
                        4. 1.0VSUS present
                        Diode mode value :
                        Pl 8901 = 05.16v
                        Pl 8701 = 0.354v
                        Pl 8702 = 0.258v
                        pl 8600 = 0.358v
                        Pl 8302 = 0.059v
                        Pl 8103 = 0.007v
                        Pl 8102 = 0.007v
                        Pl 8101 = 0.011v
                        Pl 9101 = 1.030v
                        Pl 9100 = 0.030v
                        So No vcccore , no +nvvdd...
                        09-29-2022, 03:01 AM
