The fuhjyyu's in my monitor finally went tits up today.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    7 years ain't too bad for them to last I guess considering it has probably spent the last 5 years powered on.
    Basically over the last couple weeks I noticed the monitor would "grey screen" every time my PC rebooted, and the only way to get rid of it was to pull the plug on the monitor and plug it back in. Then it would work just fine. But today it was cold in the house, the power had went out for a few hours, and when it came back on, the monitor was stone cold dead... not even the LED was working.
    Cracked it open, yanked off the PSU board, didn't even bother testing output voltages just started yanking caps. On the 12v rail there were three 470uF 25v TM series Fukiyoos, the two in parallel right after the rectifier diode measured 33 and 64 ohms each, and had absolutely no visible signs of failure. The third fukiyoo was after the low pass filter inductor and it measured 0.09 ohms... not dead yet but definitely on the way out. The only two half assed suitable caps I had were two ancient HFQ series panasonic caps... and when I say ancient they stopped shipping them in 2000. But, the ESR on the caps were below the max spec and the capacitance checked out OK so I slapped em on the board. Since I was a cap short, I put the fukiyoo with the low(er) ESR in after the low pass filter. Blech.
    On the 5v rail, the single 1000uF 10v TM series cap after the rectifier measured 0.24 ohms, the other after the low pass inductor I didn't even bother checking. Had some NOS Rubycon ZL's laying around, so I slapped those in. On the power supply's main PWM controller subcircuit there was a lone 47uF 25v cap. Guess what the ESR was? 8.9 ohms. And of course it just had to be a low ESR TM series too. Only thing I could find to drop in its place was an Elna audio grade cap. I don't know what its specs were, but the ESR was .78 and it was rated 105C so I slapped it in. The last cap on the psu I replaced was a LE series Hermei rated 220uF at 25v or however you spell it on the inverter pwm controller subcircuit... it measured 2.4 ohms and just like the fuhjyyus it didn't show any outward signs of failure. I didn't have anything in this exact value, but I did have some ancient (and not to mention huge) NOS 220uF PL Nichicons laying around, and since there was room on the PCB to mount it I slapped it on the board.
    After I got the psu pcb back in the monitor, plugged it in, turned on my pc, and the monitor fired right up.
    But, alas I figure this is at best a temporary fix for everything but the ZL's which I figure can stay since their ripple ratings and ESR is lower than the fukiyoos TMs. So, I need to order some new caps... which ones should I go with to replace the TM series, Panny FR or FM, or Nichicon PW, HD, or HE?
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    10-30-2025, 04:45 PM
  • wattage
    AOC AG493UCX 49-inch monitor - Firmware request
    by wattage
    Hello Badcaps Community,
    I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
    Wise Wing F199 19'' LCD monitor - recapped
    by momaka
    Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
    I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
    When I saw the Craigslist post, I wasn't...
    08-24-2020, 10:58 AM
  • sew333
    Pc shutdown, monitor flickered with no signal after 10 seconds
    by sew333
    My pc:
    10850K stock 4800mhz stock Kraken X73 good temps
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming OC
    Aorus Z490 Pro Gaming
    1 TB SSD
    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
    Power...
    02-22-2022, 10:27 AM
