Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 03-30-2013, 08:28 PM   #1
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
Lightbulb List of pin-compatible PSU ICs
I figured out this forum needs one. I just found that a rather obscure PWM/supervisor chip was pin-compatible with another rather obscure PWM/supervisor chip that i happened to have lying around (and thought i'll never find an use for). Successfully swapped one for the other and brought another PSU back from the dead. Anyone's free to chime in, so here we go.
The ones everybody knows about (or should know):
  • TL494 = xx494 = KA7500B
  • TL431 = xx431
  • UC384x = TL384x = AS384x* = FA1384x*
*The AS384x (Astec) and FA1384x (Fuji Electric) are pin-compatible with all other 384x chips but are spec'd a little differently, so caution is advised.
And the obscure one i found about today:
  • Chip Goal CG8010DX = Weltrend WT7520
Another obscure one off the top of my head (fairly sure it's correct, but do your own research before you try):
  • DAP015D = L6599D
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 03-31-2013, 03:29 AM   #2
Khron
City & State: Valkeakoski
My Country: Finland
Default Re: List of pin-compatible PSU ICs
I've got one more for ya:
CM6800* = ML4800 = FAN4800 (the CM's supposed to be a CMOS version for the ML; supports a slightly higher supply voltage)
Khron is offline   Reply With Quote
Old 04-09-2013, 06:51 AM   #3
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Ir3m02 = tl494
japlytic is offline   Reply With Quote
