samsung syncmaster SA350 no picture
  • alihomee
    • Dec 2012
    • 1585
    • malaysia
    This led monitor have power and also when turn it on it shows no single massage but when plug it to VGA or HDMI cable it goes blank and shows nothing i resold already the chip on the card but still same................any ideas.....model no:s23a350h model code:ls23a350hs/xm
  • re-atari
    • Oct 2010
    • 136
    Re: samsung syncmaster SA350 no picture
    Search this forum and you will find these threads:
    https://www.badcaps.net/forum/showthread.php?t=26922, post #14 in particular,
    https://www.badcaps.net/forum/showthread.php?t=29242
    and
    https://www.badcaps.net/forum/showthread.php?t=29307
    You only need a piece of software you can download from Samsung's website to get your monitor back up and running again. Instructions are in the above mentioned threads.
    re-atari
    • angel-boy
      • 550
      • Romania
      hy , i try to update firmware from pc, but no working , the pc not see the samsung monitor when plug.
      i can try to update the FLASH IC401 25X40BVSIG but i dont have the bin file.
      • diif
        • Feb 2014
        • 6978
        • England
        You need to install the driver before you can instal the firmware.
        http://www.samsung.com/hk_en/support.../LS22A350HS/XK
        • angel-boy
          • 550
          • Romania
          the driver for S22 A350H is the same for S23 A350H ?
          • diif
            • Feb 2014
            • 6978
            • England
            http://www.samsung.com/sg/consumer/p.../LS23A350HS/XS
            • angel-boy
              • 550
              • Romania
              i install the driver, i try to update firmware but is up to date.
              any ideea ? tks
              • angel-boy
                • 550
                • Romania
                someone help please ?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5040
                  • New Zealand
                  What happens when you try to flash?
                  -David VanHorn
                  • angel-boy
                    • 550
                    • Romania
                    I did not have the file to be written.
                    I need a flash rescue from a functional monitor.
                    I realy need some help .
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5040
                      • New Zealand
                      Doesn't the firmware file come with the update utility?
                      -David VanHorn
                      • angel-boy
                        • 550
                        • Romania
                        i install the driver on win7 64b , i try to update firmware but is appers up to date.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5040
                          • New Zealand
                          What's the EEPROM size? I downloaded the firmware updater program, and ran universal extractor on the updater utiity. It found some 512KB files that in a hex editor, look suspiciously like a monitor firmware image. BUT I have no idea if they are correct or require some kind of editing first.
                          If you can backup your EEPROM and compare with these, maybe they are correct. There are 69 of them though....
                          -David VanHorn
                          • angel-boy
                            • 550
                            • Romania
                            Thanks , i will backup tomorrow EEPROM , but when make backup at FLASH IC401 25X40BVSIG , will not save one .bin file ?
                            Or when i save .bin file, then use "universal extractor" and see how many files are, or compare each file size ?
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5040
                              • New Zealand
                              You will get only one .BIN file when you backup the EEPROM.
                              I ran universal extractor on the "FirmwareUpdater.exe" file that comes with the SamsungFirmwareUpdater program, which resulted in the extraction of some 69 potential BIN files, and I don't know which one you should flash, or if they are even valid firmware images at all.
                              It looks like the size is right though, since you have a 4Mbit chip.
                              After you backup the EEPROM, can you upload the resulting file here?
                              -David VanHorn
                              • angel-boy
                                • 550
                                • Romania
                                i manage to backup the EEPROM,, but i cannot extrat file from main.bin ,
                                i upload here
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5040
                                  • New Zealand
                                  You don't need to extract anything from main.bin. Main.bin *is* the firmware image.
                                  I just want to compare it to the ones I found in the SamsungUpdater, see if they are plausibly correct.
                                  -David VanHorn
                                    any ideea ? tks
                                    But did you run the update anyway since the firmware may be corrupted?
                                    https://cdn.badcaps-static.com/pdfs/...4b5e8fc605.pdf
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5040
                                      • New Zealand
                                      I looked at your file, and a few of the ones that came from the updater utility, and comapared in a hex editor.
                                      The files are the same length, and the overall structure of the files is similar, and many blocks of data match up, although some data which match are shifted a few bits and some data is different. I don't know enough about this kind of thing to say why that is.
                                      Maybe some is config data which will change depending on user settings? I don't know.
                                      I don't know why there are 69 different files in the updater - I can't imagine there would be 69 different versions of this monitor, so I don't know why there are so many there. They aren't all the same as each other, that's for sure.
                                      -David VanHorn
                                      • angel-boy
                                        • 550
                                        • Romania
                                        i try to update firmware but appers that is up to date and a button to close.
                                        i can erase the flash , and then see if needed update ?
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • soopacrucial
                                          Samsung Syncmaster 740BF repair
                                          by soopacrucial
                                          Hi folks,
                                          I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                          Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                          10-29-2024, 02:40 PM
