so my computer is being a real ass. the ICH7 USB controller seems to have decided to quit on me under windows, well the driver anyway. all the basic windows USB drivers are not loading and device manager gives a code 10. i have been accessing the pc using remote desktop from my server box which is far from ideal... any ideas why this happens? i can get the ports working for 1-2 reboots by uninstalling them in device manager... to me it almost sounds like malware or a script kiddy... any advice what to do bar reinstalling windows? today is not my day haha...
USB Hub Code 10
Re: USB Hub Code 10
Check to see if it is loaded on your system any version of USB driver by Prolific.
By uninstalling it, your system will return to normal. -
Follow the white rabbit.Comment
Re: USB Hub Code 10
Have you tried running hitman pro to see if there is any malware / rootkits your regular av isn't finding?
Kiriakos was referring to other drivers that interfere with the usb, you have to look at more then just the ich7 drivers.
Why are you having to reboot this computer so often that you know it goes bad after 1-2 boots?Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
Re: USB Hub Code 10
no i have not tried hitman pro. long story short mother was complaining about slow internet and decided to turn it off... its never been the same since, first a fan bearing quit and then the USB ports wont work under windows. any linux distro they are fine
i can update to the latest drivers or uninstall them and they will work/reboot will make them work, but after that dead again. the reason for massive reboots is looking for virii/spyware
would the reboot potentially indicate a cap issue? (but then again everything works perfectly in the bios, bootloader and linuxLast edited by luke10050; 08-18-2013, 03:45 AM.Comment
Re: USB Hub Code 10
its a driver incompatibility the drive could be colliding with a driver for say a broadcom chip or a card reader or etc that wouldnt have an incompatibility with an older driver, or it could be an older driver on the system causing it.
strip the drivers that aren't used anymore, update ALL the drivers and it may fix your system and may give it a speed boost.
take it from somebody who has read the winNT source code, the way windows is built opens it up to a very high potential for conflicts between drivers. other os's only have a fraction of the potential for driver conflicts that windows has..Last edited by goontron; 08-18-2013, 12:18 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Re: USB Hub Code 10
ramdisk drivers? oh thats right you need 3rp party ramdisk software with windows[/end MSFT mocking]
Last edited by goontron; 08-18-2013, 03:09 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by CurtissimoHi everyone.
I have a HP Elitebook 850 G8.
Serial: 5CG2324XM0
ProdID 6L8D5EC#ABA
It has a Winbond W25Q256JVEN Chip.
I need to remove BIOS Password.
I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
Attached my dump.
I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
What I did:...-
Channel: BIOS Requests ONLY!
by Sorrow1Hi,
I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
When I recorded video of POST card and played it in slow... -
by DynaxSCHi Folks
I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works... -
by FZDHello everyone!
I am trying to fix an old Intel D5400XS (Skulltrail) motherboard, which gets stuck in a loop on error post code 29 after successfully initialising the RAM and before the next code that is supposed to enumerate the PCI buses (post code 50).
I should point out that absolutely everything has been tested so far: resetting the BIOS, booting with a single CPU (cross-testing), with a single RAM module (each module tested), changing the power supply, changing the graphics card, disconnecting all peripherals... and that all the components work perfectly on another...Today, 10:30 AM - Loading...
- No more items.
