What's the ideal operating temp for capacitors?
  • TELVM
    • Oct 2012
    • 547
    • Spain
    We know heat is bad for them, but there is a such thing as excessive cooling for capacitors?
    For instance, could a constant 21C internal case temperature be 'too cold' for the polys/lytics inside a computer?
    What's the ideal operating temp for them?
    (Just for laughs ): The Ice Cap & The Submarine Vents
  • Heihachi_73
    • Jun 2012
    • 713
    Re: What's the ideal operating temp for capacitors?
    I had a feeling it would be Rodalco or someone like that.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      There is a tradeoff of course, actually cooling by peltier is better than fan because fans will encourage evaporation. However if things get too cold where liquid electrolyte freezes, that's a problem. Also cooler temperatures will reduce ion mobility, increasing ESR (that's why some capacitors work better when heated.)
      I think there is a happy point but in terms of overall performance, but for lifetime you can't do better than keeping it cool, just don't freeze them.
      • tmiha71
        • Apr 2010
        • 130
        Hard to say, but recommendation is to use capacitors with lower value of Z-25℃ / Z+20℃ (quotient of impedance at -25 degC and impedance at 20 degC ). That will result in lower deviation...
        In datasheets usually defined at 120Hz, but (probably) can be applied to higher frequencies - capacitors with higher quotient will have higher impedance than capacitors with lower quotient, probably valid for increase in temperature too...
        Some datasheets give information about impedance versus temperature - if there is that info it should be consulted first...
        Some datasheets give information about capacitance versus temperature, if we presume higher capacitance leads to lower impedance (always true), it's safe to presume higher capacitance also leads to lower ESR...
        To emphasize - deviation is bad, leads to shorter lifespan of electrolytic capacitor...
        You should search through this forum, think there was posts about this issue, and some info about other types of caps.
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 335
          • D12
          Didn't want to open new topic cause it's temperature related. I have VCR power supply with one cap that is 85C graded, can I replace that one with 105C one would that make any problem ? I know PSU that needs to have low esr caps/extra low I already check that
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8289
            no there is no problems switching out an 85c rated cap for a 105c rated one, as long as they have same capacitance. The voltage gotta be the same or higher.
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
              by sam_sam_sam
              I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
              This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
