Aopen Z400-08FC PSU?
  • docbrown
    • Dec 2006
    • 8
    A few days ago i bought two 350W AOpen PSUs without knowing the exact name / model no.. My hope was that they were build by Fortron like my old 300W PSU.
    Today i recieved the parcel and i found out that i bought two "Z400-08FC" PSUs.
    The PSUs have the following specifications:
    +3,3V: 20A
    +5V: 20A
    +3,3/5V = 130W max.
    +12V1: 10A
    +12V2: 13A
    +12V1+V2 = 276W max.
    +5Vsb: 2.5A
    ATX 2.2
    Rohs
    PFC (passive)
    20/24Pin
    80mm fan
    I looked inside of one of them and found many Teapo, Capxon and one Ost cap (1x 3300uF 10V).
    My Question is: Who build this PSU and is it of acceptable quality?
    I cant find it at Aopens website, possibly because it is an OEM/bulk PSU.
    Perhaps someone can tell me a bit more about this PSU?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Aopen Z400-08FC PSU?
    what is written on top of one of the transformers?
    • Galvanized
      • Mar 2006
      • 468
      If the UL# is E135662(to be found on the sticker) the OEM is indeed Fortron.
      I have been told a number of times that Aopen cases are bundled with FSP units.
      http://www.jonnyguru.com/SMPS_UL.htm
      • docbrown
        • Dec 2006
        • 8
        I took two photos with my digicam.
        It starts with SPI.
        inside PSU
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          SPI = Sparkle Power Inc = Fortron
          http://www.sparklepower.com/
          • Galvanized
            • Mar 2006
            • 468
            Sparkle Power International LTD.
            FSP/Fortron owns Sparkle. Note the UL#.
            • docbrown
              • Dec 2006
              • 8
              Thank you all for your quick answers.
              I cant find an UL# code on the sticker, only a P/N:56.04400.A310 and S/N, but if SPI means it was build by Sparkle/Fortron, then its Ok.
              Everything i need is a PSU with at least decent quality.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                the aopen 350w units i got a while back are fortron.they were pulled due to +12 being out of spec.
                grabbed them before they hit the dumpster.they have fuhjjyu on the secondary.
                now to recap 40+ psu when i get time......
                • AJ847.63e
                  Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                  by AJ847.63e
                  Hi Folks,
                  Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                  I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                  The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                  05-06-2025, 10:37 PM
                • Dobrowol
                  Dell Latitude 3520 help with bios build/repair
                  by Dobrowol
                  Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                  Steps i done and results:
                  I exported a clean bios from update file via pfs extract.
                  1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                  Result: Dead
                  2. Build clean bios with no changes in ME, new PMC, PCH
                  Result: Dead
                  3. Build old bios with clean ME, new PMC, PCH
                  Result: The same
                  09-22-2023, 02:43 AM
                  ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                  This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                  09-12-2024, 03:28 PM
                • kahlil88
                  AOpen MX36LE-UN which replacement caps?
                  by kahlil88
                  Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
                  10-23-2025, 03:14 PM
