samsung 58 inch plasma
    hi i have a plasma samsung there is no picture at all sound is there but the screen does not even flicker in the dark the logic board on it just flashes 1 green led it does not flash on the front just like its on but with no picture any ideas u guys thanks
    Re: samsung 58 inch plasma
    First we need model numbers and clear pictures of the boards inside.the tv.
    Time to start checking voltages. you need a voltmeter and test voltages from the power supply outputs to the y and z main boards. There are some plug in connectors on the power supply that go to these y and z main boards that are located on each side of the tv. First unplug tv. Take back cover off.
    There is quite a bit of dc voltage in these TVs so be careful with what you are doing. Once you are there you need to locate the output pins for VS and VA. Set your meter on DC voltage auto range. Black lead anywhere like a screw lug on the chassis and red lead VS then VA when powered up.
    Let us know what you find.
      Right it's started clicking and not powering up so im changing all the caps on the power board first it clicks then clicks and then clicks over and over but no sound
        3 threads all on the same tv yet still no model number
          saying "58 inch Samsung plasma clicking" is about as good as saying "my car won't start, it's a blue Ford."
            It's a pn58b680 t6w
              Any ideas when I turn it on it does not play the start up sound it clicks over and over
                Could be main board, Y-main, X-main, panel.... how about some pictures?
                  main board problem . Hard to find this board.
                    I would start by disconnecting power lines going to Y and Z sustain boards, with tv unplugged. Then power on and see if it still clicks on and off.
                                on this one im getting a clicking sound on the power board im getting 202 from the vs then the power drops when the second click so it would be . CLICK 202V ........CLICK 201 200 199 198 and so forth
                                  i have narrowed it down to being the av board
                                    tom66 any places i could have a look on there to check voltage ?thanks
                                      How did you narrow it down to main board? Did you do the test pattern jumper?
                                        Well I have changed all the caps and I'm getting the right voltage to the main board and I think I may of caught a compasitor on the av board when I was checking it because it did power up just with no pic
