3Com OfficeConnect recapping
  • theokretes
    • Jul 2013
    • 49
    For an unrelated project, I bought a cheap 3Com Gigabit OfficeConnect switch ($3). I was expecting some bad caps but ALL of them were toast. Completely toast.
    It had GLORIA and Wendell caps, all of the GLORIA ones were bloated, and some on the verge of releasing electrolyte. Yeah the switch didn't work.
    I did however do a few modifications: I used 470uF 25v instead of 470uF 35v on the two input caps because that's all I had. I tested the voltage and it only went up to 18v. So we're within tolerance.
    I replaced all 330uF 16v with the same 470uF 25v caps. 220uF 16v were replaced with 220uF 10v polymer OSCONs (all that I had on hand). Aaaand, a 47uF I just threw in 100uF. Finally, I added two more 1000uF 6.3v filter caps on two unused pads. I figure they didn't populate those just to cut costs, but I need this thing to run stably, so yeah.
    Here's what it looks like AFTER:
    I tilted the tall 470uF nichicons because I want to ensure they have some clearance. Also regarding the ones that have the weird leg thing going on (near the coil rectifiers), RADIAL capacitors were originally there!
    I've really only seen radials on the old vintage stuff. Oh well. It looks horrible, and I generally hate making imperfect work like that, but I don't feel like hunting down some VXes just for a switch.
    The small blue and small brown caps are ELNA. I have lots of ELNAs kicking around. SILMICs too-- but you wouldn't use a SILMIC on a digital circuit.
    I can see why all of the original cheap capacitors were bloated, this switch gets quite warm after running for a few hours. Running 24/7 and it'll kill those cheap caps in no time (probably why not too many of these are around?)
    Up and operating perfectly (just try to ignore the diskette box):
  • Agent24
    I see dead caps
    • Oct 2007
    • 5068
    • New Zealand
    Re: 3Com OfficeConnect recapping
    At first when I saw the photo I thought "Whaaaaat the...???"
    But, if it works!
    If you wanted a neater look you could have probably bent the legs 90 degrees and put them on their sides.
    (By the way, I have 4 diskette boxes like that!)
    -David VanHorn
    • mariushm
      • May 2011
      • 3799
      You meant AXIAL capacitors... the ones with leads on each end.
      It's really not a good idea to leave the leads so long but I guess you couldn't do a much better job with a second try, and i wouldn't advise you because you may ruin the pads.
      I also don't like how you soldered the caps but I guess you probably couldn't clear up the holes to push the leads through the boards.
      If it works now, leave it like it is.
      As for "you wouldn't use SILMIC on digital circuits" that's bull. It's still a capacitor. Yeah, I probably wouldn't use it as filtering for a switching power supply but in this circuit, it's probably just some output capacitance on a small linear regulator, so it really won't make a difference that it's an "audio grade" capacitor.
      • theokretes
        • Jul 2013
        • 49
        Even if I desoldered the two axials properly and mounted them in the holes, the length of the leads would basically be the same. So... I thought it would be just easier to do it that way. A better solution would be if 3com didn't use the axials in the first place.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I like that recap .
          I do mine very similar - usually I have a bunch of quality capacitors but they aren't an exact match for what's in the equipment, so I do some voltage measurements and toss whatever I have plus populating the empty spots. Done many PC motherboards and LCD monitors that way and never had any problems.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Strange, because another 3com switch I saw before had philips capacitors... good stuff!
            Muh-soggy-knee
            • rafa.gao
              • Mar 2021
              • 1
              • brazil
              Hello guys i know that´s out of topic, but anyone knows where to download firmware images from old 3com switches? Or someone have of 3com 4200, 4400 and 4500 series? Hp removed all without notice....
              • Kingpin!
                3COM OfficeConnect Gigabit Switch 16
                by Kingpin!
                3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                09-17-2023, 04:58 AM
                HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 02:00 PM
              • mo000
                470uf tantalum caps replacement
                by mo000
                hi
                motherboard toshiba C50 PT10F
                i found 2 bad 470uf tantalum in cpu sircuit making short .
                but i only have 380uf tantalum can i replace them with electrolytic caps .
                05-11-2021, 10:44 AM
              • Perry Babin
                Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                by Perry Babin
                I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                This is for the primary side of a switching power supply in a car audio amplifier.
                Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                10-16-2025, 05:20 AM
              • howardc64
                UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
                by howardc64
                Just typical LED bar failure repair but discovered a couple of things worthy of posting
                PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
                2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
                10-13-2025, 05:56 PM
