PlayStation 3 Slim PSU, failed stb power
  • Marta
    • Aug 2014
    • 2
    • Sweden
    I have a PS3 Slim PSU with a failed standby power. It's a MIP836 chip that seems to be broken. A replacement is on it's way and I will also replace the feedback opto, but worry about the MIP836 may not be the root cause of the failure. Therefore I try to ask if anyone here has any experience of this PSU and it's weak spots?
    The board is labelled APS 270 MB 2
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: PlayStation 3 Slim PSU, failed stb power
    Never saw or opened any slim PS3 PSUs, though I have seen plenty of dead regular PS3 PSUs.
    My advice is to post more, and higher quality pictures here of both sides of the PSU.
    If you have some experience with power supplies, check the snubber network on the standby. Usually consists of a capacitor and resistor in parallel, and this in series with a diode.
    Should you decide to test the PSU with the new MIP836 chip, use the series incadescent light bulb trick to limit power, in case something goes wrong. That way, instead of a fuse blowing, the bulb will just become lit (or partially lit) and stay that way. More about this trick is written here:
    https://www.badcaps.net/forum/showpo...4&postcount=70
    Since you are only testing the standby power supply, a 25W to 60W bulb should suffice for the application. The APFC on these PSUs may cause the bulb to glow for longer than normal, though. If the bulb doesn't stop glowing in 5 seconds or less, STOP and uplug the PSU - there may still be something shorted.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • SoulFreeze
      Lenovo Slim Pro 7 14ARP8 83AX No Power
      by SoulFreeze
      Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
      Behavior - Pressing power button results in three second led blinks on the button,
      Connecting charger lights up orange as normally would while charging.
      Connecting charger without battery blinks orange.
      No fanspin.
      Tried flashing bios, no change.
      I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits...
      05-01-2025, 09:04 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
    • WTFRules!
      Lenovo IdeaPad Slim 3 15IAN8 won´t power on after power off without AC charger plugged in
      by WTFRules!
      Hi!
      I´ve this Lenovo IdeaPad Slim 3 15IAN8 with mainboard (KS480 / KS580) NM-E901 Rev 1.0
      I receive it for repair from another shop and it had shorted EC IT8227VG-256
      After replacing it and programming it with SVOD 4 (wich is new to me as I bought it in this week) the laptop is working fine now... BUT
      Once power off from windows, it will not turn on again. When off and the power on button is pressed, a white led turns on and that´s it.
      But if you plug the charger, then all the keyboard LEDs will lit and then you get image on screen and it boots normally....
      11-04-2025, 02:50 PM
