Toshiba c660D-16L power but doesnt boot
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello
    I have a toshiba c660D with LA-6849P motherboard.
    When I plugged it on power the green light that has power lights but when I press the power button nothing happens.
    I checked the power mosfets they have 19V.
    I checked the chipset PU330(page 30) which has 3 & 5 volt
    pin 16 VIN 19V
    pin 8 VREG3 3,3V
    pin 17 VREG5 5,08V
    so I have voltage there.
    Can someone tell me how to continue.
    PS I couldnt test the power button. What should I short to test if it power on without the button?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    Re: Toshiba c660D-16L power but doesnt boot
    do u have 3,3v on switch?
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      Yes
      • sparker1
        • Sep 2011
        • 343
        Check PQ331 and PQ332 for short. They were getting really hot on mine. On another one I had the KBC controller was shorted.
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          Here are the readings
          PQ 331
          pin 5,6,7,8 19V
          pin 1,2,3,4 3,3V
          PQ332
          pin 5,6,7,8 3,3V
          pin 1,2,3,4 0V
          • ahmetozay
            • Jul 2013
            • 73
            • turkey
            Check PBTN_OUT# on pin 117 of KB926QFE0 on page 23. you should have 3v there if not first flash the bios with programmer and see what happens. If still nothing change KB926QFE0 with the new one.
            P.S. First things first of course check the button itself and be sure it is ok. Sometimes just the button itself can be faulty even it looks like ok
            • rippergr
              • May 2014
              • 345
              • Ελλάδα
              Yes I have 3V there.
              Can you tell me what to short to start laptop without the power button 1&3 , 1&4?
              • ahmetozay
                • Jul 2013
                • 73
                • turkey
                put the probes on pins of the button then press the button and the voltage should goes to 0v if not change the button
                • rippergr
                  • May 2014
                  • 345
                  • Ελλάδα
                  It's a little difficult to measure it.
                  I attached 2 pictures to see how is the button.
                  There are no pins. How should I measure it?
                  Should I put -probe to ground and +ground to the first pin to see if the voltage goes to 0V?
                  • ahmetozay
                    • Jul 2013
                    • 73
                    • turkey
                    exactly like that. just black probe to the ground and red probe to the + side
                    • rippergr
                      • May 2014
                      • 345
                      • Ελλάδα
                      Voltage doesnt change when I press the button it remains 3.3V.
                      I tried short pin 1 with 4 ( ON/OFFBTN# with GND) but still nothing.
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        flash bios. also check EC.
                        • rippergr
                          • May 2014
                          • 345
                          • Ελλάδα
                          Can you tell me what do you mean EC? Where and how should I check it? Can I flash the bios without programmer?
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            Embedded Controller = EC (ite, winbond , etc..)
                            there are some ways to flash spi roms. google may help you on this.
                            • rippergr
                              • May 2014
                              • 345
                              • Ελλάδα
                              Can you tell me which chip is EC. I think it is U22 but if this is EC how can I check it , there are no visible pins.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                EC has pins. A lot of them. It's the ENE chip next to the RAM slots.
                                A working TV? How boring!
                                • rippergr
                                  • May 2014
                                  • 345
                                  • Ελλάδα
                                  Thanks it's the U52 chip which I measure the 117 pin and I have 3V.
                                  What pins should I check there?
                                  • Chieftain
                                    • May 2016
                                    • 72
                                    • Greece
                                    Your laptop switched on without posting or totally dead?
                                    If it is switching on , then you have problem with E-350 UMA VGA. You have to reball APU
                                    • lapfix
                                      • Mar 2020
                                      • 2750
                                      • my workshop
                                      Page 38 you have a gift : POWER SEQUENCE .
                                      you find +3/5 VL , next step is EC ON ( pin 102 of U52 ) check it .
                                      Also check +RTCVCC = D92
                                      R1074 both sides
                                      Q6 Drain and source
                                      • piernov
                                        • Jan 2016
                                        • 4437
                                        • France
                                        Last message in this thread was 6 years old.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • dicky96
                                          Toshiba Lifebook A514 - Power light illuminates, Battery Charges but won't boot up
                                          by dicky96
                                          Hi guys
                                          I have this Toshiba Lifebook A514
                                          When I got it the battery was flat, orange Battery LED on. When you press the power button, with PSU attached, the blue LED by the button (and the one at the front of the laptop) come on, but no fans no signs of life... Nada.
                                          I left it overnight on the charger and the battery did charge - no more orange light and the laptop will now power on without the PSU - but still no signs of life
                                          If you hold the power button in, it will not power down again, you have to switch off power to the PSU
                                          If you do...
                                          05-14-2021, 05:03 AM
