did i pull the foil tube out?
  • rustytierod
    • Sep 2014
    • 81
    I think I pulled the foil tube out while trying to desolder a 12x19mm cap. There is a little metal boot on one leg of the capacitor.
    This is not a motherboard but a spr4232 TV PSU.
    DAMMNIT.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: did i pull the foil tube out?
    If it is the power supply, chances are it is single layer. You most likely just have a blob of solder on the leg of the capacitor shaped like the hole. A picture would be helpful.
    • rustytierod
      • Sep 2014
      • 81
      Sorry, here
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        looks like solder.
        heat it with your iron if it melts the board is fine.
        If you are talking about the cap it is fine legs are same length.
        from the pictures the board looks intact cleaning the solder out will give more information.
        the board is double layer construction and will be fine if missing the hole plating.
        My pc
        CPU : AMD PHENOM II x4 @ 3.5Ghz
        MB : ASUS M4A89TD PRO USB3
        RAM : Kingston ValueRAM 16gb DDR3
        PSU : Cooler Master 850W Silent Pro
        GPU : ATI Radeon HD 6850
        • rustytierod
          • Sep 2014
          • 81
          Originally posted by joshnz
          looks like solder.
          That little boot thing won't melt. Is the little boot on the cap leg the hole plating?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            It could be.. although I have had similar shapes form several times when pulling components and it was just solder. I don't know what causes it.
            Also the board still shows a shiny ring, if the pad had lifted you would see bare fiberglass. I think it's OK.
            In any case, it's on the positive lead, and like joshnz pointed out, only the bottom side of those pads are connected there for those capacitors, so you don't really have to worry even if it did lift.
            The same can not be said for the entire board, though! If you did lift a pad on a double sided board, you may need to solder the lead on both sides when replacing the component, depending on where the traces go. This is sometimes very hard, especially if the pad is under a component which sits flush with the board. Best to avoid it!
            -David VanHorn
            • rustytierod
              • Sep 2014
              • 81
              Well if it's solder, it's like cast from the shape of the hole.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                If it won't melt it should pull off when solder is melted.
                Looking at it closer there is no trace connected to that side of the capacitor so will be no issue when re installing new on or same one with the remains or the hole plating removed from it.
                to stop it happening in the future a little longer heating sometimes helps.
                My pc
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Is your soldering iron tip tarnished? It should be shiny, not dull looking. If it is dull, then there is a layer of oxidation which is preventing there from being enough heat transfer to the solder on the capacitor leg.
                  And yes, it does look like solder to me also. I've pulled the legs partly out of some caps before (cheap caps are very easy to do it on). There will be a little metal "boot" there, it just goes down into the capacitor itself. If you pull it out further, you will get the flat tab of the lead wire. Then you know the cap is shot, as you have torn off the foil inside. On your capacitor, it is more like a ring shape. That leads me to think that you just have solder there.
                  Muh-soggy-knee
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • DCJack
                    B&K 707 tube tester. I need help.
                    by DCJack
                    Hi everyone!
                    I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                    Initially I noticed that I was not getting the red on-light to turn on, but it...
                    03-05-2024, 05:05 PM
                  • Schoenradt
                    ECH81/6AJ8 Vacuum Tube Question
                    by Schoenradt
                    Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                    06-10-2021, 05:49 PM
                  • valvashon
                    Repair Success! Middle Atlantic UPS2200R-IP
                    by valvashon
                    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                    02-06-2024, 12:54 PM
                  • corrize
                    How to desolder this component beside chemical cap ?
                    by corrize
                    Hello, I need your advise pls ?
                    The black component at the center of picture is dead, I need to replace it (it's a Nikon D5 camera). It's easy to desolder with hot air. But beside, there is a chemical cap, and I don't want to destroy it.
                    How do you do ?
                    I have low melt solder and good capton. Is it better to desolder the cap (for safe) with iron, then desolder-resolder the black component with hot air ? Or these caps are strong enough and capton and other cover can avoid hot air damage ?...
                    07-04-2022, 03:36 AM
